Codes P0193,P0301, P0316 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2014, 07:58 PM   #1
jbilly
Fan#: 157458
What I Drive: 2005, orange, Zx3
FF Reputation: 1 jbilly Good Standing Member
I've got a 2005 zx3 that has run great, about 163k on it and currently has the above codes coming up.
-Fuel rail pressure sensor circuit high point
-cylinder 1 misfire
-misfire detected 1st 1000 rev
My question is, what is the best solution to fix these three issues? Where do I start?
Thanks in advance for any advise!
jbilly is offline
Old 04-20-2014, 09:06 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,417, Level 75
Points: 13,417, Level: 75 Points: 13,417, Level: 75 Points: 13,417, Level: 75
Level Up 42% Completed
Forum Activity 99%
Fuel rail pressure sensor & wiring, as that fault could cause the other codes.
First question would be if it's running OK now. If so, reset codes - remove & replace wire connector at the sensor looking for faults there - none found, then drive & see if it shows up again.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
