Power drop Off - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2014, 07:57 PM   #1
Spike0205
Fan#: 155682
What I Drive: 2003 Silver ZX5
FF Reputation: 1 Spike0205 Good Standing Member
Exclamation Power drop Off
Well two week ago I had an ignition coil go bad. Replaced the wires and coil pack. Fixed the
Problem of a non firing cylinder. This week started the car and pulled out the drive way and
had the accelerator half way down; started off around 3000-3500 rpm felt like the engine
is stumbling and then takes off. But it varies sometimes. I went ahead
and replaced the fuel pump, throttle Position Sensor and new fuel filter. Does
Anyone have any other ideas. I don't want to spend another weekend trying anything
and everything
Spike0205 is offline
Old 04-20-2014, 08:07 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,774, Level 54
Points: 6,774, Level: 54 Points: 6,774, Level: 54 Points: 6,774, Level: 54
Level Up 12% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
The coil pigtail. Inspect it for pulled and/or broken wires, insulation.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 04-20-2014, 08:21 PM   #3
Spike0205
Fan#: 155682
Which coil set? Fuel pump wires or the ignition wiring set?
Old 04-20-2014, 09:00 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,344, Level 75
Points: 13,344, Level: 75 Points: 13,344, Level: 75 Points: 13,344, Level: 75
Level Up 24% Completed
Forum Activity 99%
Ignition Coil
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 05-03-2014, 10:25 AM   #5
Spike0205
Fan#: 155682
code update
I inspected the coil wires. They all look to be in good condition. So I took it over to the local parts shop to have them use a code reader on it. It gave two codes.
P0102- Mass Air Flow
P1246- Generator load input condition
Both these codes have open or shorted electrical causes as explanation.
I am at the point I may actually have to take the freak in thing to a dealer unless anyone has any ideas.
Old 05-03-2014, 03:04 PM   #6
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 1,791, Level 24
Points: 1,791, Level: 24 Points: 1,791, Level: 24 Points: 1,791, Level: 24
Level Up 91% Completed
Forum Activity 26%
Activity: 26% Activity: 26% Activity: 26%
FF Reputation: 11 Marde Great Standing Member
Disconnect the electrical connector at the MAF sensor. Inspect the wiring in this area. Remove and clean the MAF sensor with MAF Cleaner or Carb Cleaner.
You've got to ask yourself one question: Do you feel lucky? -and could you really drive a Focus ATX Wagon?
Marde is online now
Old 05-04-2014, 04:31 PM   #7
Spike0205
Fan#: 155682
Cleaned the MAF and the throttle body again. I noticed some moisture out of the exhaust. I put my hand over the exhaust pipe and notice hardly no pressure build up. I went ahead put it up on the ramps and noticed exhaust fumes leaking from the muffler. Could this be creating the code for the mass air flow? There is very little back pressure. I check the MAF connections for grounding and + voltage; they were all good.
Old 05-04-2014, 05:31 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Moisture out the pipe is normal until the whole exhaust gets hot (condensation of water in exh. gases).
If exh. flow doesn't seem adequate, have someone rev. the engine while you check the output. Flow should increase immediately with the RPM increase. RPM goes up & no proportionate increase in flow - you may have a plugged CAT. Revving it up & not getting much flow is typical of that.
Check for leaks toward the engine from the MAF, clear the code & see if it returns.
"Rubber Side Down"
Old 05-04-2014, 07:33 PM   #9
Spike0205
Fan#: 155682
I let it heat up and tested the back flow. The exhaust heated up and had someone rev it up. It built back flow once heated, but I could hear the leak. Then I drove it and notice I could hear the exhaust leaking out the muffler when the engine faltered. So I seriously think it is the exhaust leak causing the faulted in power. Any thoughts?
Old 05-04-2014, 08:00 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Nope - only an exh. leak at the header can cause engine issues, & that's just because of the affect on the O2 sensors.
You were worried about the amount of flow, so I just mentioned a quick check for that to confirm no issues there.
"Rubber Side Down"
