Radiator and Cap- ??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2014, 05:33 PM   #1
FordZX32000
Fan#: 33469
What I Drive: 2000 black ZX3
Points 982, Level 16
Points: 982, Level: 16 Points: 982, Level: 16 Points: 982, Level: 16
Level Up 82% Completed
FF Reputation: 1 FordZX32000 Good Standing Member
I put the cap on too tight after topping of the coolant tank. After the car was driven and came up to normal operating temp, water begin to spew out of the radiator obviously from a leak near bottom on drivers side.
Took the cap off after cool down and put back on snug. Ran car again and now loosing very little coolant, as in a tiny drip if that. Is there a certain way to put the cap on snug versus tight ?
FordZX32000 is offline
Old 04-20-2014, 08:52 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,570, Level 100
Points: 52,570, Level: 100 Points: 52,570, Level: 100 Points: 52,570, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (28)
Just finger tight is all I do , the coolant tank should only be filled to the hot mark if you fill it all the way up it will always blow some out
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-20-2014, 08:58 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,449, Level 75
Points: 13,449, Level: 75 Points: 13,449, Level: 75 Points: 13,449, Level: 75
Level Up 50% Completed
Forum Activity 99%
Look at the drain petcock on the driver's side for a potential source of the leak that's not tragic. It's just sealed by an O-ring when pushed in & twisted to lock in place.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 04-20-2014, 09:32 PM   #4
FordZX32000
Fan#: 33469
It's filled to the max level mark on the tank. It's not blowing out of the cap, when I put the cap on too tight. It was blowing it out of the radiator near the bottom on the drivers side and possibly in other areas of the radiator.
The petcock-water outlet to the radiator is not leaking. I can see a small drizzle of coolant just to the right of it on the actual radiator.
Old 04-20-2014, 09:37 PM   #5
FordZX32000
Fan#: 33469
I'm sure it's not leaking from the petcock. However just to the right of it there is a small drizzle of coolant.
I did not realize that the cap on the coolant tank, had so much control on the amount of pressure in the system.
Old 04-20-2014, 10:38 PM   #6
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
You should be able to simply tighten the cap fully on the reservoir and not worry about the "degree of tightening" of the cap. The fact that your car leaks when you have it properly tightened would indicate weaknesses in your cooling system that can't withstand the full 14 psi (iirc) system pressure. By leaving the cap lose or not fully snug, you're possibly decreasing the ability of your cooling system to cope with severe conditions. Fix the leaks; they could be sources of potential failure in the future that may leave you stuck on the roadside on a hot summer day.
BC_ZX3 is offline
Old 04-21-2014, 04:46 AM   #7
FordZX32000
Fan#: 33469
You have valid points here.
I certainly do not want to be stranded here in TX on a hot summer day !!!
Is it a pain to change out the radiator ?
Old 04-21-2014, 06:32 AM   #8
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
I don't have a Zetec.... but doesn't that reservoir cap have a torque cap that you can't tighten but so much? One that clicks free once you've gotten it tight? Those can go bad, but it's rare and usually after the car is very old or had some sort of problem where it had to be removed frequently.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 04-21-2014, 06:36 AM   #9
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
The newer redesigned ones click, the older ones just get snug. I bought a aftermarket replacement one that's a few psi higher than stock, it just screws on snug. The new tank and cap I bought for my other focus as a clicking top that won't let you over tighten it.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-21-2014, 11:07 AM   #10
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
one of the most common antifreeze leaks discussed on this forum is the thermostat housing. So, check that before you go to the expense of replacing a radiator, because a leaky housing could dribble down the engine/transmission and wind-up just a couple of inches from the petcock, fooling you into looking elsewhere for the source.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
