Car wont idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-18-2014, 09:32 PM   #1
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,167, Level 18
Points: 1,167, Level: 18 Points: 1,167, Level: 18 Points: 1,167, Level: 18
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Car wont idle
I just put a Top Speed Intake Manifold to my SVT along with a Focus Central 70mm TB, I'm throwing codes P1504 Which is IACV code and P1518 and P1520 those are the dual stage manifold codes because I removed the module. I'm currently trying to run off the idle screw. When I start up the car it revs to 5-6k then drops back down to 1k idles there but it's really stumbling around if I pull the throttle cabel to give it gas it will chug to 5-6k then dip to 1 k even if I keep it steady, it will repeat this over and over. Going to check my vacuum lines but they're all on there good. I'm going to put a clamp on all the houses to make sure. Does there need to be a min length on the lines? I have the 4 by the orginal Manifold and the red one with at the bottom all plugged in so all 5 are set up.
StephenElsbree1986 is offline
Old 04-18-2014, 10:14 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Do you have a tune for the manifold? If not then you need a tune to be able to run it. Contact Tom and he will get you a tune to be able to run it.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-18-2014, 11:30 PM   #3
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
What is TPS voltage at idle?
Odds are adjusting the idle screw is where it's nabbing you. You can't use the idle screw to adjust idle unless you can also adjust the tune; TP for PT counts needs to be adjusted. As well as the slew of tables that came from the IAC.
121,000 members and still no sponsored racing.
iminhell is offline
Old 04-19-2014, 06:00 AM   #4
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
Oh well, thank you guys very much! I'll send Tom my file and see if I can get updated!
Old 04-19-2014, 07:57 PM   #5
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
I'm seeming to have an issue Tom wants a 5 mins log but my car is stalling out at 20-30 secs each time no matter how I hold the gas. He cannot tell me what is wrong without a 5 min log, but I cannot get a 5 min log since my car stalls out....
Old 04-19-2014, 09:10 PM   #6
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Forum Activity 13%
He's online now, so probably by a phone also. Give him a call.
If it sorta idles, that would be a starting log.
You shouldn't have to drive it until it's actually running.
You sure you didn't put the MAFS in backwards?
Connector should be to the front of the car.
iminhell is offline
Old 04-20-2014, 04:53 AM   #7
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
I'm sure I followed the arrow, I'm going to assume there a vacuum leak somewhere even though, all my lines are clamped... Is it possible for there to be to much vacuum line causing an issue?
Old 04-20-2014, 09:23 AM   #8
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
Fixed, was something dumb on my part...... Rather not mention thanks guys!
Old 04-20-2014, 02:08 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,394, Level 75
Points: 13,394, Level: 75 Points: 13,394, Level: 75 Points: 13,394, Level: 75
Level Up 36% Completed
Forum Activity 99%
HeHe - If you claim you've never done something dumb when repairing/modding, you either didn't do it yourself or you're lying.
We've ALL "been there, done that" at one time or another.
"Bleep - I was SURE I plugged that in, hooked that up, tightened it right, didn't forget that part, etc etc"
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-20-2014, 08:26 PM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,508, Level 100
Points: 52,508, Level: 100 Points: 52,508, Level: 100 Points: 52,508, Level: 100
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
Buy-Sell-Trade Rating: (28)
I know I have done " dumb " things many times its all part of life
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
