alternator bad? or going bad? or bad groud or positve cables? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-18-2014, 08:52 PM   #1
Focuslu86
Fan#: 109201
What I Drive: 2001,yellow, zx3
FF Reputation: 1 Focuslu86 Good Standing Member
So my battery light came on when I put my turning light on, and then it disappeared. After that I decide to take my car to an auto parts to test my battery, starting system and charging system. The battery and starting system cam out to be normal, and the charging system was "overcharging" (high). Does that mean that I have a bad alternator? The car runs fine, but I have noticed that my head lights fickle. I tested the battery myself, and got 12.4 V (engine off), and then turned the engine on and got between 13.4-15.0 V. I then applied load (ac, lights, radio) and stayed within the same voltage 13.4-15.0. I then rev the engine to 2000 rpms and got the same values as well. Can a bad ground or bad ground cable or bad positive cable cause this problem? I do own a ford focus 2001 zx3 2.0 DOHC.
Focuslu86 is offline
Old 04-18-2014, 09:28 PM   #2
Bills86e
Bills86e's Avatar
Fan#: 119322
What I Drive: 2000 green SE, 2007 Kappa Speedster
Points 398, Level 7
Points: 398, Level: 7 Points: 398, Level: 7 Points: 398, Level: 7
Level Up 96% Completed
FF Reputation: 1 Bills86e Good Standing Member
Yes & yes. You need an $80 Pos & neg battery cable and an OEM alternator.
Been there, done that!
Bills86e is offline
Old 04-18-2014, 10:15 PM   #3
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Don't forget to check the Alternator pigtail as well.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-19-2014, 12:20 AM   #4
Focuslu86
Fan#: 109201
I have also noticed that the car seems to want to stall at idle, just struggles a little bit to stay running. I have had this issue for a long time if I think about it..does this mean bad wiring? pigtails or pos & neg cables? rather than the alternator?
Old 04-19-2014, 01:14 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
Could be the PCV valve hose that goes into the intake manifold, that's been known to cause idle issues.
Moderator for
Technical Chat
Old 04-19-2014, 12:19 PM   #6
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 2,324, Level 29
Points: 2,324, Level: 29 Points: 2,324, Level: 29 Points: 2,324, Level: 29
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 0 smallblockfever Newbie
I guess a good rule of thumb is to do the cheap (if not free) stuff first. Sleepyboy can attest that last night I had a fickle issue and all I needed was a better ground.
Check your grounds all around, double check your alternator pigtail, check the PCV hose as mentioned, and check that all your battery and power connections are snug, clean, and make good connections. If none of that helps, then start looking at the alternator issues. It seems that the power is being made (you're reading enough voltage) but it just may not be delivered appropriately (which means check your wires).
If all else goes screwy, I have had before where the alternator made power like it is supposed to, but the voltage regulator pooped out and so i no longer got consistent voltage. If that is the case, you can either get a new alt, or get your current one rebuilt.
"Never miss a good chance to shut up."
smallblockfever is online now
Old 04-19-2014, 08:38 PM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 55%
^^Up, crazy how a that worked out since it was working fine before, glad you got it fixed.
To the OP you may also want to consider the power wires as well. I went through 3 alternators before replacing the cables and I haven't had a problem since.
Moderator for
Technical Chat
