what is the "washer trick"? eagle eyes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-17-2014, 07:38 PM   #1
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
I've read about it and there's not a lot of info about it, when you install you're projectors I hear some guy's talking about the "washer trick" whatever that means, the left projectro is screwed up........what type of adjustabliity do you have?
badazz2010focus is offline
Old 04-18-2014, 03:36 PM   #2
King Hoonigan
King Hoonigan's Avatar
Fan#: 100769
What I Drive: 2011 Sterling Grey SES
FF Reputation: 1 King Hoonigan Good Standing Member
Not really sure what youre asking. Are you saying your left projector is screwed up and if theres some trick to fixing it?
-Fswerks Race exhaust-Eibach Pro's-Eagle Eye Projectors-Fswerks stage 2 turbo-H&R 20mm Spacers(rear)-3D Carbon Rear Diffuser-17" Sparco Tarmac's-EBC Drilled Slotted Rotors-
King Hoonigan is offline
Old 04-18-2014, 05:43 PM   #3
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,263, Level 19
Points: 1,263, Level: 19 Points: 1,263, Level: 19 Points: 1,263, Level: 19
Level Up 63% Completed
Forum Activity 4%
FF Reputation: 1 popwarhomie Good Standing Member
Ive heard the washer trick with morimoto MH1s but didn't know there was one for the ebay projectors.
2010 Focus SE coupe 5 speed
Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/Projector retrofit/LED tails/ Walled with 2 SQ HDC3 18s.
94 Lightning
A lot of mods.
popwarhomie is offline
Old 04-18-2014, 06:10 PM   #4
badazz2010focus
Fan#: 78166
Forum Activity 7%
No both projectors are fine but some guys are saying something about the washer trick ::shrugs::
Old 04-18-2014, 06:17 PM   #5
popwarhomie
Fan#: 94974
Forum Activity 4%
The washer trick for MH1s is to add washers behind the the lens to angle it out a little more. Makes for a more colorful cutoff.
94 Lightning
A lot of mods.
Old 04-18-2014, 07:35 PM   #6
badazz2010focus
Fan#: 78166
Forum Activity 7%
oh otay :)
Old 04-20-2014, 06:25 PM   #7
Fo Schmo
Fan#: 156554
What I Drive: MK2
FF Reputation: 1 Fo Schmo Good Standing Member
Apparently, there are two versions of the Eagle Eyes Projectors. The earlier version uses a slightly different bulb mount utilizing three screw fasteners, whereas the newer ones have a two screw setup.
For whatever reason, there is a slight dimensional difference between the two versions. In the older versions, there is no problem, but in the newer ones, that difference can produce a ragged/uneven light cutoff line when you install HIDs.
HID bulbs are a little bit longer than the original halogens, and protrude slightly too far into the projectors, distorting the cutoff line. To fix this, you can install small washers between the bulb mounting plate and the headlight body to back the HID bulb out of the projector just enough to sharpen the cutoff.
Fo Schmo is offline
Old 04-20-2014, 06:52 PM   #8
badazz2010focus
Fan#: 78166
Forum Activity 7%
Yeah I have that issue on my left side
Old 04-20-2014, 07:51 PM   #9
z4nder
z4nder's Avatar
Fan#: 103345
What I Drive: 2010 Sangria Red SES
Points 866, Level 15
Points: 866, Level: 15 Points: 866, Level: 15 Points: 866, Level: 15
Level Up 66% Completed
Forum Activity 2%
FF Reputation: 1 z4nder Good Standing Member
Sorry if link doesn't work, but here is the how to for installing the projectors I think what I have pasted is the page that talks about the washers may have to go back or forward a few pages. http://www.focusfanatics.com/forum/s...201024&page=13
Sedan Revolution #287
Tennessee Focus Owner #12
z4nder is offline
