2005 ZX4 ST grinding/groaning/vibration on acceleration - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-17-2014, 05:34 PM   #1
sleepylabone
Fan#: 156834
What I Drive: 2005 Silver ZX4 ST
FF Reputation: 1 sleepylabone Good Standing Member
I've searched and reviewed as much as possible but can't come up with anything conclusive based on other threads. In first gear, when accelerating from a stop, there is a fairly noticeable groan and vibration coming from the passenger side wheel area. It increases to an extent with speed but then stops completely. It does not occur at higher speeds, when braking, or in neutral.
My CV boots look fine, but my initial suspicion is that it's a CV problem. There is no play in the wheel and my rotors don't seem warped since braking is unaffected and it won't occur in neutral.
I got this car when I was 18, and drove it like it's fast for about 20k miles. Since then it's been sitting and used only occasionally, and now sits at 115k. Can anyone point me in the right direction? I don't want to spend money until I know for sure this problem is going to disappear. Thanks for reading and for your patience, as I know many threads are posted regarding similar issues.
sleepylabone is offline
Old 04-17-2014, 07:20 PM   #2
JPFocus86
JPFocus86's Avatar
Fan#: 115084
What I Drive: 2005 InfraRed ZX4 ST
Points 283, Level 5
Points: 283, Level: 5 Points: 283, Level: 5 Points: 283, Level: 5
Level Up 66% Completed
Forum Activity 5%
FF Reputation: 1 JPFocus86 Good Standing Member
Is this a vibration you can actually feel, or is it more of a noise you can just hear?
Previous: CD Silver 2000 ZTS 5-speed
Current: InfraRed 2005 ST
SR #279
JPFocus86 is online now
Old 04-17-2014, 08:37 PM   #3
sleepylabone
Fan#: 156834
I'd say the vibration is slight, the noise is far more noticeable. It also does not happen ALWAYS. Most commonly, if the car has sat overnight, it will grind up to about 3,000 RPM in first gear then stop. After driving for awhile, it won't happen at all. Let the car sit overnight again, and it'll act up until it's sufficiently "warm". At all times, the noise is lessened the faster I go.
I've identified that my struts are bad, which isn't too unexpected at 115k. They clearly vibrate/knock themselves, but this noise is isolated from the other issue. On an 05 ST, is most of the torque applied to the front right wheel?
Old 04-17-2014, 08:49 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 141,026, Level 100
Points: 141,026, Level: 100 Points: 141,026, Level: 100 Points: 141,026, Level: 100
Level Up 0% Completed
Forum Activity 48%
Activity: 48% Activity: 48% Activity: 48%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Probably the carrier bearing on the axle is bad or the wheel bearing is bad. I'm leaning more towards the carrier bearing. Get under the car and grab the right side axle between the carrier bearing and the knuckle/hub, push and pull it like a handle on a door, if you feel any side to side play then that bearing is bad. Also try slowly turning the axle and see if you feel any grittiness or anything other than smooth movement will also tell you if its bad.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 04-17-2014, 08:50 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,459, Level 75
Points: 13,459, Level: 75 Points: 13,459, Level: 75 Points: 13,459, Level: 75
Level Up 53% Completed
Forum Activity 99%
Does the noise go away after braking a couple times?
To answer the torque question, yes - even with the equal length shafts to reduce torque steer the right front is the one that'll break loose first under acceleration.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-19-2014, 03:47 PM   #6
sleepylabone
Fan#: 156834
I went ahead and just brought the car in to a local shop that writes free estimates. They came to the conclusion that it needs a CV axle on the front right, both struts, and all three motor mounts. My own parts cost for this would be under $300, their estimate is over $1,300. Does their diagnosis sound plausible, at least?
Old 04-19-2014, 04:41 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
You mentioned knowing the struts were bad, that doesn't relate to the noise.
R. Axle matches Sleepyboy's carrier bearing guess, concur that it's a likely cause.
Vibration is common from old engine mounts, particularly the passenger side, but noise from that isn't particularly common. More vibration cold is the only symptom of that which matches well. Doing all three at once is best when affordable, and the best results seem to come from a Ford one on the passenger side.
Doing it at home, I'd start with a look at that bearing as Sleepy recommended. Replace that axle if there's play there or any vibration felt when turning the axle. Next would be the bad struts, you've got to get the right partially out to do the axle so that's part way to replacement if doing them at the same time. No big deal, as you just loosened it it'll come out easier later.
Save the mounts for last & see what noises/vibration are left after other repairs. Vibration cold or when accelerating/turning are the first signs for them, you'll start getting the vibes at more times if they are going now. (Likely will be needed at your mileage, just prioritizing the list)
Cheers
"Rubber Side Down"
Old 04-19-2014, 06:43 PM   #8
sleepylabone
Fan#: 156834
Thanks a bunch. I started pricing out the parts from various retailers. Shop wanted $700+ for parts, Autozone/Oreilley/Advance between 4 and 500 (though with advance promo codes, they were the cheapest by far). I'm visiting family in Arizona right now anyway, and there's a place down the street called Parts Authority. Paid less than $300 for two complete Monroe strut assemblies, the CV axle, and two of the motor mounts (couldn't find the third one, which I believe is the problematic one that Ford would be best for). I figure I'll do the driver side strut, take off the passenger side strut, do the CV axle, put on the new strut, and then address the engine mounts separately. Solid plan? Thanks for the input so far, I appreciate it.
Old 04-19-2014, 07:21 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Sounds like a solid plan.
Pass. side axle is the easier one to replace BTW, driver's side is easiest by removing the passenger one first to pop out the axle with a drift. Passenger comes out without an issue once the bearing is unbolted.
"Rubber Side Down"
Old 04-19-2014, 07:52 PM   #10
sleepylabone
Fan#: 156834
For clarity, is it necessary to drain the transmission from the drain bolt prior to removal, or is a catch can under the shaft seal adequate?
