Need some help with cooling fan failure (not focus related) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-17-2014, 03:07 PM   #1
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
What I Drive: 2003 Liquid Grey ZX3
Points 2,453, Level 30
Points: 2,453, Level: 30 Points: 2,453, Level: 30 Points: 2,453, Level: 30
Level Up 2% Completed
FF Reputation: 1 03FocusZX3 Good Standing Member
Have a 98 Nissan Maxima and the cooling fans are not turning on, and the car will overheat. I've checked the relays and fuses and everything seems to check out. Need help asap, and thanks guys.
When I die, I want to go peacefully like my grandfather did, in his sleep, not screaming, like the passengers in his car.
03FocusZX3 is offline
Old 04-17-2014, 04:58 PM   #2
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
I'm asking because the Nissan people are no help and I usually get help here. I'm loyal! Lol
Old 04-17-2014, 10:43 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,746, Level 73
Points: 12,746, Level: 73 Points: 12,746, Level: 73 Points: 12,746, Level: 73
Level Up 74% Completed
Forum Activity 99%
Don't know if that one is old enough to have a separate sensor switch that USED to be the normal way to turn cooling fans on & off.
Look for one on the radiator first, then check for TWO by the thermostat if you don't find one at the radiator. Two by the thermostat, one is for the idiot light & the other for the fans.
Single wire is typical for sensor, two wire if you find it would be typical for a fan switch sensor.
Generic info. of typical older systems MIGHT help.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 04-17-2014, 11:58 PM   #4
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
Thanks sailor, Wish i could figure this crap out... Anyone else?
Old 04-19-2014, 03:57 AM   #5
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
Bump
Old 04-19-2014, 04:40 AM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,233, Level 100
Points: 138,233, Level: 100 Points: 138,233, Level: 100 Points: 138,233, Level: 100
Level Up 0% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
Do the fans come on with the a/c? All cars have the fans come on with the a/c this should tell you if they are working.
It's probably something simple. We used to have a Infiniti I30 (same as the Maxima). Those cars are dead reliable, but something stupid small can bring them down. We had problems with the coolant temp sensor freaking out. It would cause the car to stall and die but was a simple fix once we figured it out.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 04-19-2014, 05:35 AM   #7
Metalcrack
Fan#: 127930
What I Drive: 2014 Dark Gray SE
Points 119, Level 2
Points: 119, Level: 2 Points: 119, Level: 2 Points: 119, Level: 2
Level Up 38% Completed
FF Reputation: 1 Metalcrack Good Standing Member
I'd add a seperate relay tied to the ignition to get them working temporarily (maybe permanent) until you can track down the problem.
Stock HU -> Audiocontrol LC6i -> Planet Audio 4-Chan -> JBL/Crystal Mobilsound Comps -> Polk 8
Metalcrack is offline
Old 04-19-2014, 09:18 AM   #8
rexazz2
rexazz2's Avatar
Fan#: 121761
What I Drive: 2014 HB SE
Points 1,928, Level 26
Points: 1,928, Level: 26 Points: 1,928, Level: 26 Points: 1,928, Level: 26
Level Up 28% Completed
Forum Activity 12%
FF Reputation: 1 rexazz2 Good Standing Member
test fans with jumper wires directly to battery
if they work I would replace the coolant temperature switch
it should look something like this
if you unplug this single wire and ground it the fan should start
http://www.rockauto.com/catalog/more...552&cc=1316803
rexazz2 is offline
Old 04-20-2014, 01:09 PM   #9
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
Ty Rex! How do I hook it up that way? There little plastic connectors
Old 04-20-2014, 01:11 PM   #10
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
Yes, and sleepy boy, when I first tested the AC fan it worked, few days later it won't now
