Cold Air Intake NEED HELP! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-15-2014, 02:44 PM   #1
hellboy2332
Fan#: 156146
What I Drive: 2003 red/blacked out zx5
FF Reputation: 1 hellboy2332 Good Standing Member
Angry Cold Air Intake NEED HELP!
I have a 2003 2.0L zx5 and i went out and bought a spectre or what its called air intake from autozone put it all together and i unhooked the battery as well so it would be able to reset the ecu so the computer can realize theres a new upgrade and it can adjust to the right perimeters. But for some reason when i step on it, it seems like its almost slower and 3rd gear takes along time to get through now when before it didnt and im trying to figure out why and i cant. Please help
hellboy2332 is offline
Old 04-15-2014, 03:08 PM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,745, Level 58
Points: 7,745, Level: 58 Points: 7,745, Level: 58 Points: 7,745, Level: 58
Level Up 98% Completed
Forum Activity 21%
Activity: 21% Activity: 21% Activity: 21%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Are you using the MAF from your stock intake, is it in the stock tube (or tube of same diameter) and is it going in the correct direction? Is everything connected air tight so as no air is entering the engine unmetered?
Last I heard, spectra did not make a focus specific kit. I am assuming this is cone filter, how is it installed? Have you thrown a CEL? I would abstain from full throttle pulls until you have this sorted or return to the stock setup.
rambleon84 is offline
Old 04-15-2014, 03:31 PM   #3
benoit230
benoit230's Avatar
Fan#: 118823
What I Drive: 2007, Silver, ZX4 w/SAP
Points 932, Level 16
Points: 932, Level: 16 Points: 932, Level: 16 Points: 932, Level: 16
Level Up 32% Completed
FF Reputation: 1 benoit230 Good Standing Member
When I put mine on a few months ago I made the hose clamp on the throttle body too tight - loosened it up a bit and it was all good. Also, check your hose clamps every now and then I felt like I had a loss of acceleration last month and checked my hose clamps again and one of them was a bit too loose and I could have pulled off the hose.
Team Duratec #68
DD - "Argentum" 2007 Ford Focus zx4 w/SAP
Unnamed 2011 GMC Sierra 1500 SLE Z71 - White
benoit230 is offline
Old 04-15-2014, 03:51 PM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,015, Level 74
Points: 13,015, Level: 74 Points: 13,015, Level: 74 Points: 13,015, Level: 74
Level Up 42% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "Zetec Performance".
zetecDon is offline
Old 04-15-2014, 04:10 PM   #5
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
What I Drive: chcl gry 02 ZX3 - 5sp
Points 5,499, Level 47
Points: 5,499, Level: 47 Points: 5,499, Level: 47 Points: 5,499, Level: 47
Level Up 75% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
Buy-Sell-Trade Rating: (18)
You have toi let the car idle for 10 minutes after you reconnect the battery.
Make sure you hooked every thing back up, all electrical cables, and such.
I had a spectre on my last '05 at the bottom of the first filter box. Dont let that confuse you its totally different from Zetec. I forgot to hook up a few cables like the throttle body electric cable! D0H!!!!
"You are a person, No one can forget you, even if it's Good or Bad, you make waves!" #truth #truthinadvertizing...
R.I.P. Pat :-( HN #68 - Focus Takeover #008 - principal defensor para el diablo
daspazzZX3 is online now
Old 04-18-2014, 10:16 PM   #6
Tyfocus95
Tyfocus95's Avatar
Fan#: 120306
What I Drive: '14 Race Red SE sedan
Points 353, Level 7
Points: 353, Level: 7 Points: 353, Level: 7 Points: 353, Level: 7
Level Up 6% Completed
FF Reputation: 2 Tyfocus95 Good Standing Member
Chances are it's confusing the heck out of the MAF. I own a 2014 so I'm not entirely familiar with Zetecs. But generally because you replaced the box (restrictive by design) with a full open end cone filter you are losing vacuum pressure. This causes a slight (sometimes more) loss in HP/TQ on the low end say before 4,000 rpm but a gain of HP/TQ on the upper end. I experience this myself on my 2014 focus with an after market CAI. Like others have suggested, did you reinstall all cables/wires? Maybe get MAF spray cleaner and clean it. It could have got debris on it in the process of putting on the spectre. Maybe put back on the OEM airbox and see I it acts the same? Let us know what you find!
Tyfocus95 is offline
Old 04-28-2014, 08:44 PM   #7
fmirenzi
Fan#: 99753
What I Drive: 2001 Black ZX3
FF Reputation: 1 fmirenzi Good Standing Member
Check that your hose clamp on the hose to the throttle body isn't loose.
fmirenzi is offline
Old 04-28-2014, 09:34 PM   #8
benoit230
benoit230's Avatar
Fan#: 118823
or too tight
Team Duratec #68
Old 06-28-2014, 05:25 PM   #9
Toother1321
Fan#: 111111
What I Drive: 2003 Red ZX3
Points 195, Level 3
Points: 195, Level: 3 Points: 195, Level: 3 Points: 195, Level: 3
Level Up 90% Completed
FF Reputation: 1 Toother1321 Good Standing Member
Just curious how a "too tight" hose clamp would screw up the MAF
Toother1321 is offline
Old 06-29-2014, 06:50 AM   #10
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 340, Level 6
Points: 340, Level: 6 Points: 340, Level: 6 Points: 340, Level: 6
Level Up 80% Completed
Forum Activity 5%
FF Reputation: 1 GhostTribute Good Standing Member
If I remember correctly there have been cases where if you tighten them too much it can crack the housing. This could cause false MAF readings. I.E. There could be more air getting into the engine than the MAF is reading. Therefore, based on the improper signal sent from the MAF to the engine management system (ECU), the air to fuel ratio would not be correct. This could cause a stumble or drop in power/performance.
GhostTribute is online now
