Killing you guys with another sway bar thread - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-15-2014, 05:46 PM   #11
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
I think the stock size back then was 18mm.
Someone correct me.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 04-19-2014, 08:22 AM   #12
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,717, Level 76
Points: 13,717, Level: 76 Points: 13,717, Level: 76 Points: 13,717, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Originally Posted by nboyles85737 View Post
Haha Cali car for the first 11 years of its life, then I got it :) when i crawl under the arms they still look solid. and does anyone know what the stock sway size would be? 00 se zetec
And Felix, what do you prefer? Steedas rear or eibach? I also read that switching the front sway isn't important/not needed?
If your changing out the rear, for sure do the front. A great bar setup is the Eibach kit= 22mm/ 25mm. I went w/ Steeda's fatman bar= 28.6mm from Eibach's 25mm one. Anymore then a 25mm bar, you'd need suspension mods.
felixthecat is offline
Old 04-19-2014, 11:28 AM   #13
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,365, Level 75
Points: 13,365, Level: 75 Points: 13,365, Level: 75 Points: 13,365, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
Looked up the front size in the stickies to remind myself.
18mm for cars with only the front bar, 21mm for those with front & rear.
That holds thru '07 for sure, I'll call it likely the same thru '11 but I haven't seen confirmation.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-19-2014, 12:35 PM   #14
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,883, Level 59
Points: 7,883, Level: 59 Points: 7,883, Level: 59 Points: 7,883, Level: 59
Level Up 67% Completed
Forum Activity 30%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Only the svts had a 21mm front iirc, other models would have had 20mm. I believe some of the second gens came with a 22mm front too.
I switch front 18mm front and 0mm rear to 21mm front and 22mm rear...been happy with that setup
rambleon84 is offline
Old 04-21-2014, 12:25 PM   #15
nboyles85737
nboyles85737's Avatar
Fan#: 130386
What I Drive: 2000 Autumn Orange SE
Points 6,804, Level 54
Points: 6,804, Level: 54 Points: 6,804, Level: 54 Points: 6,804, Level: 54
Level Up 27% Completed
Forum Activity 100%
FF Reputation: 5 nboyles85737 Good Standing Member
ah shoot im dumb, i put steed vs eibach when i meant h&r vs eibach. anyways what would i need to do if i went bigger than 25?
nboyles85737 is online now
Old 04-21-2014, 03:56 PM   #16
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Checking those rear lower arms for reinforcement would be important, as rambleon mentioned that wasn't present except on the SVT in '00.
felix can comment on how low he is (don't remember myself) - works better to be stiff & low before trying an extreme rear bar. Stiffer springs can take some of the load, so not as much gets transferred to the other side by the bar. Big Bar, soft springs, un-reinforced arms - you're likely to break a lower arm.
You're a bit lower & stiffer, so a bit stiffer on the bar would match.
Stiff bar with moderate springs can be a handful - note the ST stays on the road with stability assistance using that setup. Testers note that can be too much of a good thing, more balanced like the Fiesta ST is easier to handle.
"Rubber Side Down"
Old 04-22-2014, 11:44 AM   #17
nboyles85737
Fan#: 130386
Forum Activity 100%
ah so than massive 28mm bar requires new rear springs, and maybe new/re-enforced arms? got it haha 25 eibach for sure. thanks guys!
Old 04-22-2014, 02:33 PM   #18
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Just remember that the SVT used reinforced LCA's, even with a 21mm bar, and that reinforced LCA's became std. early in production for ALL cars (but after yours).
"Rubber Side Down"
Old 04-30-2014, 05:35 PM   #19
ChrisRobin
ChrisRobin's Avatar
Fan#: 46204
What I Drive: 04 silver SVT Focus
FF Reputation: 4 ChrisRobin Good Standing Member
I second the Eibach kit. The rear 25mm bushings are easy to find if you need to replace them (you can use 1 inch bushings), although getting 22mm bushings is a bit of a since Eibach is the only supplier.
Originally Posted by WRCwannabe View Post
...and then slap a supercharger on it and rape their tits off.
ChrisRobin is online now
Old 04-30-2014, 05:39 PM   #20
nboyles85737
Fan#: 130386
Forum Activity 100%
Forgot to add I ordered eibach set
Sedan Revolution Member #288
the Broken Focus
Autox'er
