Killing you guys with another sway bar thread - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2014, 01:09 PM   #1
nboyles85737
nboyles85737's Avatar
Fan#: 130386
What I Drive: 2000 Autumn Orange SE
Points 6,788, Level 54
Points: 6,788, Level: 54 Points: 6,788, Level: 54 Points: 6,788, Level: 54
Level Up 19% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 5 nboyles85737 Good Standing Member
So im in the market for some sway bars and it looks like eibach, steeda and h&r all make sway bars for the '00 focus (im on svt springs if that matters at all).
the eibach and h&r ones are both about 200 bucks and the steeda one is about 100. are the steeda sway bars crap?
so im getting a rear sway bar for sure, is the front worth it? to those who own them, what are your thoughts on the brand you own? also do i need adjustable? is an adjustable one worth the money?
nboyles85737 is offline
Old 04-14-2014, 02:38 PM   #2
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
The SVT suspension isn't really that aggressive. It may be cheaper and equally satisfying to just find an SVT sway bar.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 04-15-2014, 02:18 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,329, Level 75
Points: 13,329, Level: 75 Points: 13,329, Level: 75 Points: 13,329, Level: 75
Level Up 20% Completed
Forum Activity 99%
Adding poly bushings would tighten that up another notch & make a balanced suspension on the cheap.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 04-15-2014, 05:53 AM   #4
nboyles85737
Fan#: 130386
Forum Activity 100%
so youre all firm believers of svt sway bars?
would i be ok just getting some eibach sway bars? if not could you explain why?
Old 04-15-2014, 06:33 AM   #5
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,715, Level 76
Points: 13,715, Level: 76 Points: 13,715, Level: 76 Points: 13,715, Level: 76
Level Up 17% Completed
Forum Activity 100%
The Eibach set are 22mm & 25mm. Thats a great setup. I've had that setup for yrs, when it was packaged as a frpp's kit. I've since upgraded to Steeda's 28.6mm rear bar a few yrs ago. I'd go w/ the Eibach kit. H&R's front bar is a 24mm w/ 2 adjustments. It might sound good to have a big adjustable bar, but not for a front bar. Its a fwd car so you want the bigger bar on the rear. A bigger rear bar is going to tranfer diaganal weight to the inside front wheel for better traction out of corners.
felixthecat is online now
Old 04-15-2014, 09:52 AM   #6
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,883, Level 59
Points: 7,883, Level: 59 Points: 7,883, Level: 59 Points: 7,883, Level: 59
Level Up 67% Completed
Forum Activity 30%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
What sort of shape are your rear lower control arms in? The reason I ask is this:
http://www.focusfanatics.com/forum/showthread.php?t=402402
The SVT LCA's were reinforced compared to the stock ones in '00 as well. So you may want to beef those up if you are going with a larger bar that will be increasing stiffness
http://www.oakos.com/wrx/swaybarchart.htm
rambleon84 is offline
Old 04-15-2014, 10:05 AM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Originally Posted by nboyles85737 View Post
so you're all firm believers of svt sway bars?
Suggestions by now range from the cheapest on up - even the poly bushings on stock rear bar makes a difference.
All this is assuming you're starting with an existing rear bar. Swapping front & rear plus adding the rear mount kit (plus welding that on for best results) would be the start if you DON'T have a pair already.
"Rubber Side Down"
sailor is offline
Old 04-15-2014, 10:05 AM   #8
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
I don't have any cracks or nothing. My arms are like new or better then new, since I clean them ever so often, along w/ the bars.
Old 04-15-2014, 03:45 PM   #9
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 30%
I think you being in WA and the OP being in AZ, both of you should fair better than us guys in the salt belt. You have good habits checking them out periodically
Old 04-15-2014, 05:34 PM   #10
nboyles85737
Fan#: 130386
Forum Activity 100%
Haha Cali car for the first 11 years of its life, then I got it :) when i crawl under the arms they still look solid. and does anyone know what the stock sway size would be? 00 se zetec
And Felix, what do you prefer? Steedas rear or eibach? I also read that switching the front sway isn't important/not needed?
