Immobilizer light stays on - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-30-2014, 11:35 AM   #11
NIKO-007
Fan#: 86107
What I Drive: 2008 Silver Focus TDCI 1.6 Remapped
Points 69, Level 1
Points: 69, Level: 1 Points: 69, Level: 1 Points: 69, Level: 1
Level Up 38% Completed
FF Reputation: 1 NIKO-007 Good Standing Member
I have fitted an EGR blanking plate to my car today as a cheap fix hoping it would cure my problems, it did not, the car runs fine with the EGR unplugged but is a NCT test fail because of the EML light, the test is next month.
I think i need to get a new EGR valve but would like to try cleaning out the old 1 first but i have no idea of how to get the little clip on and off that connects the EGR cooler to the EGR valve, any ideas.
I am getting a P0698 OBD code http://www.dtcsearch.com/P0698/
NIKO-007 is offline
Old 04-30-2014, 12:11 PM   #12
pfsantos
Fan#: 125113
What I Drive: 2009 Silver SES
Points 723, Level 14
Points: 723, Level: 14 Points: 723, Level: 14 Points: 723, Level: 14
Level Up 23% Completed
FF Reputation: 1 pfsantos Good Standing Member
Well, but it runs fine as in no symptoms like before? Then its a stuck open egr valve.
And yes, unplugging it or removing is not a solution cuz the engine is looking for it (it thinks the wiring inside the egr is broken).
I agree - try cleaning - but cuz of your issue take a pic of the clip.
Paulo - '09 SES Silver
pfsantos is offline
Old 04-30-2014, 12:20 PM   #13
NIKO-007
Fan#: 86107
Points 69, Level 1
Here is the same clip but on a diff pipe, easier to take pics of as its better exposed:-
NIKO-007 is offline
Old 05-01-2014, 05:31 AM   #14
NIKO-007
Fan#: 86107
Points 69, Level 1
Would anybody know if this Peugeot EGR clamp will fit my car? as Pug Ford and Citroen all use the same engine.
http://www.ebay.co.uk/itm/GENUINE-CI...item3a8e95ba1e
NIKO-007 is offline
Old 05-01-2014, 08:39 AM   #15
NIKO-007
Fan#: 86107
Points 69, Level 1
I managed to get original clip off and back on, you just need to be brutal with it, i cleaned up the EGR valve, there were lots of carbon powdery deposits in there, it was a bout a quarter full of the stuff.
The same symptoms persist, car is hard to start and cuts out at any time, i get the code P0405, could my EGR valve actuator be damaged ?
http://www.obd-codes.com/p0405
The car runs just fine with the EGR unplugged.
Any help appreciated.
NIKO-007 is offline
Old 05-01-2014, 08:41 AM   #16
pfsantos
Fan#: 125113
How many pins on valve? How many (edit: km's) on engine?
Edit: when cleaned up, did it close completely? Any vacuum connections to it?
And u didn't say...when u had the block off plate, all symptoms were gone?
pfsantos is offline
Old 05-01-2014, 08:47 AM   #17
NIKO-007
Fan#: 86107
Points 69, Level 1
There are 5 pins on my valve and 108000 miles thats 173000k on her.
I am thinking that as my valve was full of carbon then the actuator would have trouble moving and over time get damaged and so i need a new 1.
NIKO-007 is offline
Old 05-01-2014, 09:16 AM   #18
pfsantos
Fan#: 125113
Sounds like you do need a new valve.
Being a 5-pin, it's not as easy to test for a regular DIY'er. It probably opens a varied amount as requested by the ECU and may include a circuit to show position. If it was a 2-pin, you could test it by applying 12V + and a ground.
pfsantos is offline
Old 05-01-2014, 09:26 AM   #19
NIKO-007
Fan#: 86107
Points 69, Level 1
I have also fitted a blanking plate though, now that my EGR is clean and possibly functioning normally could my banking plate cause these issues on my car?
Or do i need a new EGR and can i just fit it or do i need to have ford code it in as i have read somewhere ?
NIKO-007 is offline
Old 05-01-2014, 09:29 AM   #20
pfsantos
Fan#: 125113
Its definitely possible. Try running without it. There may be a diff sensor for detecting egr flow or temp., and you're misleading it.
pfsantos is offline
