Rear Rotor Question - HELP!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-14-2014, 12:00 AM   #1
JPfocus23
JPfocus23's Avatar
Fan#: 106356
What I Drive: 2012 White HB (Storm Trooper)
Points 945, Level 16
Points: 945, Level: 16 Points: 945, Level: 16 Points: 945, Level: 16
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
FF Reputation: 1 JPfocus23 Good Standing Member
Hey Everyone! So, I am trying to install new extended lug studs so I can run my 20mm spacers. I am only installing these in the rear.
So, I unhooked my ebrake, removed the rear caliper, and I go to remove the rear rotor and it will not budge. If I'm not to be mistaken, these are a floating rotor, correct? I tried hitting it with a rubber mallet, but still no movement. I cannot see any reason as to why it will not come off. Am I missing something? Or is it just really stuck on there. Any help you guys can give me would be absolutely great! Thanks guys!!
'12 Focus Oxford White Hatch
IG: jfiddles
JPfocus23 is offline
Old 04-14-2014, 08:15 AM   #2
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
Hit the rotor face in the area between the studs with a metal hammer with good enough aim that you don't hit the studs, and with a contact that evenly strikes the face of the hammer against the rotor to spread out the impact area. Don't hit the wear surface of the rotor with the metal hammer. You can spray the area between the rotor and hub, and area between the rotor and studs with a good penetrating fluid prior to whacking it if it is bad (and clean the penetrating fluid off with brake clean prior to re-installing). A good practice is to clean the hub face and inside face of the rotor prior to re-assembly, and use a thin skim of anti-seize on both surfaces to prevent this from happening on the next round.
Rat Fink is offline
Old 04-15-2014, 08:37 PM   #3
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Ford Focus Hatchback SE RR DCT
Points 4,935, Level 44
Points: 4,935, Level: 44 Points: 4,935, Level: 44 Points: 4,935, Level: 44
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 1 Jburks Good Standing Member
Off topic,but what spacers did you go with? all the 20mm i've seen are bolt on where you dont have to replace the stud.
2014 Focus SE DCT RR. "Fiona"
Mods- Green Drop in-Snorkel Delete-plastidip-RokBlokz
Instagram- _jburks_
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is online now
Old 04-15-2014, 10:23 PM   #4
4mikebruns
Fan#: 119661
What I Drive: 2014 SGM DCT Focus SE (sedan)
Points 667, Level 13
Points: 667, Level: 13 Points: 667, Level: 13 Points: 667, Level: 13
Level Up 34% Completed
FF Reputation: 2 4mikebruns Good Standing Member
That's impossible you can't run more than 5 mm spacers without getting extended studs. Please do not attempt to either as serious harm will follow
4mikebruns is offline
Old 04-15-2014, 10:27 PM   #5
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,532, Level 47
Points: 5,532, Level: 47 Points: 5,532, Level: 47 Points: 5,532, Level: 47
Level Up 91% Completed
Forum Activity 10%
FF Reputation: 35 thenorm Great Standing Member
he's talking about a bolt on spacer.
example
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
Old 04-15-2014, 10:29 PM   #6
4mikebruns
Fan#: 119661
That doesn't look very safe either...The original studs are past the hub
Old 04-15-2014, 10:29 PM   #7
Jburks
Jburks's Avatar
Fan#: 145009
Forum Activity 15%
check it. No need for a extended stud. it's built into the spacer. relax.
http://www.fswerks.com/collections/f...cer-5x108-20mm
http://www.fswerks.com/collections/f...cer-5x108-25mm
Instagram- _jburks_
Old 04-15-2014, 10:30 PM   #8
Jburks
Jburks's Avatar
Fan#: 145009
Forum Activity 15%
Many people on here have been running spacers with no issues at all.
Instagram- _jburks_
Old 04-16-2014, 07:52 AM   #9
4mikebruns
Fan#: 119661
hmmmm.... interesting though.
Old 04-16-2014, 10:09 PM   #10
thenorm
thenorm's Avatar
Fan#: 14947
Forum Activity 10%
many wheels have voids on the hub face where those original studs that stick out will fit without contacting anything.
for my wheels, i even had to add the slightest additional divet because my spacers were only 15mm thick. and i used low profile nuts
May 2014 ROTM
thenorm is offline
