No power on hills, rough idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2014, 06:28 PM   #1
FriskyDingo
FriskyDingo's Avatar
Fan#: 145578
What I Drive: 2000 Bright Atlantic Blue LX
FF Reputation: 1 FriskyDingo Good Standing Member
Plugged in a scan tool today and at idle im getting 40% engine load and usually around 18* timing.Fuel pressure was as high as 50 idle and lowest was 38 under load.
FriskyDingo is offline
Old 04-13-2014, 07:18 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,807, Level 73
Points: 12,807, Level: 73 Points: 12,807, Level: 73 Points: 12,807, Level: 73
Level Up 90% Completed
Forum Activity 99%
How 'bout a compression test to start with, then go from there with other possibilities.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 04-14-2014, 11:29 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,023, Level 74
Points: 13,023, Level: 74 Points: 13,023, Level: 74 Points: 13,023, Level: 74
Level Up 44% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
Old 04-15-2014, 04:18 PM   #4
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 487, Level 9
Points: 487, Level: 9 Points: 487, Level: 9 Points: 487, Level: 9
Level Up 74% Completed
Forum Activity 14%
FF Reputation: 1 Leora83 Good Standing Member
Sailor has an excellent idea. Bad compression on one or more cylinders will cause those symptoms, and if that's your problem you need to know sooner rather than later.
If your compression is good, here are a few other things to check: idle air control valve, PCV hose, coil & harness. All are common issues with these cars.
Leora83 is offline
Old 04-19-2014, 01:11 PM   #5
FriskyDingo
Fan#: 145578
Turned out my timing was retarded by one tooth, car has power now.For anyone else who may be having this problem i noticed low vacuum, which affected the brakes you had to rev the car or the booster wasnt getting enough vacuum.Also when the car was near empty it would act as if it was running out of gas and i would get the rotten egg smell like my cat was bad.
