Tell us all your success/fail Focus stories! Write, write, write! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 04-11-2014, 03:43 PM   #1
Pirate2.0
Fan#: 72072
What I Drive: 2001 Burgundy Focus SE
FF Reputation: 1 Pirate2.0 Good Standing Member
Proud 2001 Focus SE owner here.
205,700 original miles.
2 timing belts, 1 thermostat housing, 1 clutch, 3 mounts, 1 radiator, 1 reservoir tank, 3 set of tires, countless oil changes, 1 fuel pump and 2 serpentine belts later and this car still drives me to work everyday, with the A/C on full blast working as good as the first day.
I'm a diesel mechanic and I do all the work on my car and I would like to say thank you Ford engineers for such an amazing car and thank you fellow Focus owners that understand that taking care of a car is the only way to prove others that our Fords are not "horrible 4 bangers".
If you're interested, I'll tell you all how this car used to drive in the Utah mountains every weekend, 4 people inside, while towing a trailer with 4 dirtbikes on it, EVERY SUMMER WEEKEND.
My baby:
http://imgur.com/Dr7Bslv.jpg
Pirate2.0 is offline
Old 04-14-2014, 08:27 PM   #2
autolite
autolite's Avatar
Fan#: 46002
What I Drive: 2006 pitch black zx4
Points 460, Level 9
Points: 460, Level: 9 Points: 460, Level: 9 Points: 460, Level: 9
Level Up 20% Completed
FF Reputation: 3 autolite Good Standing Member
2006 Focus. 136,000 Miles put on sway bar end links and front brakes. Its a great car only problem is I drove my nephews ST yesterday I want a ST. when mine wears out.
autolite is offline
Old 04-17-2014, 12:08 PM   #3
Jensen_75
Fan#: 140346
What I Drive: 03 Screaming Yellow SVTF
Points 283, Level 5
Points: 283, Level: 5 Points: 283, Level: 5 Points: 283, Level: 5
Level Up 66% Completed
FF Reputation: 1 Jensen_75 Good Standing Member
I have had my SVTF since the first week of March and within the first two weeks I got new tires and discovered that the lug nut holes were trashed. Found the clutch master cylinder leaking. The thermostat housing failed, changed it, fired up the car and it was running on 3 cylinders. Bought plugs and plug wires, still no change. Come to find one of the wires to the coil pack connector from the engine harness corroded through and broke off so I changed that. Then my left front brake caliper locked up. changed that and the car has treated me well since. Currently have brake kit in the mail and many many more things to work on.
2003 Screaming Yellow SVTF aka "The Screaming Banshee" - Part out
1990 Black Chevy Suburban aka "Frank The Tank"
1990 Red Mazda MX-5, 1.6,PS,PB,5spd,VLSD
Jensen_75 is offline
Old 04-20-2014, 07:45 PM   #4
KittenMittonz
Fan#: 148826
What I Drive: '00 Se Wagon/'98 F150
Points 162, Level 3
Points: 162, Level: 3 Points: 162, Level: 3 Points: 162, Level: 3
Level Up 24% Completed
FF Reputation: 1 KittenMittonz Good Standing Member
Bought a 2000 se in march which had quite a few electrical issues effectively making the following non functional; radio, cruise control, brake lights, signal lights, heater fans, hatch open button, and door ajar warning while driving. A few fuses, sensors, switches, radio and a new blower motor made short work of them all (minus signal lights which I'll learn to live with).
With the blower working I was then able to smell the burning oil from the leaking valve cover, no biggie. The biggie was looking at all of the water that had pooled up over the spark plugs when the previous owner pressure washed the engine. New pugs and wires and the car finally sounded like it was running good.
While on a test drive the transmission was slipping bad so I decided to swap the filter and it has been driving good ever since. Also swapped the fuel, air, pcv and egr just because. The car runs really good. Was getting 15mpg, now getting 23 city!
KittenMittonz is offline
Old 04-20-2014, 10:53 PM   #5
b.pearson
b.pearson's Avatar
Fan#: 130617
What I Drive: 2003 Infrared SVT ZX5
FF Reputation: 2 b.pearson Good Standing Member
Mine's a fail and short - My sunroof hasn't been working right at all, relearn doesn't work, pulled the glass to check better for stuck things and broke one the glass' support beam things. So I went from a sunroof that doesn't work right to a sunroof that I can't use at all. Yay me lol
2003 SVT ZX5- EAP rims, FSWerks Race cat-back exhaust, FSWerks SRI, Spectre cone filter & breather filter, FSWerks front splitter, SAP rear diffuser, upgraded throttle body (Size and brand unsure), HID headlights, more to come!
b.pearson is offline
Old 04-22-2014, 09:12 PM   #6
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,424, Level 21
Points: 1,424, Level: 21 Points: 1,424, Level: 21 Points: 1,424, Level: 21
FF Reputation: 2 Miztaken1312 Good Standing Member
When I first got my 2008 in April 2010, I was updating the sync system with whatever the latest update was for it. It didn't go well and I ended up completely breaking the entire sync system. I was so lucky I had warranty still.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 04-22-2014, 09:42 PM   #7
FreeFocus
OOOOH...SHINY
FreeFocus's Avatar
Fan#: 112674
What I Drive: 2002 SPI Focus
Points 20,786, Level 90
Points: 20,786, Level: 90 Points: 20,786, Level: 90 Points: 20,786, Level: 90
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 3 FreeFocus Good Standing Member
Cleaned engine bay, coil pack broke, no big deal got it fixed, 2 weeks later got new tires, went to get them changed, coil spring broke, batting 1.000 right now.
MY FOCUS HAS A HEMI IN IT
Focus TakeOver#001 Co-Founder
Sedan Revolution #289
FOCUS XTREME
FreeFocus is offline
Old 04-23-2014, 03:23 PM   #8
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
PIRATE2.0 - is your SE a Ztec or SPI? Car body looks great. I couldn't help notice your headlights look a little frosted - is that just the photo or have you ever tried polishing and sealing them? I hear that Florida sun is brutal, just as brutal as the high altitude sun.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
