Spec Stage 1 Clutch w/Spec Steel Flywheel - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-11-2014, 09:03 AM   #1
Megagwar
Megagwar's Avatar
Fan#: 114192
What I Drive: 2003 Faded Infra Red SVT
Points 928, Level 16
Points: 928, Level: 16 Points: 928, Level: 16 Points: 928, Level: 16
Level Up 28% Completed
Forum Activity 3%
FF Reputation: 1 Megagwar Good Standing Member
So it's coming close to time to get a new clutch... :/
I was looking for a little more performance than stock clutch. Rev harder. I was looking at getting this combo: Spec Stage 1 and Spec Steel Flywheel. Anyone have this setup? If so, how do you like it? Or should I stick w/OEM clutch from Luk?
Also, what else should I get when I go to redo my clutch? Trying to get a list down and purchase everything at once.
Megagwar is offline
Old 04-11-2014, 10:32 AM   #2
ShadowFocus603
ShadowFocus603's Avatar
Fan#: 118448
What I Drive: 2004 Pitch Black SVT EAP 2Dr #1878
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
FF Reputation: 1 ShadowFocus603 Good Standing Member
Make sure you get the slave cylinder and axle seals. The Stage 1 is fine if you don't plan on adding big power (read turbo supercharger etc). The steel flywheel won't let the car rev as quickly as aluminum but it wheel minimize clutch chatter at idle.
2004 Ford Focus SVT #1878
ShadowFocus603 is offline
Old 04-11-2014, 11:45 AM   #3
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,135, Level 18
Points: 1,135, Level: 18 Points: 1,135, Level: 18 Points: 1,135, Level: 18
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 3%
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Well, I hate spec. I like them on the fox bodies. But my Spec stage 3 broken in with 700 didn't last or grip worth a shit. I have a Clutch Master stage 3+ and I like it allot more grips better, flywheel is lighter then specs alum. Cheaper friction zone replacement. Isn't the OEM Luk dual mass flywheel like 21lbs? That's alot of parasitic drag iirc for these cars.....
175WHP/153TQ N/A
StephenElsbree1986 is offline
Old 04-11-2014, 12:06 PM   #4
Megagwar
Megagwar's Avatar
Fan#: 114192
Forum Activity 3%
Thanks. Yea I'm not planning to go turbo or supercharger. For the steel, that's what I figured. Really don't want too much chatter.
O really? So would suggest a Clutch Master Stage 1 over the Spec, from your experience from the Spec Stage 3?
Yea I believe so it's 21lbs. Would like to lessen the wait.
Megagwar is offline
Old 04-11-2014, 12:09 PM   #5
ShadowFocus603
Fan#: 118448
I haven't seen a steel flywheel less than about 24 lbs. Either clutch masters or spec (cant remember) aluminum flywheel is 12 lbs. Fidanza had a 9lb flywheel but I'm not sure if that was ever offered for SVT.
Old 04-11-2014, 12:45 PM   #6
Megagwar
Megagwar's Avatar
Fan#: 114192
Forum Activity 3%
According to CFM, the Spec Steel flywheel is 20lbs. Stock is 24.5lbs. Spec has an aluminum flywheel that is 12lbs. I heard about the Fidanza one. That's pretty light.
Megagwar is offline
Old 04-11-2014, 12:47 PM   #7
StephenElsbree1986
Fan#: 104271
Forum Activity 3%
Chatter chatter, performance upgrades make noise. I barley notice the chatter at all. Spec's is bigger at 12 lbs TBH I thought CM when I weight it after taking my spec off was 9.3lbs but it been years ago. Call to verfy but it isn't 12lbs. I'd go higher then stage 1 anyways..... Even if a DD with no N/A mods, I come from fox bodies and cabel clutches. I like to feel the clutch and it gripping!
175WHP/153TQ N/A
Old 04-11-2014, 03:56 PM   #8
apagios
apagios's Avatar
Fan#: 40891
What I Drive: '03 ZX5 SVT, '05 Mazdaspeed Miata
Points 873, Level 15
Points: 873, Level: 15 Points: 873, Level: 15 Points: 873, Level: 15
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
FF Reputation: 3 apagios Good Standing Member
I'm on my 3rd Spec Stage 2 clutch. I love the feel and rev-happy nature with the 12 lb Al flywheel, but with the kevlar friction material I really can't get more than 60-70k miles out of the clutch. (Stock clutch failed at 45k miles, replaced with Spec stage 2, then again at 110k miles, and again at 175k miles, at 190k miles now).
Honestly if the car lasts me, the next clutch may be the Spec Stage 1 just to go back to the organic material see if it lasts longer. Spec has a "+" rated clutch that uses the spring fromt he next stage up, when it comes time I'll call and see if they can give me a stage 1 organic disc but with the spring force of my stage 2 since I like the heavier pedal feel.
apagios is offline
