Vibration over 120km - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-08-2014, 04:47 PM   #1
D-Jack
D-Jack's Avatar
Fan#: 122833
What I Drive: 2008 Black Focus SES
FF Reputation: 1 D-Jack Good Standing Member
Hey Guys,
I have an annoying vibration once I hit 120km and continues as the speed climbs. It feels like the passenger front end, tires are brand new but it may be a bent rim I guess.
Any ideas? I read that it may be a hydro-bushing on the wishbone arm.
Any help would be great!
P.S. Engine mount was just replaced.
Dan Jackson
Focus Fan!
D-Jack is offline
Old 04-09-2014, 02:36 PM   #2
FordServiceCA
Official Ford Rep
FordServiceCA's Avatar
Fan#: 116356
What I Drive: 1908, Black, Model T
Points 95, Level 1
Points: 95, Level: 1 Points: 95, Level: 1 Points: 95, Level: 1
Level Up 90% Completed
Forum Activity 3%
FF Reputation: 1 FordServiceCA Good Standing Member
Originally Posted by D-Jack View Post
Hey Guys,
Hi D-Jack,
Was your dealer able to diagnose the issue? I encourage you to book an appointment with them if you haven't done so already; they are in the best position to assist. :)
Bianca
FORD SERVICE
p: 800.565.FORD
t: @FordServiceCA @FordFocus @FordCanada
f: facebook.com/FordFocus facebook.com/FordCanada
FordServiceCA is offline
Old 04-09-2014, 02:49 PM   #3
D-Jack
D-Jack's Avatar
Fan#: 122833
They were not able too and as it has passes the extend warranty period I am looking a solution if possible before I spend too money on diagnostics
Dan Jackson
Focus Fan!
D-Jack is offline
Old 04-09-2014, 03:16 PM   #4
D-Jack
D-Jack's Avatar
Fan#: 122833
Any chance you know a good Ford service in Toronto????
Dan Jackson
Focus Fan!
D-Jack is offline
Old 04-10-2014, 03:58 PM   #5
FordServiceCA
Official Ford Rep
Fan#: 116356
Points 95, Level 1
Forum Activity 3%
Hi D-Jack,
You can find a dealer for a second opinion here.
I hope this helps! :)
Bianca
FORD SERVICE
p: 800.565.FORD
Old 04-10-2014, 04:18 PM   #6
ThaKillerKlown
ThaKillerKlown's Avatar
Fan#: 73791
What I Drive: '11 SES Sedan
Points 473, Level 9
Points: 473, Level: 9 Points: 473, Level: 9 Points: 473, Level: 9
Level Up 46% Completed
Forum Activity 4%
FF Reputation: 1 ThaKillerKlown Good Standing Member
Did you have the issue before you put the new tires on it?
ThaKillerKlown is offline
Old 04-10-2014, 04:22 PM   #7
pfsantos
Fan#: 125113
What I Drive: 2009 Silver SES
Points 724, Level 14
Points: 724, Level: 14 Points: 724, Level: 14 Points: 724, Level: 14
Level Up 24% Completed
FF Reputation: 1 pfsantos Good Standing Member
Wouldn't be engine or tranny mounts. More likely out of balance tire (I'd recheck the balancing, bent rim, maybe bad tire internally (yes it's possible), loose tie rod or ball joint, rust/debris between wheel mounting area and rotor, etc. So a few things to check.
But to isolate the problem down to a wheel or tire (or not), rotate the tires (fronts to back and vice versa).
pfsantos is offline
Old 04-10-2014, 04:50 PM   #8
Lajtung
Lajtung's Avatar
Fan#: 153666
What I Drive: 2000 Silver Zetec-S
Points 146, Level 2
Points: 146, Level: 2 Points: 146, Level: 2 Points: 146, Level: 2
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 Lajtung Good Standing Member
Tire balancing, most defenetly. Had same prb when I bought new set. Vibration while driving >120km/h.
When I went back to the shop, they rebalanced the whees an everything was O.K.
Lajtung is offline
Old 04-11-2014, 10:08 PM   #9
D-Jack
D-Jack's Avatar
Fan#: 122833
My sister had the car for a year while I was overseas and when we got back there was a vibration but then the tire blew so I thought that was the issue then we had a vibration at idle and at higher speeds so I switched out the mount which solved the vibration at idle but we still have the vibration at high speeds which is where I am at now
Dan Jackson
Focus Fan!
D-Jack is offline
Old 04-11-2014, 10:13 PM   #10
D-Jack
D-Jack's Avatar
Fan#: 122833
I will get the alignment and balancing done and go from there
Dan Jackson
Focus Fan!
D-Jack is offline
