180* T-Stat Question - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 04-13-2014, 10:02 AM   #61
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 3 Juicedz Good Standing Member
It was a 94 camaro z28. They usually put down 230-240rwhp stock, which was ground breaking back in the day lol. The more you can cool that air inlet temperature the better, which is why guys were putting down the 5-8rwhp by eliminating 200f coolant running through the throttle body. Cooler air means denser air, which turns into mooo powa! Haha I agree with what you're saying though it won't be comparable to a tune, intake, or exhaust modification. Also, from what I recall swapping the t-stat in the mk3 isn't a 5 minute job by any means. You could wait until the scheduled interval change but that's 100,000 miles. If the juice is worth the squeeze I suppose (pun intended).
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
    Quick reply to this message
Old 04-13-2014, 10:12 AM   #62
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,165, Level 96
Points: 26,165, Level: 96 Points: 26,165, Level: 96 Points: 26,165, Level: 96
Level Up 82% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
Originally Posted by 1turbofocus View Post
Adding the 180 deg thermostat isnt for racing , In my opinion its for anyone adding a tune and almost any mod to there engine
This started out as a serious questions , It was " questioned " and opinions were made not to use it now those are making lite of it and in my opinion it isnt funny , I answered all the questions and BS with good straight answers and from some one that has actually installed many and tested them vs all the others that have never even installed and tested a 180 thermostat in a Focus
I dont say things and answer things just to be typing things and to keep things stirred up , If you feel the need to " question " things thats great I invite it, there is questioning things then there is making comments like you actually know what your talking about yet you have never even installed a 180 deg thermostat and tested it , and you make comments turning others away from doing it by your opinions and " questioning " and it is clear you have no clue what your talking about
If your adding a tune and modding your car there is only upsides to adding a 180 deg thermostat, There is 5 pages of unsupported opinions and BS and one that has actually had a 180 deg thermostat and installed dozens of them and tuned many more , It works !
Originally Posted by dyn085 View Post
Yes, emissions is a large part of it as well. Don't forget to mention the increased warm-up times in the winter which leads to increased engine wear and increased times for the interior to reach a comfortable temperature. A large portion of wear on an engine throughout its life comes from pre-warmup driving.
As stated above, the main benefit for this is people that live in higher-temperature states to help keep the ECU from retarding timing; this results in a better overall fuel burn.
My first response, which questions nothing and literally agrees with and is posted directly after one of your posts.
Increased warm up time ? The 180 doesnt take any longer to get up to temps then the 192 does if thats what you mean, Interior temps will warm up the same time
The 180 deg thermostat will still run in the 190-200 range which is MORE then enough to keep you toasty in side , In my opinion ALL states will benifit from the 180 and there would be no down side to it , for those in the Northern states the Fans can be set for a winter tune where they dont come on so soon if needed
The person questioning/arguing.
Feel free to show me where I told people to not do it. Try to discredit me as you want I really don't care, but if you actually read what I type instead of trying to argue for literally no reason then you will see that I've stated multiple times that it will benefit some, though more than others.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 04-13-2014, 10:28 AM   #63
Juicedz
Juicedz's Avatar
Fan#: 108814
Forum Activity 2%
Alright you two, back to your corners. Does the coolant system have a bleeding valve or what would the process be for removing air in the system?
Juicedz is offline
Old 04-13-2014, 10:50 AM   #64
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,536, Level 100
Points: 52,536, Level: 100 Points: 52,536, Level: 100 Points: 52,536, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
You never came right out and said NOT to use it but your postings do say just that
False
There is no longer warm up time , ECU warm up time is set to 145-165 in the ECU and water warm up time is set by the Thermostat which is 180 so you actually have less warm up time with a 180 ,
False , A 180 deg will warm the cabin just as quick it isnt that difference between 180 deg and 196 deg that warms the cabin
False , the 180 deg thermostat is for 99% of all Focus from Mexico to Canada , even people in cooler areas will fully benefit from a 180 deg thermostat from its safety and added performance with no downside
in the winter, you accept that the heater will take longer to get warmer because your coolant is flowing and fans are already on, all while it's cold outside
Who said the Fans were on , your assumption that the fans come on at 180 deg was just that your assumption and it was incorrect , again I say the 180 deg thermostat still runs the engine temps between 190-200 deg ans sometimes higher
It's not unbearable, it just takes longer to warm the cabin.
False
Carbon won't burn off as well, which is pertinent to those that drive DI powerplants
False , the big issues with carbon on the DI engines is in the intake runner where a cooler thermostat has no effect , this comes more from sucking in the hot oily air from the PCV and the Valve cover , stop this and you stop 95% of the carbon build up
If your comments above does not sound like your saying not to use the 180 deg thermostat then I dont know what does , because you dont come right out and say it doesnt mean it isnt what your saying
I am in no way trying to discredit you in any way jut to answer you concerns you posted so others can see that a 180 thermostat with tune and mods will benefit everyone if anything you are discrediting everything I am saying by posting questions , I answer then you move on and give no credit to my testing and experiences by either agreeing or posting your testing and experiences by actually trying it and posting what you found
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 04-13-2014, 10:54 AM   #65
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 61%
The Focus is self bleeding just make sure you idle it till your fans come on watching the water reservoir , it goes down some when the thermostat opens , do a short drive and recheck water level to be sure
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-13-2014, 11:04 AM   #66
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 60%
False
False
I am in no way trying to discredit you in any way jut to answer you concerns you posted so others can see that a 180 thermostat with tune and mods will benefit everyone if anything you are discrediting everything I am saying by posting questions , I answer then you move on and give no credit to my testing and experiences by either agreeing or posting your testing and experiences by actually trying it as to what you found
This is exactly my point-you are the one arguing. My posts do not say to not use them and I have repeatedly stated that in an effort to hopefully get you to understand. You are implying it and trying to make me the anti-thermostat-changer-guy.
The fact of the matter is that when you change a part, there will always be a trade-off from OEM design and operation. Those that think otherwise are delusional. You cant lower your car without changing comfort/handling characteristics, you can't modify your intake without changing power/economy characteristics, you can't change your thermostat without changing heating/cooling (engine and interior) characteristics.
Give it a rest and sell your tune, geez. Like I said in my first post in this thread, you can run a tune with or without the 180 thermostat.
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 04-13-2014, 11:08 AM   #67
Eminaga
Eminaga's Avatar
Fan#: 123953
What I Drive: 2014 Focus SE (Performance Blue)
Points 1,192, Level 18
Points: 1,192, Level: 18 Points: 1,192, Level: 18 Points: 1,192, Level: 18
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 24%
FF Reputation: 1 Eminaga Good Standing Member
I have a feeling my focus will benefit from this mod after a tune to srt the fans to come on a bit earlier. It started warming up around here and I can already feel that the heath is effecting my focus a lot more then it did my mustang. After the car is fully warmed up a d cruising you can tell the heath is taki g power away big time. Actually I would say it seems to be effecting it more then any other car I had. I hope the termostat+tune can keep my car cooler and running the same like when its 50* weather outside unlike yesterday at 70*+. I believe when tom tells that it benefits our cars.
*Snorkel/Shroud Delete, ITG Filter, Full ST Exhaust, E-RMM, Steeda RSB, Vogtland Springs, 180* T-Stat, Custom SCT Tune by Tom @ Focus-Power*
Eminaga is offline
Old 04-13-2014, 11:11 AM   #68
Eminaga
Eminaga's Avatar
Fan#: 123953
Forum Activity 24%
Its not that you are telling people not to do a thermostat mod dude, its the fact that you are arguing against it so much yet the difference in heating cooling is very very litle plus the benefits could be great.
Eminaga is offline
Old 04-13-2014, 11:29 AM   #69
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 60%
So you have a problem with me mentioning the trade-offs off deviating from OEM design?
It's like this-when I bought my V-Maxx coilovers there were members that already knew they didn't fit the Mk3. I was pissed at the fact that none of them would choose to say anything online where people could be informed before making the decision to use them. It's a problem that is rampant within the Mk3 community, which is further compounded by the fact that some members don't want to believe anything other than a perfect-world scenario and will argue vehemently just to not be wrong.
This is part of why the Mk3 community is the laughing-stock of the Focus community. Even the ST members are mature enough to be able to receive and handle information in order to make a decision. The majority engage in critical-thinking daily and encourage sharing of information-both positive and negative-in order to figure out what products best fit their lifestyle. They already know that what works well for person A will not work well for person B.
Buy the thermostat, use Tom's tune, all you will see is a benefit with absolutely zero trade-offs for everyone everywhere. It's exactly what the engineers designed but someone along the line slipped up and changed the part on accident. This has nothing to do with selling product it's simply what is the best decision for all Mk3 owners everywhere.
There, I said what you want to hear (though you'll add a sarcastic tone when you read it and blame me for it). It's all rainbows and unicorns (sarcasm).
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 04-13-2014, 11:33 AM   #70
Eminaga
Eminaga's Avatar
Fan#: 123953
Forum Activity 24%
I apreciate you are trying to help the mk3 community and you have been doing it way longer then I have been on this forum. I think I am done with this thread.
Eminaga is offline
Closed Thread
