2000 ford focus zx3 engine cranks but wont start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-06-2014, 10:52 PM   #1
gsweaver
Fan#: 154242
What I Drive: 2000 blue zx3
FF Reputation: 1 gsweaver Good Standing Member
my names gordon an di have a problem and dont know what else to look for, my problems all started when the fuel pump went out as usual the car would turn over but not start thats a given, but what is baffling me is i just put in a new fuel pump and the engine will crank and it still wont start, need help fast
gsweaver is offline
Old 04-07-2014, 09:18 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,737, Level 73
Points: 12,737, Level: 73 Points: 12,737, Level: 73 Points: 12,737, Level: 73
Level Up 72% Completed
Forum Activity 99%
Can you hear the pump run at all when the key is first turned on?
Put much fuel in the tank?
Can you see fuel on a spark plug?
Check the cutoff switch & reset?
Any fuel at the fuel rail?
What was the reason for replacing the pump? (That might not be the problem, or the only problem)
Think about "fuel, spark, compression, timing" when looking for why it won't run. All have to be correct for it to run properly.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-19-2014, 04:39 PM   #3
gsweaver
Fan#: 154242
thanks sailor, i was getting fuel to the fuel rails behind the motor but was getting no spark, replaced the coil pack still nothing then i noticed the crankshaft sensor was disconnected, plugged it back in the it finally started.
gsweaver is offline
Old 04-19-2014, 05:07 PM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
FF Reputation: 49 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
lol
That'll do it.
Odd thing is, that is the ONLY sensor the car needs to run. It can BS it's way through not having the rest. Albeit not run well or safe.
OH, you're not playing dumb ...
iminhell is online now
Old 04-19-2014, 05:44 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Thanks for posting the fix!
It can take some perseverance to keep checking things 'till you find the problem.
"Rubber Side Down"
