Questions about the different Injected tunes. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-06-2014, 10:08 PM   #1
Kjanracing
Kjanracing's Avatar
Fan#: 135409
What I Drive: 2014 Ruby Red SE hatch with DCT
Points 503, Level 10
Points: 503, Level: 10 Points: 503, Level: 10 Points: 503, Level: 10
Level Up 6% Completed
FF Reputation: 2 Kjanracing Good Standing Member
Hi all. I received my Injected tuner last week. Loaded the 93 octane tune. Love it. So, a few questions for the folks that have had the tuner for a while. Have you noticed a big power difference between the tunes: 87,91,93? D you have one you prefer over another? Have you found better fuel mileage with a certain tune? The 93 tune feels great, just not sure I want to run premium gas all the time as this is a commuter car. I haven't received the DCT tune yet as they are working on new files. Even without, the operation is a lot smoother. I'm really looking forward to loading the DCT tune. I'd love to dyno the tunes,switching fuel would be the hard part. Thoughts on testing all tunes with premium? I use the term premium because in Denver, we have 91 octane as the highest grade. Octane requirement is lower at higher altitudes, so I am actually running 91 octane fuel with the 93 tune. If I were making a trip to sea level or close, I'd back the tune down first.
Thanks for your input.
K&N drop in. Ceramic Smervic bearing retrofit. DCT Phase Detractor delete. Injected Tune. Back Joy seat cushion.
Kjanracing is offline
Old 04-06-2014, 10:21 PM   #2
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
What I Drive: 2014 Tuxedo Black Focus ST1
Points 1,742, Level 24
Points: 1,742, Level: 24 Points: 1,742, Level: 24 Points: 1,742, Level: 24
Level Up 43% Completed
FF Reputation: 4 Whodatxevg Good Standing Member
Five speed, but if I drive conservatively I can get better MPGs with a tune (87 or 93 doesn't matter) because the increased torque in the low RPM range let's me shift sooner.
'13 Oxford White sedan 5 speed. (SOLD)
15.00x @94.3
"Spirit of John Force" driver mod
Whodatxevg is offline
Old 04-06-2014, 10:22 PM   #3
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
I also just switched from 93 to 87 today because screw $4.20 gas. I feel a loss of power over 4000 RPM but below 4k it feels the same.
By loss of power I mean it still makes more than stock, just less than the 93 tune.
15.00x @94.3
Old 04-07-2014, 01:37 PM   #4
4mikebruns
Fan#: 119661
What I Drive: 2014 SGM DCT Focus SE (sedan)
Points 675, Level 13
Points: 675, Level: 13 Points: 675, Level: 13 Points: 675, Level: 13
Level Up 50% Completed
FF Reputation: 2 4mikebruns Good Standing Member
Ive always found the 91 tune to make the most felt torque and had the smoothest powerband. I run 93 no matter what tune its on though. I'm in the same boat as you on waiting for DCT files... my last car had the DCT tuned as well and youre in for a treat. Be prepared for off the line wheel spin and 2nd gear chirp
4mikebruns is offline
Old 04-08-2014, 06:36 PM   #5
Jburks
Jburks's Avatar
Fan#: 145009
What I Drive: 2014 Hatchback SE RR DCT "Fiona"
Points 6,080, Level 50
Points: 6,080, Level: 50 Points: 6,080, Level: 50 Points: 6,080, Level: 50
Level Up 65% Completed
Forum Activity 86%
Activity: 86% Activity: 86% Activity: 86%
FF Reputation: 2 Jburks Good Standing Member
I wanted to know about the octane's as well. I was told if you are running the 93 octane then you should be using no less then 93 octane but if you run the 91 then you can run 91 octane and higher. is that correct? I live in washington and the highest octane we have is 92 so i wasnt sure if i should go with the 93 octane tune or 91 octane tune if i were to go with injected. We only have 87,89 and 92 octane gas here and i want to use premium.
Green Filters drop in-Snorkel Delete-Steeda RSB-Fswerks RMM insert-Focus Power Tune.
Build thread-http://www.focusfanatics.com/forum/showthread.php?t=382642
Jburks is online now
Old 04-08-2014, 06:39 PM   #6
4mikebruns
Fan#: 119661
Use an octane booster and you should be ok to run the 93 tune. It's not too expensive. I'd buy octane booster and fill with 89. It'll prob cost the same as filling with 92 between the bottle and gas. Just a suggestion.
I reprogrammed to 93 octane tune last night and today I noticed it does indeed pull harder in 93 mode than in 91. Must've been bad gas I had the 1st time I tried it
Old 04-08-2014, 06:45 PM   #7
Jburks
Jburks's Avatar
Fan#: 145009
Forum Activity 86%
I wouldnt be against doing that but then would that be something i have to do everytime i fill up? I would rather just get the 91 octane and run 92 unless it is okay to run 92 octane with the 93 tune. Tom said he can tune for the 92 octane so i might just go that route too. I'm still way on the fence about what tune i want to go with.
Old 04-08-2014, 06:48 PM   #8
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
On Injected's thread they did say that you can not run 92 or lower on the 93 tune, you can still 92+ on the 91 tune so you would be correct. I was also told by them that you can run e85 on the 93 tune provided your car is flex fuel capable.
15.00x @94.3
Old 04-08-2014, 06:48 PM   #9
4mikebruns
Fan#: 119661
I won't argue who is better. To each his own. Injected will be releasing a Cam Lope feature soon though that'll make the car sound cammed and I'm looking forward to that. I chose them because I just wanted to be able to tune and be done and not data log for the best tune and what not. Nothing against Tom or SCT. Plus I used a promo code and my device was 400 shipping and all. So a tad cheaper.
Old 04-08-2014, 06:57 PM   #10
Jburks
Jburks's Avatar
Fan#: 145009
Forum Activity 86%
Cool, thanks for the info! so i'd just go with the 91 tune and run 92 octane then.
Yeah that is definitely something i like about injected. I'm not to sure i want to do data logging either. plug and play is nice. :) Plus from what i have read the DCT tune they offer gives a noticeable improvment in the way it shifts and the power it puts down which are the main reasons i want a tune anyway. I hate the way the DCT shifts.
