How bad are these motors? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-07-2014, 09:06 PM   #11
Wulff45
Fan#: 148170
What I Drive: 2002 SE sedan
FF Reputation: 1 Wulff45 Good Standing Member
Aside from the defective valve seats, these are pretty reliable engines. The most common issue is timing belt, which should be changed around 100K/8 years, so it doesn't leave you stranded, usually at a bad time......
The valve seat issue can give a warning, though often it doesn't. A misfire code that isn't cured by plugs/wires, could be caused by a loose valve seat, or possibly a sticking valve. Either of these requires head removal to fix.
Wulff45 is offline
Old 04-10-2014, 02:18 PM   #12
Mandroid
Mandroid's Avatar
Fan#: 150610
What I Drive: 2003 light tundra metalic SE 5spd
Points 1,108, Level 18
Points: 1,108, Level: 18 Points: 1,108, Level: 18 Points: 1,108, Level: 18
Level Up 8% Completed
FF Reputation: 1 Mandroid Good Standing Member
I wish I had the money to just put a heads only head on it ASAP. Even if I did I wouldn't have anywhere to do it. And even if I did I wouldn't have a car until I got it done. And even if I did I wouldn't have the time to do it lol. If I can get 130k out of it I would be happy. I take really good care of my cars
Mandroid is offline
Old 04-11-2014, 03:58 PM   #13
Svizzara
Svizzara's Avatar
Fan#: 98554
What I Drive: '01 SPI Sedan
Points 408, Level 8
Points: 408, Level: 8 Points: 408, Level: 8 Points: 408, Level: 8
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 Svizzara Good Standing Member
^ pay a shop to do it and you can whittle all that down to the first sentence only :)
Svizzara is online now
Old 04-11-2014, 06:23 PM   #14
Burkeboy
Burkeboy's Avatar
Fan#: 141633
What I Drive: 2004 Red SVT
Points 2,548, Level 30
Points: 2,548, Level: 30 Points: 2,548, Level: 30 Points: 2,548, Level: 30
Level Up 66% Completed
FF Reputation: 1 Burkeboy Good Standing Member
Fix it or sell it to someone who will. Please do not let this focus go to waste.
http://www.focusfanatics.com/forum/showthread.php?t=380258
Burkeboy is offline
Old 04-12-2014, 12:50 AM   #15
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,368, Level 75
Points: 13,368, Level: 75 Points: 13,368, Level: 75 Points: 13,368, Level: 75
Level Up 30% Completed
Forum Activity 99%
Read the whole thread guys!
He's GOT a good one now, just worried after seeing all the warnings.
Drive it & don't worry too much, price was right & you may never have an issue while you own it.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-12-2014, 01:20 PM   #16
Mandroid
Mandroid's Avatar
Fan#: 150610
That's what I'm hoping for lol.
Mandroid is offline
Old 04-17-2014, 06:55 PM   #17
rnewscates
Fan#: 97162
What I Drive: 2000 Focus SPI, 1978 Lotus Esprit
FF Reputation: 1 rnewscates Good Standing Member
I got mine cheap (2000 Sedan, 115K) with a missing head and manifolds etc. It turned out to also have a broken #1 piston so it is a good thing I pulled the block and had it on an engine stand. At that point it made sense to go all out, lightly hone the cylinders, new std pistons and rings, new crank seals, new timing belt and idler pulley, new water pump.
I recommend a new head casting from a machinist for about $350. Plus a new head gasket and valves as needed. Do all this and maintain it well and it'll give you years of pleasure. Sure you can take the risk and keep driving, but it could drop a seat at any time. You can't dare take long trips with it, locally would be OK but you never know!
Rebuild it yourself as a project and you will learn a lot, as much as a lot of expensive schooling! Good Luck, Bob Scates Springfield, VA
rnewscates is offline
Old 04-17-2014, 10:14 PM   #18
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
The guy's got 45 THOUSAND miles to go before the mileage when yours broke, I'm not rebuilding my Duratec just because a few with more than twice the mileage have had rod bearings give up. Some go over 200,000 without an issue of each type.
Something else could break first, unless it's a high mileage SPI and you have time/$ to do the head as a preventive it's not worth worrying TOO much about it.
"Rubber Side Down"
Old 04-18-2014, 05:09 PM   #19
Stanley Rockafella
Fan#: 118997
What I Drive: 07 Focus ZX4 SES
Points 479, Level 9
Points: 479, Level: 9 Points: 479, Level: 9 Points: 479, Level: 9
Level Up 58% Completed
FF Reputation: 1 Stanley Rockafella Good Standing Member
On my 97 Escort, I went about 150k miles when I finally sold the car and it STILL never had the issue. Maybe it was luck? or maybe it was my 20k miles OCI oil changes with M1 that held it together? I dunno, but I'm sure glad I don't have that thing in my life anymore!
Stanley Rockafella is offline
Old 04-20-2014, 07:54 AM   #20
billino32
Fan#: 108232
What I Drive: 2003 ford focus se
FF Reputation: 1 billino32 Good Standing Member
worst car ive ever owned
Ive never had in my life a miserable car that constantly needed work and rebuilds..it should be put to rest and laid out to pasture, never buying a ford again because of this.
billino32 is offline
