Ecopia EP422 for svt focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-06-2014, 01:04 PM   #1
dman25
Fan#: 95916
What I Drive: 2000, Red, SVT Lightning
FF Reputation: 1 dman25 Good Standing Member
Is anyone running Bridgestone Ecopia EP422 tires on their SVT? 215/45/17
Im currently running primewell PZ900 and I cant get much more than 20-30k out of a set of tires cause of bad inner wear, so I want to get a tire i can rotate around the care more appropriately.
Anyone running these tires? issues? thoughts?
dman25 is offline
Old 04-06-2014, 03:51 PM   #2
ShadowFocus603
ShadowFocus603's Avatar
Fan#: 118448
What I Drive: 2004 Pitch Black SVT EAP 2Dr #1878
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
FF Reputation: 1 ShadowFocus603 Good Standing Member
If you are getting bad inner wear you might want to check that your toe is in spec. A common misconception is that camber causes tire wear but excessive toe is more often the culprit.
2004 Ford Focus SVT #1878
ShadowFocus603 is offline
Old 04-06-2014, 05:58 PM   #3
dman25
Fan#: 95916
I've taken it in 3 times for alignment at Firestone complete auto care, it hasn't made a difference in my tire life over the last 30k miles. Every time i go in something thing is out of wack.
dman25 is offline
Old 04-07-2014, 12:21 AM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,998, Level 74
Points: 12,998, Level: 74 Points: 12,998, Level: 74 Points: 12,998, Level: 74
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "Wheels & Tires".
zetecDon is offline
Old 04-07-2014, 10:27 AM   #5
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,002, Level 33
Points: 3,002, Level: 33 Points: 3,002, Level: 33 Points: 3,002, Level: 33
Level Up 68% Completed
Forum Activity 8%
Toe can definitely make the problem worse, especially if you have a lot of camber. But I'd also suggest checking out your bearings by spinning them with the brake pads off. My car doesn't make the "usual" bad bearing noises while driving. It's quieter at highway speed than it is while driving slowly and turning doesn't seem to affect it much (though, I believe both rear bearings are bad). I jacked up my car this weekend and my bearings definitely sound shot even though I've been driving on them and ruining tires for 60k miles. lol
Check out my thread in the MK3 section to see if that's what your tires look like:
Summer Tires:
http://www.focusfanatics.com/forum/showthread.php?t=319374
Winter Tires:
http://www.focusfanatics.com/forum/s...=319374&page=3
And windeye on this website had the same problem with weird inner tire wear from bad bearings on her Mazda 3:
http://www.bobistheoilguy.com/forums...73#Post3170273
EDIT: To be honest, I'm not even convinced that my front wheel bearings aren't damaged.
PratoN is offline
Old 04-08-2014, 12:48 AM   #6
dman25
Fan#: 95916
Summer Tires:
Winter Tires:
Ill try that! thanks dude.
dman25 is offline
Old 04-27-2014, 05:51 PM   #7
ribaudoa
Fan#: 141585
What I Drive: 2002 Green ZX5
Points 491, Level 9
Points: 491, Level: 9 Points: 491, Level: 9 Points: 491, Level: 9
Level Up 82% Completed
FF Reputation: 1 ribaudoa Good Standing Member
Primewells...ick. Ecole A's are nice tires, but they are Bridgestone Eco tire. Not a performance tire at all. Go with one of the Potenzas, RE...97 I think that is the directional tire. Very good tire for grip and on wet roads. I test drove a bunch of those including the Ecopia on BMWs.
using FF Mobile
ribaudoa is offline
Old 04-27-2014, 07:03 PM   #8
justalilslow
Fan#: 59266
What I Drive: 05 gutted hatch
Points 950, Level 16
Points: 950, Level: 16 Points: 950, Level: 16 Points: 950, Level: 16
FF Reputation: 3 justalilslow Good Standing Member
Skip the ecopia line and look into the turanza line up. Better all around all season that has much less side wall flex and more grip.
The 97 is decent at first but I hate that its directional. Begins to cup badly after a few thousand and theirs nothing you can do to stop it. So looking into a asymmetrical tire is better so you can rotate it around to prevent that.
Try change your rear alignment to -.04 and 33-35 psi should give it a very smooth even wear. Every one will tell you zero toe for the rear is better but I found I tend to eat up the outsides a little bit faster.
05 gutted hatch
M88A1 recovery vehicle
justalilslow is offline
Old 04-27-2014, 10:48 PM   #9
ribaudoa
Fan#: 141585
Points 491, Level 9
I do agree with the directional tire "debate". I purchase symmetrical tires as well. I have a set of Hydro Edges and they are cupped...loud and annoying. But when I tested those tires, they gripped really well, specially on a wet road. Ecopia did the worse, 970s then the 97, than...The others, I can't remember what they were. But that was taking corners at high speed. Power sliding threw corners...goodtimes.
using FF Mobile
ribaudoa is offline
