205/50r16 tires hate these tires need different - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-05-2014, 09:58 PM   #1
eeyoresusieq
Fan#: 153970
What I Drive: 2004 red zx3
Points 104, Level 2
Points: 104, Level: 2 Points: 104, Level: 2 Points: 104, Level: 2
Level Up 8% Completed
FF Reputation: 1 eeyoresusieq Good Standing Member
Please help me I have put 2 sets tires on this car n they were out too quickly and are horrible in snow. Can I get snow tires for this car or do I need to buy 15 inch rims so I can buy normal tires that are not so expensive
eeyoresusieq is offline
Old 04-06-2014, 02:45 AM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,150, Level 74
Points: 13,150, Level: 74 Points: 13,150, Level: 74 Points: 13,150, Level: 74
Level Up 75% Completed
Forum Activity 29%
Activity: 29% Activity: 29% Activity: 29%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "Wheels & Tires".
zetecDon is offline
Old 04-06-2014, 07:43 AM   #3
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,226, Level 87
Points: 19,226, Level: 87 Points: 19,226, Level: 87 Points: 19,226, Level: 87
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 9%
FF Reputation: 7 badazz2010focus Good Standing Member
blizzaks on a set of steelies or you're stockers.
badazz2010focus is online now
Old 04-06-2014, 09:02 AM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,371, Level 75
Points: 13,371, Level: 75 Points: 13,371, Level: 75 Points: 13,371, Level: 75
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 99%
15's work on your model, any stock Focus wheel (thru 2011) fits.
Blizzaks are great Snows, one of the faster wearing types.
Alignment & decent tires helps make them last, you didn't mention what you were using/how they wore/how long they lasted so there's not much to go on here.
Welcome to FF!.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-06-2014, 09:27 AM   #5
badazz2010focus
Fan#: 78166
Forum Activity 9%
such has toe and caster/camber etc etc
Old 04-06-2014, 10:11 AM   #6
david in germany
Fan#: 146770
What I Drive: 2005 red zx3
Points 152, Level 3
Points: 152, Level: 3 Points: 152, Level: 3 Points: 152, Level: 3
Level Up 4% Completed
FF Reputation: 3 david in germany Good Standing Member
If you are not an aggressive driver you can look for a tire with a higher tread wear rating. Higher tread wear is a bit harder rubber and you give up a bit of traction. You did not specify what you have been running so it is hard to recommend a better tire than what you presently have. I second the Blizzaks for winter though. People tend to skimp on winter tires without thinking about the consequences. Personally depending on the weather, I run winters 6.5 to 7 months of the year here in Germany. I will run the best tire I can afford/find for both seasons.
david in germany is offline
Old 04-09-2014, 01:57 PM   #7
eeyoresusieq
Fan#: 153970
Points 104, Level 2
I have tires from Walmart goodyears I think supposed to be guaranteed to 50,000. I made them replace the first set of 2 because they wore out at 20,000. Now the second set is wearing out. I think I will get a different set of rims so that I don't have to buy the flat tread performance tires - I hate them. I will buy some snow tires. I live in the country and they do nothing to the roads. Are the Blizztaks expensive. I had new cams? not sure name spelling put on the rear so the alignment guy could properly align the car. Cost me about 450 dollars. Of course here in the country its hard to keep a car in alignment. I just want to be able to put tires on it that will grip the road in snow. The performance tires are only good in light snow. I also hate the aluminum rims they get bent to easily when tires are changed. So can I get steel 15" rims for this car and buy better tires. The performance tires are also expensive. Usually cost me $130 total each put on.
Old 04-09-2014, 03:05 PM   #8
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
FF Reputation: 3 jasonbi Good Standing Member
you bought your tires at walmart....what did you expect?
#3286 OF 4788
jasonbi is offline
Old 04-09-2014, 03:16 PM   #9
david in germany
Fan#: 146770
Points 152, Level 3
I disagree with you about light metal wheels. I have bent steel wheels much easier than alloys. The only advantage with steel wheels is that they are easier to straiten after they bend.
