Grill Modification - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-03-2014, 09:47 PM   #1
lacole725
lacole725's Avatar
Fan#: 85112
What I Drive: 2010 Ingot Silver Focus SE Sedan
Points 3,259, Level 35
Points: 3,259, Level: 35 Points: 3,259, Level: 35 Points: 3,259, Level: 35
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 3 lacole725 Good Standing Member
Grill Modification
So I have a chrome grille on my '10 SE. I want to do the badge removal and match it to the body color of the car. Can I paint or do anything to this grill, or does it have to be a black or unpainted one? Just not sure if it will stick the chrome looking finish. Also wondering if anyone has done a write up on how to do the badge modification. I found a couple posts saying how time consuming and frustrating it could be and I also found a user that did the mod to his gf's car and was considering doing them for other members, but that thread was from 2012. I'm waiting on a message back from him. In the meantime, any ideas?
Adam
lacole725 is offline
Old 04-03-2014, 10:06 PM   #2
Burkeboy
Burkeboy's Avatar
Fan#: 141633
What I Drive: 2004 Red SVT
Points 2,548, Level 30
Points: 2,548, Level: 30 Points: 2,548, Level: 30 Points: 2,548, Level: 30
Level Up 66% Completed
FF Reputation: 1 Burkeboy Good Standing Member
If you debadged the grill wouldn't that leave a big oval?
And why debadge I would wear the blue oval with pride, at least it ain't no bow tie
Burkeboy is online now
Old 04-03-2014, 10:18 PM   #3
lacole725
lacole725's Avatar
Fan#: 85112
Forum Activity 2%
No, you cut out the oval so it is just two solid bars across the grill. I just like the clean look. Some members have fiberglassed it, others have used bondo.
Adam
Old 04-03-2014, 11:17 PM   #4
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,129, Level 27
Points: 2,129, Level: 27 Points: 2,129, Level: 27 Points: 2,129, Level: 27
Level Up 86% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
I would want this if I had a MK2, looks so clean.
My idea was if you could cut the oval out and then take a second donor grill to plasticweld smooth sections to the other grill. Then smooth the cut lines with filler as opposed to it being made out of bondo or glass.
Sniper Focus is offline
Old 04-03-2014, 11:22 PM   #5
lacole725
lacole725's Avatar
Fan#: 85112
Forum Activity 2%
That is a good idea, but I don't know if it would be entirely cost effective. I do know someone with a plastic welder. My plan was to grind it down with a dremel as smooth as possible and bondo it and then paint.
Do you know anything about the chrome finish on the grille? Will it accept any type of work or can it be stripped or what? Not terribly knowledgeable with body work type stuff, the most I've done was filling rusted out fender arches on my first truck with fiberglass.
Adam
Old 04-03-2014, 11:55 PM   #6
Sniper Focus
Fan#: 84221
Forum Activity 20%
I don't know a ton about body work, but you can paint chrome plastic if you scratch it up with 400 grit (or so) and then primer. I painted my chrome lights and they're holding up great.
Harbor Freight has a plastic welder for $10 its basically an over powered soldering iron used to repair bumpers. For "small" projects like this you could use a soldering iron with a flat tip. There are hot-air plastic welders and I think that would be too much for a grill also.
In my case the local cheapo junkyard would charge no more than $20 for a grill and it's a quick shot down the highway. I know most people don't have this "privilege", but if you keep your eyes open you might find one for the right price.
Old 04-03-2014, 11:59 PM   #7
lacole725
lacole725's Avatar
Fan#: 85112
Forum Activity 2%
I don't think the black grill is too expensive brand new to begin with and I could find a cheap one at the junk yard. I'll have to look at my grill and see what I can do.
Adam
Old 04-04-2014, 12:31 AM   #8
tuvok
tuvok's Avatar
Fan#: 102442
What I Drive: 2010,Grey,SES
FF Reputation: 2 tuvok Good Standing Member
im looking for a cheep grill to Mod aswell , though im not thinking badge Delete , I wanna take a whole different approach , but I really don't want to mod the grill that's on my car now , id rather slap my modified grill on after it is completed. man I really need to make a trip to the bone yard !
PSN : T_u_V_o_K add me , Call of duty MW3 , Madden 13 SEDAN REVOLUTION # 242
tuvok is offline
Old 04-04-2014, 07:15 AM   #9
Burkeboy
Burkeboy's Avatar
Fan#: 141633
There is a junkyard just about 20-30 min north of Oneida up in KY that would sell the grill (if they had it) for probably less then $5-10, and probably less. I went to pull-a-part and bought like $45 worth then went here and got the same stuff and more for maybe $20.
Old 04-04-2014, 10:58 AM   #10
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
The chrome grill is paintable. I sanded mine a bit, primed it, and painted it body colored (: I like the Oval being there though as I have auto bot overlays and my center caps are autobot and when my third brake light lights up it says "autobot" (:
Galatians 6:14
crice8 is offline
