Possible front brake issue........? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-02-2014, 02:21 PM   #1
focusETSzx4
Fan#: 120097
What I Drive: 2005 zx4 & 2012 se
Points 413, Level 8
Points: 413, Level: 8 Points: 413, Level: 8 Points: 413, Level: 8
Level Up 26% Completed
FF Reputation: 1 focusETSzx4 Good Standing Member
Hey guys!
So I just put new pads on my car Monday and had my rotors machined down. Probably has no relevance to my situation since I had the same problem before I replaced my pads.
But... I have noticed that since I bought the car I hear this knocking sound when I put my car in reverse and hit the brake pedal. Part of me is thinking possibly a brake pad is loose or someone else suggested possibly a motor mount. It only does it when my car is in reverse however, any other gear And everything sounds fine on it. Help! lol
focusETSzx4 is offline
Old 04-02-2014, 02:27 PM   #2
onlycodered
onlycodered's Avatar
Fan#: 149570
What I Drive: '09 Vista Blue SES coupe 5spd
Points 776, Level 14
Points: 776, Level: 14 Points: 776, Level: 14 Points: 776, Level: 14
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 14%
FF Reputation: 4 onlycodered Good Standing Member
On the topic of the motor mount, how many miles are on your car and have the motor mounts ever previously been replaced?
onlycodered is online now
Old 04-02-2014, 02:36 PM   #3
focusETSzx4
Fan#: 120097
Points 413, Level 8
I have about 108,000 on it now. I'm a second owner so I'm pretty sure the motor mounts have never been changed... Although the car was well maintained so it's a possibly but not entirely too sure
Old 04-02-2014, 02:52 PM   #4
onlycodered
Fan#: 149570
Forum Activity 14%
I would definitely get at least the passenger side motor mount replaced then. They're known to go bad at around 50k. I have 54k on my 2009 and I'm already noticing excess vibration.
Old 04-02-2014, 04:04 PM   #5
ManiacalZX3
ManiacalZX3's Avatar
Fan#: 6111
What I Drive: 2001 White ZX3
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
FF Reputation: 1 ManiacalZX3 Good Standing Member
A good way to check the mounts is put your car in gear then hold brake and hit the gas. Not hard enough to make the car move, just hard enough to stress the powertrain and make it rock back and forth. Then try Reverse. If it makes that noise in drive or reverse you wanna look at mounts. This happened on my passenger mount.
Otherwise, you could have a friend try to make the noise driving the car and you could stand outside and try to listen for the sound and follow it to its source. Just don't crawl under the car with it in gear.
ManiacalZX3 is offline
Old 04-02-2014, 04:38 PM   #6
focusETSzx4
Fan#: 120097
Points 413, Level 8
I will try that thanks.
Old 04-02-2014, 05:05 PM   #7
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
alot of cars have a mild clunk in reverse as the pads re-seat from the change in direction. If you're concerned about it, double-check that the pad retainer clips are properly installed, and check that the caliper hardware is secure (some folks overtorque the guide pin and strip the knuckle threads).
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 04-11-2014, 12:50 PM   #8
focusETSzx4
Fan#: 120097
Points 413, Level 8
Well I took my wheel off today after work to investigate. As far as I can tell, everything is seated properly, retainer clip is on properly. I noticed Ford uses almost a floating design on these types of cars, which kind of makes it a pain in the ass to diagnose a problem.
Before, when I first got the car, it would make a clink sound, when in reverse... sounded like the pads were knocking the rotor really hard or something. I just recently changed hardware and my front pads and had my rotors machined down. Now I get a THUMP when I apply my brakes at low speed.
I searched on google and found that this is a common problem with Infinities. However, my ford didn't do it until I had my brakes done. It's pissing me off ><
Old 04-11-2014, 02:26 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,457, Level 75
Points: 13,457, Level: 75 Points: 13,457, Level: 75 Points: 13,457, Level: 75
Level Up 52% Completed
Forum Activity 99%
If the noise is from the front, might look close at the pad to holder fit. That's what limits the pad's movement front to rear - caliper isn't involved in that.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 04-11-2014, 02:33 PM   #10
boardliquid01
boardliquid01's Avatar
Fan#: 114884
What I Drive: 2003 Silver Ford Focus SVT EAP
Points 573, Level 11
Points: 573, Level: 11 Points: 573, Level: 11 Points: 573, Level: 11
Level Up 46% Completed
FF Reputation: 2 boardliquid01 Good Standing Member
Does the knock continue in reverse almost like its rotational? Or while reversing can you induce the noise with every press of the brakes?
If so I'm betting you have drum rear brakes and the star adjuster in the drums is frozen. The adjustment rod is skipping over the start adjuster causing a clicking/ clunking noise.
But if you're 100% percent certain it's coming from the front, when you did the front brakes did you verify all the slide pins moved freely?
boardliquid01 is offline
