Plasti Dip Removal - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-01-2014, 01:12 PM   #11
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
The best part about dip is it works great if you just keep layering it on. Of course if you did a bad spray job, any texture you had on the wheel will show through unless you go back after you're finished and fix it up.
https://www.youtube.com/watch?v=4T0jEvxxTzE
Here's how DipYourCar did it.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 04-01-2014, 02:37 PM   #12
ThaKillerKlown
ThaKillerKlown's Avatar
Fan#: 73791
What I Drive: '11 SES Sedan
Points 317, Level 6
Points: 317, Level: 6 Points: 317, Level: 6 Points: 317, Level: 6
Level Up 34% Completed
Forum Activity 7%
FF Reputation: 1 ThaKillerKlown Good Standing Member
I am peeling plasti-dip off the trunk and wing on my SES, the dip on the trunk came right off however I guess I put it on the wing a little thin and then it sun backed so it is SLOW go removing it. Does the WD-40/De-Solv-It method work?
<---------- See pic.
ThaKillerKlown is offline
Old 04-01-2014, 02:40 PM   #13
Miztaken1312
Fan#: 74993
I'd be weary of using WD-40 on any painted surface of my car. I've heard it works, but I would not leave it on the paint any longer then you have to.
Old 04-01-2014, 03:06 PM   #14
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
It took me hours and days to remove plastidip from mine the first time I did them... The more layers the easier it is to remove. And I mean thick layers.
Galatians 6:14
crice8 is offline
Old 04-01-2014, 03:09 PM   #15
crice8
crice8's Avatar
Fan#: 84830
I used wd40 at one point on my wheels to help break down the plastidip. and It does help it dissolve some but not completely. Still takes hours and lots of elbow grease with a scotch pad or something similar. And the wd40 actually caused some of the original paint on my wheels to come off so I ended up just platidipping them again at the time... Then last year I decided to go all out and spent a few days removing the plastidip as good as I could before painting them with wheel paint, which turned out really good(=
Galatians 6:14
crice8 is offline
Old 04-02-2014, 01:37 AM   #16
arjay219
arjay219's Avatar
Fan#: 98685
What I Drive: 2010 Black SES
Points 1,027, Level 17
Points: 1,027, Level: 17 Points: 1,027, Level: 17 Points: 1,027, Level: 17
Level Up 27% Completed
FF Reputation: 2 arjay219 Good Standing Member
The de-Solv-it worked really well! Sprayed heavy coats and let it sit for like 10-15 minutes and then spray! Most of it comes right off and then you can just pull off any left overs! Saw this on a wrx wheel vid. So back to stock wheel color for now. doesn't hurt original paint
FoFo in CoMo!!!
arjay219 is offline
Old 04-02-2014, 09:12 AM   #17
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 14 mac.mogul Great Standing Member
This thread = reason number 230948203458 why you shouldn't use plasti-dip.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 04-02-2014, 09:14 AM   #18
onlycodered
onlycodered's Avatar
Fan#: 149570
What I Drive: '09 Vista Blue SES coupe 5spd
Points 720, Level 14
Points: 720, Level: 14 Points: 720, Level: 14 Points: 720, Level: 14
Level Up 20% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 4 onlycodered Good Standing Member
Still easier to remove than paint.
onlycodered is online now
Old 04-02-2014, 09:15 AM   #19
Miztaken1312
Fan#: 74993
If done right Mac, it's not problem to remove. Everyone thinks it's like spray paint but it's not. A single coat with some touch up won't work.
Old 04-02-2014, 09:18 AM   #20
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Forum Activity 9%
If you paint something right to begin with, you won't need to remove it. Problem solved.
