My 2010 coupe is finally lowered and flushed. about time. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-25-2014, 01:51 AM   #1
anwi1179
anwi1179's Avatar
Fan#: 72587
What I Drive: 2010, black, focus se coupe
Points 1,585, Level 22
Points: 1,585, Level: 22 Points: 1,585, Level: 22 Points: 1,585, Level: 22
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 2 anwi1179 Good Standing Member
Hows it look?! Now im looking for dampers to compliment my eibach springs. Any suggestions?
anwi1179 is offline
Old 03-25-2014, 02:54 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,391, Level 75
Points: 13,391, Level: 75 Points: 13,391, Level: 75 Points: 13,391, Level: 75
Level Up 36% Completed
Forum Activity 99%
Moved it to the showroom for comments on the looks, now you've got "build thread" here you can add to.
If you don't get comments on the shocks/struts, post that question in the Brakes, suspension & Chassis section.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 03-25-2014, 03:17 AM   #3
br0cus
br0cus's Avatar
Fan#: 127098
What I Drive: 2000 Black ZTS
Points 839, Level 15
Points: 839, Level: 15 Points: 839, Level: 15 Points: 839, Level: 15
Level Up 39% Completed
FF Reputation: 2 br0cus Good Standing Member
Nice drop ! Low enough to eliminate wheel gap but still drive able.
S L O T H
br0cus is offline
Old 03-25-2014, 05:40 AM   #4
wv rider
wv rider's Avatar
Fan#: 125497
What I Drive: 2010 grey s
Points 1,303, Level 20
Points: 1,303, Level: 20 Points: 1,303, Level: 20 Points: 1,303, Level: 20
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 6%
FF Reputation: 1 wv rider Good Standing Member
Bilstein B8's
The Focus formerly known as Gandalfthegreyfocus
wv rider is offline
Old 03-25-2014, 06:45 AM   #5
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,226, Level 87
Points: 19,226, Level: 87 Points: 19,226, Level: 87 Points: 19,226, Level: 87
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 9%
FF Reputation: 7 badazz2010focus Good Standing Member
there aren't many suspension options availabile for 2 g's if you want get the massive omni kit........hell I'll even sell you mine if i can find it LOL. We just moved and everythimg just shuffled around, what did you use for spacers?
badazz2010focus is offline
Old 03-25-2014, 07:11 AM   #6
anwi1179
anwi1179's Avatar
Fan#: 72587
I used h&r spacers. 15mm up front 20mm out back.. the stance is perfect but on stock dampers the tires rub on every dip and lot enterance. So im desperately ISO of stiffer dampers. If no luck ill have to swap the eibach springs for an entire adjustable coil over set. 1K easy... without install fees.
anwi1179 is offline
Old 03-25-2014, 09:06 AM   #7
onlycodered
onlycodered's Avatar
Fan#: 149570
What I Drive: '09 Vista Blue SES coupe 5spd
Points 775, Level 14
Points: 775, Level: 14 Points: 775, Level: 14 Points: 775, Level: 14
Level Up 75% Completed
Forum Activity 12%
FF Reputation: 4 onlycodered Good Standing Member
Are your front or rear tires rubbing? Or both? I'm wondering if I can get away with just spacers on my car with Pro-Kit springs but I want to make sure I don't rub at all because it's my daily driver.
onlycodered is online now
Old 03-25-2014, 09:06 AM   #8
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,893, Level 59
Points: 7,893, Level: 59 Points: 7,893, Level: 59 Points: 7,893, Level: 59
Level Up 72% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Time to roll and maybe pull the fenders a bit. Also look at modifying your fender liners, this all depends where exactly and what you are rubbing at. You can get some blue painters tape on the fenders/liners and then see where its rubbed off to find out for sure.
Running a little more negative camber can also help with the rubbing.
The shocks will depend on your budget, top of the line adjustable will be Koni yellows...nothing but great reviews on those
rambleon84 is offline
Old 03-25-2014, 09:11 AM   #9
H82BEU
H82BEU's Avatar
Fan#: 29198
What I Drive: 2009 Focus SES
Points 2,528, Level 30
Points: 2,528, Level: 30 Points: 2,528, Level: 30 Points: 2,528, Level: 30
Level Up 52% Completed
Forum Activity 4%
FF Reputation: 1 H82BEU Good Standing Member
Originally Posted by wv rider View Post
Bilstein B8's
That is about all there is unless you want to go coilovers. I went with coilovers because there were a few more choices. Don't get the omni kit is junk and a waste of money. The car looks like it is coming along!
2009 Focus SES Coupe
H82BEU is offline
Old 03-25-2014, 12:07 PM   #10
anwi1179
anwi1179's Avatar
Fan#: 72587
Well I have the more aggressive eibach sport line springs . They ride a bit Lower than yours. If you wanna go flush like this Id recommend you install the spacers that I bought 15mm and 20mm. If your still riding on stock dampers , prepare for A WHOLE lot of tire rub. Haha
Oh and to anwser your other question ALL 4 wheels rub. Yep..
anwi1179 is offline
