Eibach Sportline (4.13435) doesn't fit 2014 sedan? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-24-2014, 12:59 PM   #1
Yadda
Yadda's Avatar
Fan#: 134881
What I Drive: 2014 Tuxedo Black sedan
FF Reputation: 1 Yadda Good Standing Member
Well, this is annoying. TireRack says they fit, Amazon says they fit but when I took them to get installed they told me they don't fit. The rears fit fine, but the fronts didn't fit. The tech mentioned he called Eibach and they said they don't have a set of springs for the '14 Sedan yet.
Has anyone had any luck installing these or any other form of lowering springs/coils on their 14 sedan?
Yadda is offline
Old 03-24-2014, 01:06 PM   #2
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 14 mac.mogul Great Standing Member
There may have been a change in the front struts/spring design. They did this on the 07-08 models where the rears are the same but a small change in the strut design for 08 changed the spring compatibility. It might be as simple as picking up some 12-13 struts.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is online now
Old 03-24-2014, 01:10 PM   #3
Yadda
Yadda's Avatar
Fan#: 134881
At that point, I would just return the springs and buy coilovers but I'm not even sure if the fitment guides are accurate now. Iv seen that people have successfully installed them on the HB and earlier mk3 sedans but no 14 sedans now that I'm looking. I hate to be that guy who brings his stuff to a garage only to find out it doesn't fit once they pull it apart.
Yadda is offline
Old 03-24-2014, 02:59 PM   #4
Yadda
Yadda's Avatar
Fan#: 134881
I'm not making a new thread just to pose a new question.
I knew I would have to buy new shocks/struts to match with my springs but I wasn't expecting it so early. Buying OE struts just to fit the springs is counter productive since the springs will destroy them eventually. The price of buying everything up front is really close to the price of coilovers which is vastly superior.
If I bought coilovers what else would I need to buy to fix any alignment issues? Also, what's the point of sway bars and are they necessary? I'm aiming mostly for looks but I don't want to do it at the cost of ride quality.
Yadda is offline
Old 03-24-2014, 03:27 PM   #5
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Forum Activity 9%
Personally, if this was me, I would see if I could return the springs and buy this instead.
LINK
The full kit will ensure that everything fits and you'll get the added performance balance of replacing all the important pieces.
Old 03-24-2014, 03:39 PM   #6
Yadda
Yadda's Avatar
Fan#: 134881
LINK
That's a good alternative I hadn't considered. I ignored it mostly because I wanted to get the Koni shock/strut system but now that I'm being charged $200 labor I don't really have a choice. It'll come out about even in the end. :\ Kind of upset about that, but I can't really dispute it seeing as how I brought them something that didn't fit.
Yadda is offline
Old 03-24-2014, 04:58 PM   #7
Yadda
Yadda's Avatar
Fan#: 134881
Before I order this, is there any reason at all it won't fit? I don't trust fitment anymore. With springs, I can understand since they kind of depend on the struts/shocks to line up right. But is there any reason at all shocks/struts won't fit properly? I don't want to end up paying ANOTHER 200 bucks on something that doesn't fit.
Cuz I'm totally about to do it. Begrudgingly.
Yadda is offline
Old 03-24-2014, 05:09 PM   #8
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Forum Activity 9%
I would call tirerack and verify the kit comes with all mounting hardware or if there's anything you'll need to acquire. I don't see upper strut mounts in the photo, but its just an approximate and not the actual product. They may have designed it to reuse stock hardware and that may not work for you if the 2014 is different.
At any rate, it is best to call and find out first.
Also, I would recommend making an effort to install it yourself. Find a local buddy who's got some tools and a workspace, rent a spring compressor for the struts, and take care of it. I just replaced my suspension this weekend and it took me less than 3 hours for the whole shebang.
I understand if you absolutely can't do it, but suspension is so easy. It is just nuts and bolts and doing it yourself will save so much money...
Good luck.
Old 03-24-2014, 05:25 PM   #9
Yadda
Yadda's Avatar
Fan#: 134881
Good luck.
You are just full of great ideas. I'll likely do that, I have a buddy who could help but he said he was very busy and itd take a while to make time for me. Seeing as how I just ponied up 200 bucks for an install that never happened I think I'm going to take this route to recoup my losses. I just got off of the phone with TireRack and the guy was confused why his parts sheet states that the springs I ordered are incompatible while the website says it is. He sent an email to someone and said he would get back to me in the morn about the compatibility of the entire kit. But as it stands, from TireRack, Eibach and the technician who worked on my car, the spring set alone is incompatible with the 2014 Sedan SE.
Yadda is offline
Old 03-24-2014, 06:16 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,786, Level 73
Points: 12,786, Level: 73 Points: 12,786, Level: 73 Points: 12,786, Level: 73
Level Up 84% Completed
Forum Activity 99%
It'd be useful to know where the problem was with the front springs, whether at the top or the bottom.
Spring change on earlier models was a major reduction in the size of the top, if that was the case with yours, the top mounting is the issue instead of the struts.
To answer an earlier question, sway bars control a car's lean when turning. The combination of sizes front to rear affects the handling of the car regarding oversteer or understeer. ST is the only stock version with a touch of oversteer BTW. Using none on a FWD car would result in more lean & understeer (Plows in a turn, wants to go straight).
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
