Broken MAF Sensor Housing, How to Fix??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-22-2014, 08:00 AM   #1
shengsri
shengsri's Avatar
Fan#: 118280
What I Drive: Ford Focus 2012: White Hatchback
Points 391, Level 7
Points: 391, Level: 7 Points: 391, Level: 7 Points: 391, Level: 7
Level Up 82% Completed
FF Reputation: 2 shengsri Good Standing Member
Hi, I've had the K&N Typhoon CAI installed. sadly i over tightened the filter and the housing cracked. Now when every i drive the car the filter always falls off. Does anyone know a way to fix this problem??? I'll eventually replace the housing, but i need something that will stop the filter from falling out for now. I've tried taping the part that cracked, but it just made it worse. If anyone knows how to fix this problem please let me know. Thank You!!
shengsri is offline
Old 03-22-2014, 08:24 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,374, Level 75
Points: 13,374, Level: 75 Points: 13,374, Level: 75 Points: 13,374, Level: 75
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 99%
Temp. Fix
Measure the inside of that tubing (fully expanded), then run around the house & garage looking for anything that size.
Plastic pipe, tin can, anything you can cut up to make a "sleeve" that'll fit inside to support the cracked plastic.
Tighten down the filter enough so it doesn't fall off & everything will stay in place.
If I couldn't find anything to fit, a solution would be a piece of aluminum strap bent into the appropriate circle. Just butt the ends together, so it would need to be thick enough not to easily overlap.
McGuyver whatever you can find into that circular size & it'll work.
Luck!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 03-22-2014, 08:27 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
BTW - the idea isn't totally original, some motorcycles with similar clamp-on filters use an internal ring for this problem from the factory. As I was thinking of options & describing the "fix", remembered seeing it before.
"Rubber Side Down"
Old 03-22-2014, 10:05 AM   #4
shengsri
shengsri's Avatar
Fan#: 118280
Points 391, Level 7
Originally Posted by sailor View Post
Temp. Fix
Luck!
thank you for the advice. Just after i finished posting this i found some metal wires that were bent to support some aftermarket wheel caps that i took off the wheels. They were exactly the same size, but there were able to retract when you squeeze the outside. so i taped 3 of them together and then squeezed them into the hole and made what you suggested. now its real sturdy, and i taped them to the housing itself to prevent them from moving. it was lucky i didn't throw those away!! LOL
shengsri is offline
Old 03-22-2014, 10:18 AM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Great Minds think alike?
It's not trash anymore when you can make a part you need out of it. Odd scraps & extra parts save the day many a time.
My Clutch return spring is an odd drum brake spring that just happened to be the perfect size & strength.
Glad it worked out for you.
"Rubber Side Down"
Old 03-22-2014, 10:39 AM   #6
shengsri
shengsri's Avatar
Fan#: 118280
Points 391, Level 7
yeah, scraps in my car have saved me from roadside incident many times. after facing this problem for the last few weeks i was already thinking the same thing, but couldn't find anything that fits in there until i found these. now i just need to find a way to make it stick permanent without using tape. any ideas???
shengsri is offline
Old 03-22-2014, 12:23 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Thought of an Epoxy I like - PC-7 - that mixes up thick & sticky, works on many plastics. And other possibilities like Hot Glue. Any of those you'd have to test a drop on a hidden spot to see if it sticks...
Some fine copper wire would work well to tie them into place with small holes drilled to the inside of where those notches are. Only need to drill on one side then, wire around & twisted tight inside the tube. Filter covers further than those so it wouldn't leak.
Couple possibilities there.
"Rubber Side Down"
Old 03-22-2014, 06:10 PM   #8
shengsri
shengsri's Avatar
Fan#: 118280
Points 391, Level 7
thank you for the advice!! i'll try some epoxy, a lot of people that i've asked around suggested the same thing. i'll let you know how it works out.
shengsri is offline
Old 03-23-2014, 12:31 AM   #9
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
A new housing is only $5
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 03-23-2014, 12:40 AM   #10
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,237, Level 67
Points: 10,237, Level: 67 Points: 10,237, Level: 67 Points: 10,237, Level: 67
Level Up 47% Completed
Forum Activity 30%
FF Reputation: 26 suss6052 Great Standing Member
Note the O.P. is in Thailand, so this may not be applicable, depending on local exchange rates and the prices of parts from their local Ford Dealer v.s. ordering and importing the part from the U.S.
suss6052 is online now
