Tires humming at highway speed - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-21-2014, 08:39 PM   #1
Matt89
Fan#: 97715
What I Drive: 2008 Metallic Blue Ford Focus SES
Points 1,160, Level 18
Points: 1,160, Level: 18 Points: 1,160, Level: 18 Points: 1,160, Level: 18
Level Up 60% Completed
Forum Activity 6%
FF Reputation: 1 Matt89 Good Standing Member
Atleast I think it is the tires making the faint humming sound.
It starts once I hit about 103km/h but it stops once I get to 109km/h. What gives??
It's an 08 Focus with 115k km
Matt89 is offline
Old 03-21-2014, 10:11 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,412, Level 75
Points: 13,412, Level: 75 Points: 13,412, Level: 75 Points: 13,412, Level: 75
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 99%
Moved to Wheels & Tires.
Speed dependent like that, it might be related to balance.
That's a common speed range for a balance issue to show up, hitting a "harmonic" at a certain speed is the key to my guess.
Luck
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 03-21-2014, 11:07 PM   #3
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,117, Level 34
Points: 3,117, Level: 34 Points: 3,117, Level: 34 Points: 3,117, Level: 34
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 4%
FF Reputation: 9 emsvitil Good Standing Member
Always the same road or different roads?
If it's always the same road, it could be a harmonic with the tread blocks and the roughness of that particular road.
Ed
emsvitil is online now
Old 03-21-2014, 11:26 PM   #4
onlycodered
onlycodered's Avatar
Fan#: 149570
What I Drive: '09 Vista Blue SES coupe 5spd
Points 776, Level 14
Points: 776, Level: 14 Points: 776, Level: 14 Points: 776, Level: 14
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 14%
FF Reputation: 4 onlycodered Good Standing Member
The 2008 Focus had issues with rear camber which led to the inside of the tires being worn more quickly. You probably have uneven wear that's causing noise. Take one of the rear wheels off and see if the wear is uneven. If it is do a tire rotation and you should be good.
I had the exact same problem with an old Civic of mine. The rear had too much negative camber and I had a humming noise. Turned out to just be the tires.
onlycodered is offline
Old 03-22-2014, 12:14 AM   #5
Matt89
Fan#: 97715
Forum Activity 6%
It happens on different roads. I'm pretty sure it's the balance (alignment?) and/or tire wear as well (pulls slightly to the left). I'm taking it in for a service after the weekend, I'll let you guys know how it went.
Matt89 is offline
Old 03-22-2014, 12:32 AM   #6
goingtoscotland
goingtoscotland's Avatar
Fan#: 132001
What I Drive: '14 Tuxedo Black HB, 05 Kawi ZX-10R
Points 1,954, Level 26
Points: 1,954, Level: 26 Points: 1,954, Level: 26 Points: 1,954, Level: 26
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 6 goingtoscotland Good Standing Member
Most likely tire wear if there is no real perceptible vibration,
Dawkins....Dennett....Harris....Hitchens
Hatch Nation #46
goingtoscotland is offline
Old 03-26-2014, 08:56 AM   #7
onlycodered
Fan#: 149570
Forum Activity 14%
Any news?
Old 03-26-2014, 09:38 AM   #8
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,765, Level 24
Points: 1,765, Level: 24 Points: 1,765, Level: 24 Points: 1,765, Level: 24
Level Up 65% Completed
Forum Activity 3%
FF Reputation: 5 Miller88 Good Standing Member
Do you have the original Hankook Optimo tires?
Mine got very loud when they wore.
My 2011 also has visible negative rear camber.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 03-26-2014, 04:57 PM   #9
rexazz2
rexazz2's Avatar
Fan#: 121761
What I Drive: 2014 HB SE
Points 1,928, Level 26
Points: 1,928, Level: 26 Points: 1,928, Level: 26 Points: 1,928, Level: 26
Level Up 28% Completed
Forum Activity 12%
FF Reputation: 1 rexazz2 Good Standing Member
here is what I am running on my SUV
You don't know tire noise LOL
rexazz2 is offline
