Mpg vs. Outside temp - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-21-2014, 11:49 AM   #1
boombots
boombots's Avatar
Fan#: 130266
What I Drive: 2012 Focus Titanium Hatch
Points 879, Level 15
Points: 879, Level: 15 Points: 879, Level: 15 Points: 879, Level: 15
Level Up 79% Completed
Forum Activity 3%
FF Reputation: 1 boombots Good Standing Member
Now I don't have any hard data but just watching my instant mpg screen (which is ALWAYS accurate within .5mpg)I notice much better mileage with air temps in the 70s than when it's 30... When its cold with cruise on 70mph I can't pull over 31. Same speed when its warm gets me 35...
It's the same drive and same station (shell 93 octane)
Thoughts?
2012 Titanium Hatch- Yellow Blaze Tri-Coat
Mods: K&N Typhoon, ST exhaust, SCT tune by Tom
-Vince
boombots is online now
Old 03-21-2014, 12:07 PM   #2
Etch.
Fan#: 116485
What I Drive: Not a Focus anymore. Good riddance!
Points 941, Level 16
Points: 941, Level: 16 Points: 941, Level: 16 Points: 941, Level: 16
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 0 Etch. Newbie
That's about right. A couple things work against you in the cold months. 1) winter vs summer fuel. Winter blend is more stable in cold weather, but also a bit less energy. Gasoline isn't quite as distinct as say diesel between summer and winter blends, but there is a bit of a difference. and 2) warm up times. just because your coolant temp gets to normal doesn't mean the rest of the engine is running at it's full soaked temp. Almost any engine uses significantly more fuel until it is fully warmed up, so even though you may do moderate driving, just the full warming up period will pull your overall average for the leg down quite a bit.
Another thing to keep in mind is as cars get more efficient, you will see bigger swings with that sort of stuff. Nothing is really different in that respect then other cars if you look at it percentage wise. Say for example that stuff makes a 10% difference in overall fuel economy. On a pickup or older car that maybe gets 20MPG average, means a 2mpg difference. Same percentage on a newer more efficient 40mpg car means a 4mpg difference. Your much more likely to notice 4MPG then 2MPG, but really the difference is the same.
Etch. is offline
Old 03-21-2014, 12:08 PM   #3
Billacuda
Billacuda's Avatar
Fan#: 114361
What I Drive: 2013 Titanium Hatchback
Points 185, Level 3
Points: 185, Level: 3 Points: 185, Level: 3 Points: 185, Level: 3
Level Up 70% Completed
FF Reputation: 2 Billacuda Good Standing Member
I noticed the same thing. Best mileage I have gotten all winter is 34 doing 65. Over the summer I could get 38-39 at the same speed. I believe it's a mix of winter fuel + cold temps.
2013 Ford Focus Titanium Hatchback
2013 Ram 1500 ST 4x4
Billacuda is offline
Old 03-21-2014, 12:14 PM   #4
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,959, Level 40
Points: 3,959, Level: 40 Points: 3,959, Level: 40 Points: 3,959, Level: 40
Level Up 5% Completed
Forum Activity 9%
FF Reputation: 14 mac.mogul Great Standing Member
Cold air is very dense and the engine uses more fuel to compensate.
Hot air is less dense and the engine uses less fuel to compensate.
It's why on a very hot summer day, your car may feel like it has less power than usual.
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 03-21-2014, 12:35 PM   #5
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,299, Level 28
Points: 2,299, Level: 28 Points: 2,299, Level: 28 Points: 2,299, Level: 28
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 4%
FF Reputation: 13 BetaDnB Great Standing Member
This should be common knowledge for any car owner. This happens to all cars. Always has. I however see a much greater fluctuation. I haven't been able to hit 30mpg all winter, but once it hits about 60 I'm good for usually 40mpg+.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is online now
Old 03-21-2014, 01:45 PM   #6
boombots
boombots's Avatar
Fan#: 130266
Forum Activity 3%
I know the fuel blend mixes it up but my explorer had no change based on temp. Summer blend was always 16.5-17.5 and winter was 14. It could be 15 degrees or 65 degrees on winter blend and hold consistent mpg. I knew performance was better in cold so I wasn't expecting that big of a dip I guess... This is my first efficient car
Just wanted to hear from other focus owner... Thanks guys...
-Vince
Old 03-21-2014, 02:06 PM   #7
bshin352
bshin352's Avatar
Fan#: 114147
What I Drive: 2013 Tux Black Ti Sedan, DCT
FF Reputation: 1 bshin352 Good Standing Member
add aerodynamics and such to the fuel and engine temps.
cold air is dense, difficult to punch through going say, 50mph?
bshin352 is offline
Old 03-21-2014, 02:08 PM   #8
mac.mogul
mac.mogul's Avatar
Fan#: 90409
Forum Activity 9%
Temperature does not affect aerodynamics.
Old 03-21-2014, 02:52 PM   #9
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 4%
Actually drag does increase with air density.
Old 03-21-2014, 03:02 PM   #10
Kabigon
Fan#: 88299
Points 4,394, Level 42
Points: 4,394, Level: 42 Points: 4,394, Level: 42 Points: 4,394, Level: 42
Level Up 22% Completed
Forum Activity 14%
FF Reputation: 11 Kabigon Great Standing Member
You said that "cold air is very dense" and that "hot air is less dense".
Do you understand the relationship between air density and drag?
I am Kabigon and I approve this message.
Kabigon is offline
