Tire size - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-21-2014, 06:44 AM   #1
Dukttape
Dukttape's Avatar
Fan#: 94135
What I Drive: 2011 Sangria Red SE Sedan "Fiona"
Points 635, Level 12
Points: 635, Level: 12 Points: 635, Level: 12 Points: 635, Level: 12
Level Up 70% Completed
FF Reputation: 1 Dukttape Good Standing Member
Tire size
I'm looking for a set of good summer tires. Only thing is I have the stock "15 wheels. I'm looking for a tie that's wider than stock tread wise yet has a shorter side wall. What are my options. I was looking on tire rack at 205/50R15 but the load index is an 86 instead of an 88. Is this something I can use or should I just use the stock 195/60R15 and just deal with the wheels spinning a bit this summer until I can get another set of wider wheels?
Roush performance intake, Exedy 12.5 lb flywheel, Massive 76A lower engine mount... more to come with more money.
Dukttape is offline
Old 03-21-2014, 06:51 AM   #2
cheap sleeper
Fan#: 59848
What I Drive: 2001 black zx3
Points 910, Level 16
Points: 910, Level: 16 Points: 910, Level: 16 Points: 910, Level: 16
Level Up 10% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 5 cheap sleeper Good Standing Member
In 15 inch, you can go considerably wider. I have personally ran up to 215-55-16 and I still had room to clear by a half inch or more from the strut. Don't concern yourself with load index or speed ratings. All you should look at 'specs'-wise, IF you are determined to study ratings, is the traction rating and tread wear rating. But keep in mind, many 'specs' ar a quasi-arbitrary number that the manufacturer itself gets to test and claim with little oversite, so 'specs' are 70% b.s.. With such little, light weight cars, load index is the last thing you would ever need to look at on a tire. ;)
cheap sleeper is offline
Old 03-21-2014, 07:28 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,737, Level 73
Points: 12,737, Level: 73 Points: 12,737, Level: 73 Points: 12,737, Level: 73
Level Up 72% Completed
Forum Activity 99%
Tire width isn't going to help with traction, you need to look for summer high performance tires for that.
Not much choice in the stock size, look in Tire Rack for ratings/reviews.
(15" is kinda ignored with more performance selections in 17's, except for race rubber)
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 03-21-2014, 04:46 PM   #4
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,060, Level 34
Points: 3,060, Level: 34 Points: 3,060, Level: 34 Points: 3,060, Level: 34
Level Up 7% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Unless money is no object, get a good 195/60 rather than an equivalently priced wider tire that isn't rated as good. (check tire rack)
I like my Bridgestone RE960s.....
Ed
emsvitil is online now
Old 03-21-2014, 06:04 PM   #5
Seth@TireRack.com
Fan#: 132618
What I Drive: N/A
Points 45, Level 1
Points: 45, Level: 1 Points: 45, Level: 1 Points: 45, Level: 1
Level Up 90% Completed
FF Reputation: 1 Seth@TireRack.com Good Standing Member
Take a look at the 205/55R15 Yokohama S.Drive. Great traction in a recommended size for your SE that works on a 15 inch wheel between 5.5 and 7.5 wide, it is an Ultra High Performance Summer tire though so not for cold temps. Click here to take a look http://www.tirerack.com/tires/tires....&affiliate=AD4
800 428-8355 Ext. 4177
Seth@TireRack.com
Remember to reference Seth/Focus Fanatics in the "previous contacts" field to make sure the forum get's credit!
Seth@TireRack.com is offline
Old 03-21-2014, 08:38 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
There ya go!
A bit more width & a lot of stick.
"Rubber Side Down"
Old 03-22-2014, 11:01 PM   #7
Dukttape
Dukttape's Avatar
Fan#: 94135
Yay! Now all I have to do is save a bit out of the next two paychecks and stick these on my wheels and go for some fun drives on the back roads
Dukttape is offline
