Help Me Identify Something I Found in My Engine Bay - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2014, 09:40 PM   #1
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
I usually inspect my car every few thousand miles. Car has only been to the dealer for oil changes and a sync update.
I found this piece of plastic (looks like a connector but air doesn't go through it)
This is the area in which I found it resting
I couldn't see anywhere it would connect. Is this suppose to be a piece of my car, or something that the tech dropped, or ???
thejordan is offline
Old 03-20-2014, 09:57 PM   #2
wavsine
wavsine's Avatar
Fan#: 118470
What I Drive: 2013 Focus SE Oxford White Hatch 5m
Points 20,405, Level 90
Points: 20,405, Level: 90 Points: 20,405, Level: 90 Points: 20,405, Level: 90
Level Up 11% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 16 wavsine Great Standing Member
Did they check out this oil leak when you had it in?
Use a Motorcraft FL-400S filter to increase filtration media and oil quantity. (Drop in for FL-910S)
Synthetic oil in GDI engines
www.focusfanatics.com/forum/showthread.php?t=324396
wavsine is online now
Old 03-20-2014, 10:05 PM   #3
thejordan
thejordan's Avatar
Fan#: 107706
That actually seems to be dirt caught by the edge of gasket sealer. I was cleaning the engine bay so it was dripping down.
I'm going to do a full cleaning when the block cools to verify. I don't have any oil loss, I'm at 20k. My coolant is at the min line however.
Old 03-20-2014, 10:05 PM   #4
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,400, Level 29
Points: 2,400, Level: 29 Points: 2,400, Level: 29 Points: 2,400, Level: 29
Level Up 67% Completed
FF Reputation: 6 CunFFS13 Good Standing Member
Oil leak!
CunFFS13 is offline
Old 03-20-2014, 10:08 PM   #5
thejordan
thejordan's Avatar
Fan#: 107706
Originally Posted by CunFFS13 View Post
Oil leak!
It doesn't smell/taste like oil
I'll add dye to the oil to verify.
Old 03-20-2014, 11:08 PM   #6
Rat Fink
Fan#: 92487
What I Drive: Ford, and vintage Dodge
FF Reputation: 6 Rat Fink Good Standing Member
Pretty sure it's something from the assembly process. A lot of vehicles have random plastic bits that look like that in various forms that are left around the vehicle. most of the junk left inside the car gets cleaned out for delivery, but there are plenty of nooks/crannies under the hood where things like that are abandoned. Could've been a plug for one of the lines that gets chucked on assembly. You'll find various plastic plugs, rubber bands, sometimes even random screws/bolts laying around.
If anyone has ever done a 1st transmission service on an older ford where they find the goofy looking yellow bobber in the bottom of the pan, it is probably the same type of idea. (the bobber sits in the dipstick tube hole on the trans to keep out contamination while on assembly line, and when the dipstick tube is pushed into the trans, the bobber gets pushed into the trans pan and is left there).
Rat Fink is offline
Old 03-20-2014, 11:24 PM   #7
thejordan
thejordan's Avatar
Fan#: 107706
ya that makes sense. it's not hollow so fluid/air can not pass through so it wouldn't really be a useful connector. or the tech dropped it as some sort of oil filler apparatus.
i just cleaned my engine bay, it doesn't seem like any of that grime contained oil (it was dry like dust), but i'll do the dye + uv inspection to be sure.
thanks everyone.
Old 03-20-2014, 11:40 PM   #8
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,783, Level 54
Points: 6,783, Level: 54 Points: 6,783, Level: 54 Points: 6,783, Level: 54
Level Up 17% Completed
Forum Activity 3%
FF Reputation: 9 SilverPony2001 Good Standing Member
Doge!!!
SilverPony2001 is online now
Old 03-21-2014, 02:14 PM   #9
bshin352
bshin352's Avatar
Fan#: 114147
What I Drive: 2013 Tux Black Ti Sedan, DCT
FF Reputation: 1 bshin352 Good Standing Member
winter has been brutal hasnt it?
you could do the dye but unless its a rear main, it wont show. i dont recall ever seeing a leak above the transmission in mine. It was on the bottom as i dropped the undertray.
bshin352 is offline
Old 03-21-2014, 02:47 PM   #10
waynehere
Fan#: 150002
What I Drive: 2009 Focus
Points 8, Level 1
Points: 8, Level: 1 Points: 8, Level: 1 Points: 8, Level: 1
Level Up 15% Completed
FF Reputation: 1 waynehere Good Standing Member
When you say they did a sync on it, what is that anyway? I was thinking maybe it is like a hose plug for when the shop might hook up a tester or scanner. They may have left it behind or it fell off and they forgot to get it back out? Just a thought.
waynehere is offline
