Oil life/change Message will not Clear - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > MK3 Focus
Old 03-20-2014, 05:36 PM   #1
awwall
Fan#: 90527
What I Drive: 2012 Grey Focus Hatchback
FF Reputation: 1 awwall Good Standing Member
Folks, here is the problem. My 2012 Focus has had the Oil Changed every 3000 miles by the dealer...yes I know 3000 is not much, but I am a fanatic about a 3000 mile change. Here is the problem, the "Oil Change" message has popped onto the screen behind the steering wheel. I have followed the books procedure to the Tee...
Resetting the Oil Life Monitoring System
1. Turn the ignition key to the on position. Do not start the engine. For vehicles with push-button start, press and hold the START/STOP button for two seconds without pressing the brake pedal. Do not attempt to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be displayed.
5. After 25 seconds, the Service: Oil reset complete message will be displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be displayed.
8. Rotate the key to the off position. For vehicles with push-button start, press the START/STOP button to turn the vehicle off completely.
Tried this several times and nothing happens. The message just stays there until it times out. Turn key off and back to on, there it is again.
Any clues to what could be going on before I take it to dealer?
awwall is offline
Old 03-20-2014, 05:51 PM   #2
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,314, Level 29
Points: 2,314, Level: 29 Points: 2,314, Level: 29 Points: 2,314, Level: 29
Level Up 10% Completed
Forum Activity 35%
Activity: 35% Activity: 35% Activity: 35%
FF Reputation: 6 CunFFS13 Good Standing Member
Try this
http://m.youtube.com/watch?v=o7P1xUEcab8
CunFFS13 is online now
Old 03-20-2014, 05:56 PM   #3
awwall
Fan#: 90527
Originally Posted by CunFFS13 View Post
Already watched this one and some others. It does not work.
Thanks for suggestion.
awwall is offline
Old 03-20-2014, 06:06 PM   #4
suss6052
suss6052's Avatar
Fan#: 95752
Points 9,584, Level 65
Points: 9,584, Level: 65 Points: 9,584, Level: 65 Points: 9,584, Level: 65
Level Up 78% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
I don't know why you are having difficulty with this, just keep both pedals fully depressed before turning the key to on with the engine off. I've never seen this not work in person.
suss6052 is online now
Old 03-20-2014, 06:16 PM   #5
goingtoscotland
goingtoscotland's Avatar
Fan#: 132001
What I Drive: '14 Tuxedo Black HB, 05 Kawi ZX-10R
Points 1,954, Level 26
Points: 1,954, Level: 26 Points: 1,954, Level: 26 Points: 1,954, Level: 26
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 6 goingtoscotland Good Standing Member
And if it's truly not working, take it to your dealer for an inspection. Warranties are a great thing, use it while you can.
Dawkins....Dennett....Harris....Hitchens
Hatch Nation #46
goingtoscotland is offline
Old 03-20-2014, 06:48 PM   #6
awwall
Fan#: 90527
Should I depress the brake and accelerator before turning the key to "ON"?
awwall is offline
Old 03-20-2014, 06:52 PM   #7
goingtoscotland
Fan#: 132001
You can try, but I don't see how that will make a difference. You stated that the in progress message appears,but never completes. The process is initializing, so that's not really an issue.
Hatch Nation #46
Old 03-20-2014, 08:29 PM   #8
awwall
Fan#: 90527
If you re-read my post you will see that the process "never" starts. It just doesn't do anything when I try to initiate it...
awwall is offline
Old 03-20-2014, 09:01 PM   #9
goingtoscotland
Fan#: 132001
"The message just stays there until it times out"
I see. I thought by this that you meant that the oil reset in progress message just stayed there when depressing the pedals
Hatch Nation #46
Old 03-21-2014, 03:01 PM   #10
mlheck
Fan#: 140617
What I Drive: 2012 Focus SEL
FF Reputation: 1 mlheck Good Standing Member
I'm going to ask a stupid question here, are you turning the key to the "ON" position or the "Accessory" position. When you turn it to the ON position all of the light in the cluster should come on.
mlheck is offline
