Tail lens replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-18-2014, 05:30 PM   #1
That_Yellow_Car_Guy
Fan#: 136817
What I Drive: 2012 Yellow Blaze 4dr SE automatic
Points 42, Level 1
Points: 42, Level: 1 Points: 42, Level: 1 Points: 42, Level: 1
Level Up 84% Completed
FF Reputation: 1 That_Yellow_Car_Guy Good Standing Member
Now that the weather has warmed up (yay 40F!) I need to replace the tail lenses, not the bulbs mind you but just the lenses. They were both cracked back in January when a good Samaritan pushed me out of the snow. Specifically, I am referring to the inboard ones/attached to the trunk lid and not the ones body-side. My questions are: do I need any special tools to remove/replace the lenses? I have the basics:Torx, screwdrivers, etc. I noticed on the inside of the trunk lid the black screw cover where the assembly bolts in so I know how to take it off, I think. Just curious if this is an easy at-home fix or something to haul into the dealer. I also need to replace the CHMSL but that appears to be a plug-n-play deal by simply popping it out of the wiring harness. Thanks.
That_Yellow_Car_Guy is offline
Old 03-18-2014, 05:37 PM   #2
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,488, Level 52
Points: 6,488, Level: 52 Points: 6,488, Level: 52 Points: 6,488, Level: 52
Level Up 69% Completed
Forum Activity 4%
FF Reputation: 9 SilverPony2001 Good Standing Member
You just need to unscrew the plastic wing nut thing that is on one bolt, and they pop out. The need a little force, so push from the back and have a hand in front to catch if need be. I would also disconnect the reverse light harness first.
SilverPony2001 is offline
Old 03-18-2014, 06:18 PM   #3
That_Yellow_Car_Guy
Fan#: 136817
Points 42, Level 1
Thanks, that wingnut is what I was thinking of. I'm going to swing by the dealer tomorrow and see if I can get replacements.
Old 03-18-2014, 08:10 PM   #4
JustinT222
Fan#: 107545
What I Drive: 2013 Black Focus Titanium
FF Reputation: 1 JustinT222 Good Standing Member
The wingnuts are TIGHT from the factory, I had to use a pair of needle nose to get enough torque to twist them out and tighten them back up when I tinted mine.
After you take those off just "gently" pull on the tail light assembly from outside the car. There is a popper you have to get loose that takes some force to remove
Easiest tail light removal ever
JustinT222 is offline
Old 03-19-2014, 09:19 AM   #5
That_Yellow_Car_Guy
Fan#: 136817
Points 42, Level 1
I bought my car used, maybe that's why the wingnuts weren't super-tight. I just twisted one off by hand. Or maybe I'm superhuman! LOL
Old 03-19-2014, 01:48 PM   #6
That_Yellow_Car_Guy
Fan#: 136817
Points 42, Level 1
I stopped at the local used auto parts shop and ordered replacements. They're 1/3 cheaper than going to a dealer and should be here by Friday. For whatever reason, I neglected to order/ask about the CHMSL! Oh well, I can ask about it when I pick up the tail lamps.
Old 03-21-2014, 10:08 AM   #7
That_Yellow_Car_Guy
Fan#: 136817
Points 42, Level 1
OK, so I got the call on Thursday morning that my lenses were in. I picked them up and also found out they had a CHMSL as well. I purchased all 3 and came back home. Easy enough to replace, just unplug the wire harness, then unscrew the wingnut and gently pop out the entire lens. Of course I tested the new ones before replacing and everything worked well. Working alone I had to wedge a pole on the brake to test all the lights. Assembly was of course in reverse order. However I had a helluva time getting everything flush with the body. It seems the bottom part should be closer to the body but there seems to be (to my eyes) an unacceptable gap. I tried putting them back together more than once with the same results. As for the CHMSL, I only had one of the metal clips left due to the above-referenced incident. I replaced this one the best I could but it still sticks out a little bit due to a small dent in the trunk face right above the blue oval. I'm going to call it good enough for now until the weather warms up and I can have my FIL take a look at it. In the meantime, I may go to a dealer this Sunday and look at the tail lights to see how far off I am.
Old 03-21-2014, 01:51 PM   #8
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,388, Level 36
Points: 3,388, Level: 36 Points: 3,388, Level: 36 Points: 3,388, Level: 36
Level Up 26% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
I'm voting you're superhuman. Be sure to check out Ford Parts here for any additional items you may need.
Todd
FORD SERVICE
p: 800.392.FORD
FordService is offline
