Headlight problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-18-2014, 01:54 PM   #1
Celebrity
Celebrity's Avatar
Fan#: 99779
What I Drive: MK3 Focus Hatch
FF Reputation: 1 Celebrity Good Standing Member
Headlight problem
So the past couple weeks I have been having a problem with my headlight. It simply is not working. The unit itself works because i can see the amber lights are illuminated. I get a message on my display that reads "Dipped Beam. Bulb Fault"
This is a reacurring problem, hence it keeps happening, but every time I go to fix it, the bulb is working again, so the bulb isnt burnt out..
I did replace my bulbs with some 4200K Halogen bulbs, but it hasnt been an issue until now. Can anyone help?
Celebrity
*MK3*
Instagram: @RyanLewiss
Twitter: @RyanLewiss
Celebrity is offline
Old 03-18-2014, 03:46 PM   #2
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,790, Level 54
Points: 6,790, Level: 54 Points: 6,790, Level: 54 Points: 6,790, Level: 54
Level Up 20% Completed
Forum Activity 4%
FF Reputation: 9 SilverPony2001 Good Standing Member
Stock wattage on the new bulbs?
SilverPony2001 is online now
Old 03-18-2014, 05:32 PM   #3
vegachicago
Fan#: 89988
What I Drive: 2012 Focus SEL Sterling Grey
Points 1,004, Level 17
Points: 1,004, Level: 17 Points: 1,004, Level: 17 Points: 1,004, Level: 17
Level Up 4% Completed
FF Reputation: 2 vegachicago Good Standing Member
If wattage is the stock 55watt then I'd suspect the socket friction connection, that is, inside the socket. Check for corrosion or oxidation. Also, get some silicone gel to apply a VERY thin coat to the base of each bulb. remember that halogen bulbs cannot or should not be handled so use very gloves. Good luck
vegachicago is offline
Old 03-18-2014, 11:22 PM   #4
Celebrity
Celebrity's Avatar
Fan#: 99779
Only one headlight is out. That's 1/4 bulbs that isn't working. And like I said it occasionally works.
Celebrity
*MK3*
Old 03-18-2014, 11:51 PM   #5
SilverPony2001
Fan#: 27073
Forum Activity 4%
Are they stock wattage?
Old 03-19-2014, 07:35 PM   #6
Celebrity
Celebrity's Avatar
Fan#: 99779
So I disconnected my headlight, but left the power connected to the car, disconnected the bulb, and re connected the bulb, and it worked fine. Im guessing the connection from the bulb to the car was bad, all I know is that I have a working headlight now.
Celebrity
*MK3*
