What's your beef with your second gen? - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-20-2014, 10:04 AM   #41
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,735, Level 24
Points: 1,735, Level: 24 Points: 1,735, Level: 24 Points: 1,735, Level: 24
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 5 Miller88 Good Standing Member
Originally Posted by sailor View Post
Miller88 - you can play with camber all you want, but toe-in has been the issue with rear tire wear on these from the first ones.
Check in the Brakes,Tires & suspension area to see all the old threads on this.
Just tryin' to help out, had one rear misaligned when I got mine & getting them right solved the problem.
MINIMUM spec. for toe in the rear works - toed toward the max it'll chew up tires.
Cheers
I've read that too. But the rear wheels look like this when looking at the rear of the car /---\ I don't have any feathering on the inside, though.
I can check the toe pretty easily. I should do that once the weather warms up.
Originally Posted by mac.mogul View Post
I think you have a unique problem because I've never had problems with shifting into 2nd gear. Have you looked at your shifter assembly for possible problems?
I have had it to the dealer 5 or 6 times. It's "normal". Doesn't appear to be a synchronizer as 50% of the time it shifts perfect and it doesn't pop out of gear.
Who knows. It hasn't got any worse (actually a bit better). Problem appeared around 15K miles and I am almost at 41K. As long as it doesn't get worse, I'll not worry about it.
I plan to keep the car until it rusts in half like my Taurus did. I keep the paint waxes and spray with oil throughout the winter, so this one shouldn't rust as bad as the Taurus!
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 03-20-2014, 10:43 PM   #42
WilliamChrist
Fan#: 147282
What I Drive: 2008 Silver Sedan SES
FF Reputation: 1 WilliamChrist Good Standing Member
The motor mounts on the car are garbage and I need to change them so I can stop driving a paint shaker around. Also on the rear end there are 4 bolts that hold the entire spindle in place for the rear tire that you have to remove in order to check the brakes so if you live in a state where they do an inspection (i.e. virginia) they often don't put all the bolts back in because its a pain in the ass to get too => I have to argue with the morons.
Other than that its a great little car that gets wonderful gas mileage, too bad not much aftermarket support.
WilliamChrist is offline
Old 03-20-2014, 11:34 PM   #43
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Yeah that brings up probably my biggest complaint on our cars. A complete lack of aftermarket parts even though there were over a million 08-2011 focus sold lol
Galatians 6:14
crice8 is offline
Old 03-21-2014, 03:17 PM   #44
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
I could be entirely wrong, but I think most of the stuff from the Mk1s will work on the Mk2 because mechanically, the cars are very similar. Like the FRPP suspension kits for example, or the SVT rear brake kits.
But really, if you want a huge aftermarket for an economy car (at least an American one) you've bought the wrong car. Honda and Nissan would be the ones to own if you want a huge aftermarket for econo-boxes.
As for my gripes with the car...
1. The tray on the rear bumper
2. The chipping on the steering wheel buttons
3. When I'm really getting into to with the throttle (talking near redline shifting), 3rd gear will always grind just the slightest bit
4. With both windows down, cruising at highway speeds, the radio isn't nearly loud enough to overcome wind noise
5. My passenger side door requires either one really hard tug on the handle to open it, or two pulls. One to pop it free, the second to open it
6. No interior trunk release
7. Crappy plastics in the dash
8. Lack of rear disc brakes
9. Lack of adequate seat bolsters (my sister's Honda Fit has better seats then me)
Other then all that, mechanically it's a great car, aesthetically nice to look at, and it's got enough get-up-n-go to get me in just enough trouble if I wanted to.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 04-09-2014, 08:18 PM   #45
jiraines
Fan#: 70026
What I Drive: 2009 Sterling Gray Focus SE
Points 108, Level 2
Points: 108, Level: 2 Points: 108, Level: 2 Points: 108, Level: 2
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 jiraines Good Standing Member
I have issues with rattles and other noises from the dash during cold weather. The buttons on the steering wheel are really chipped on mine too. The fix ford applied for the squeaking parking brake cable broke after about a year so I just grease it up with axle grease once a year. I have replaced both license plate bulb sockets twice because the keep rusting out and break when I change bulbs. My brake light housings get moisture inside them during really wet weather but eventually dry out.
She's a great little car though and I enjoy driving it. I think the focus was the best car to buy at that price point.
jiraines is offline
Old 04-10-2014, 01:02 PM   #46
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,032, Level 45
Points: 5,032, Level: 45 Points: 5,032, Level: 45 Points: 5,032, Level: 45
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 13%
FF Reputation: 6 SlickWilly Good Standing Member
I've seen some people with the chipped steering wheel buttons but mine are chip free. My center piece did scratch up.
My auto spins a lot more then I would like off the line, an aggressive tire would solve that but these LRR's so nice and fuel efficient to ride on.
I wish my gear ratio was better probably a coupe trans swap would help me with that because my gears are long and winded by the time it shifts.
K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - N2O
SlickWilly is offline
Old 04-10-2014, 02:48 PM   #47
Rubix
Rubix's Avatar
Fan#: 109903
What I Drive: 2011 SES
FF Reputation: 1 Rubix Good Standing Member
This bugs me.
http://www.focusfanatics.com/forum/showthread.php?t=309357
For my build
Rubix is offline
Old 04-10-2014, 04:40 PM   #48
pfsantos
Fan#: 125113
What I Drive: 2009 Silver SES
Points 705, Level 14
Points: 705, Level: 14 Points: 705, Level: 14 Points: 705, Level: 14
Level Up 5% Completed
FF Reputation: 1 pfsantos Good Standing Member
^ your pic is kinda vague lol...what bugs you?
Pretty much what was mentioned and:
- no switch to turn off dome light when opening doors
- buzzer that doesn't shut off when door open and ign. on.
- having rear drums, especially not being able to take drum off without messing with the bearing
Also on the rear end there are 4 bolts that hold the entire spindle in place for the rear tire that you have to remove in order to check the brakes so if you live in a state where they do an inspection (i.e. Virginia)
Shouldn't they be removing the wheels and center bearing nut instead?
And I've generally only heard good things about our man. tranny (MTX75), so maybe some have had bad previous (or current, lol) owners. :D
pfsantos is online now
Old 04-10-2014, 04:49 PM   #49
Miztaken1312
Fan#: 74993
I love my manual. And since I've put in my Steeda shirt throw, it doesn't grind going into third at high rpm
Old 04-10-2014, 05:13 PM   #50
Rubix
Rubix's Avatar
Fan#: 109903
I suppose not being flush bugs me too haha but I was trying to show the condensation in my tail light.
For my build
Rubix is offline
