#1 | ||||
Spring tune up advice (Synthetics, plugs, etc...)
I'm gonna give my car an early spring tune up (prob. the first one - bought my car last Sept.) and I just wanted some advice and if at all possible specs/part numbers for some things.
I'm gonna get new plugs - either NGK Iridiums, Denso Iridiums or Motorcraft coppers. I'm leaning towards the iridiums as they'll only be about $20-30 more a set but may be hard to get. Anyways, does anyone have any part numbers for any of these and any experience changing to one of these brands? Second is new wires - either F/S 8 mm for about $80, or Ford motorsport 9mm (I believe?) for $?? Are the FocusSports overhyped? Should I save a few bucks and get the bigger Ford wires and if so, do you have a part number? Third, I'm gonna switch the oil to Mobil 1 5W30 which is certian but the tranny swap to Mobil 1 is a bit iffy....is it just a universal manual tranny fluid or ATX fluid? Is there a specific weight like the crankcase' oil? Anyone have experience swapping the tranny fluid over? I figure this 'tune-up' should smooth out the idle and maybe give me a little better mileage for couple hundred and last for quite some time so it's a worthwhile investment imo. Any help and advice is appreciated and I have searched all the way back to last August and there are almost no mentions of part number so I thought I'd throw this in !! Thanx, Todd |
Remove Advertisements |
Fan#: 1
#2 | ||||
Denso Iriduim part # ITV24
as for as tranny lube goes , i use the Redline MTL |
#4 | ||||
only thing i noticed with the spark plugs was a faster start-up in really cold temps
the redline seemed to make down shifting a bit smoother and the slight whine the tranny had under hard accleration is gone |
#5 | ||||
The Librarian
The Ford spec for the Getrag tranny fluid is:
MERCON V - ATF, Full Synthetic. I'm not sure which Redline, or Royal Purple for that matter, would be a match.
WD40 Reverend GripShift - FF Moderator Member's Rules and Signature Guidelines Member FAQ and Information Archive Complete 'How To' Archive Complete Acronym/Abbreviaton and Forum Terminology List |
#7 | ||||
you can get the denso iridium plugs from c-f-m.com. I think it's around $50 a set. you might also want to look into a screamin demon coilpack and set of livewires from performance distributors. the coil puts out more power than the stock coil, and the wires a rather high quality, which will help your idle, startup, and smooth out your acceleration a good bit. there are some magazines that show a small HP increase from the coilpack and wires, and I know denso iridium plugs actually do produce more power/tq than stock plugs (been proven on other cars, but I don't know anyone who did a back to back dyno for plug comparison). if you do the coilpack, wires, and plugs, you'll spend around $200 total, and if you don't have a lead foot, your investment should pay for itself in increased gas mileage in about 2 years (yes, I did the math).
#9 | ||||
I got some Redline 5W30 synthetic oil but not tranny oil....gonna wait til a flush is actually required. I also got a new K & N conical air filter, some Motorsport 9mm wires, NGK iridium plugs and a new Ford fuel filter and some good concentrated fuel injection cleaner. This will all be installed Tuesday and hopefully I get another 40 hp out of it!!! (obviously kidding!)
| Thread Tools | |
| Display Modes | |
