2005 headunit and alarm system wire colors and pictures - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-27-2005, 02:16 AM   #1
sa_pyro_ne
sa_pyro_ne's Avatar
Fan#: 1437
What I Drive: 2000 Ranger V6 4.0L 4x4 XLT Ext Cab
FF Reputation: 4 sa_pyro_ne Good Standing Member
Thanks to www.directechs.com for this information. To see more detailed information for the 05 Focus (including special notes on wire locations, more photos, more wire colors, etc) go to www.directechs.com and enter the password c441wav (I saw the password posted somewhere over at FJ so if anyone has a problem with this let me know).
Head unit power wires:
Radio 12v : orange/black
Radio Ground : black/green and black (there are two grounds)
Radio Ignition : yellow/green
Radio Illumination : orange/black (dimmer) - pos. wire
Factory Amp Turn-on (if you have the audiophile or sony system) : white/red (sub amp)
Speed Sense : white/green
Speaker wires (pos. - neg.):
LF Speaker : +/- white/black - gray/black
RF Speaker : +/- white/red - gray/red
LR Speaker : +/- white/purple - gray/white
RR Speaker : +/- white - gray
Remote start, alarm, keyless entry, etc. wires (wire : color : polarity : location):
Notice: Immobilizer Bypass Module needed for remote starts : Type is SecuriLock : Part# is 555S, 556U, or 555U
12volts : red (30A) : + : ignition harness
Starter : gray/black : + : ignition harness
Ignition : green/yellow : + : ignition harness
Accessory : yellow : + : ignition harness
Keysense : red/black : + : ign harness or GEM, tan plug, pin 8
Power Lock : black/red : - : driver kick or GEM, gry plug, pin 15
Power Unlock : black/yellow : - : driver kick or GEM, gry plug, pin 21
Lock Motor : yellow/black : 5wi : driver kick or GEM, wht plug, pin 3
Unlock Motor : white/black : 5wi : driver kick or GEM, brn plug, pin 5
Disarm Defeat : white/black : 5wi : pass. kick or GEM, brn plug, pin 1
Parking Lights: orange/yellow : + : switch or GEM, tan plug, pin 14
Hazards : black/orange : - : switch or GEM, tan plug, pin 23
Turn Signal(L) : blue/white (F), blue (R) : + : GEM, blu plg, pin 4 & gry plg, pin 2
Turn Signal(R) : blue/red (F), blue/red (R) : + : GEM, blu plg, pin 3 & wht plg, pin 4
Reverse Light : green/black : + : driver kick, harness to rear
Door Trigger : see notes (see bottom of thread) : - : GEM
Dome Supervision : black/blue : - : dr A pillar or GEM, gry plug, pin 3
Trunk/Hatch Pin : black/blue or black/yellow : - : light in trunk/cargo area
Hood Pin : black/yellow : - : pin switch or GEM, blu plug, pin 21
Trunk/Hatch Release : black/yellow : - : switch or GEM, brn plug, pin 16
Factory Alarm Arm : black/blue : - : driver kick or GEM, gry plug, pin 16
Factory Alarm Disarm : black/white : - : driver kick or GEM, gry plug, pin 14
Disarm No Unlock : see factory alarm disarm
Tachometer : black/stripe : AC : any fuel injector
Brake Wire : green/red to green/yellow : + : switch or GEM, tan plug, pin 9
Parking Brake : black/red : - : parking brake switch
Horn Trigger : black/blue or black/green : - : column or GEM, brn plug, pin 14
Headlight : green/red : + : headlight switch
Speed Sense : white/green : radio harness
Wipers : white/grn (L), white/blk (H) : + : windshield wiper switch
LF Window up/dn : yellow - white : A : driver window motor in door
RF Window up/dn : yellow/purple - white/purple : A : driver kick, door harness
LR Window up/dn : yellow/blue - white/blue : A : driver kick, door harness
RR Window up/dn : yellow - white : A : driver kick, door harness
Note: The LF door is black/yellow in the tan plug, pin 22. The RF door is black/blue in the tan plug, pin 21. The LR door is black/orange in the white plug, pin 15. The RR door is black/green in the gray plug, pin 18. Use all four wires and diode isolate each. :::::::::::: The GEM (Generic Electronic Module) is above the passenger kick panel.
sa_pyro_ne is offline
Old 02-27-2005, 02:38 PM   #2
ippyy
Fan#: 18384
What I Drive: 2005 Sonic Blue ZX4 SES
FF Reputation: 1 ippyy Good Standing Member
Just as a side note I think they used the same harness in all '05's. I have the non-audiophile 6cd player, and it still has the remote turn on wire, and also some little harness which either hooks up to the audiophile or blaupunkt, its just not hooked to anything in mine.
ippyy is offline
Old 02-27-2005, 07:08 PM   #3
spudgunman
Fan#: 3952
What I Drive: 05 ST Black on Black
FF Reputation: 1 spudgunman Good Standing Member
also the "stering wheel remote" wires are in that same plug
over @ http://www.pac-audio.com/ for more info
Pin's 18,19,20 (black,orange,violet) seen on the left of that picture
are also on the audiophile
My Car Site Wire Diag Help My CarMy Sub Box
___
Current FAQ: OEM SUB
spudgunman is offline
Old 02-28-2005, 04:06 PM   #4
polar
polar's Avatar
Fan#: 14064
What I Drive: 2005 Black ZX3
FF Reputation: 1 polar Good Standing Member
Is that a standard NorthAmerican antenna harness I see??
polar is offline
Old 02-28-2005, 05:09 PM   #5
spudgunman
Fan#: 3952
yes no more VW thing
___
Old 03-03-2005, 03:28 AM   #6
spudgunman
Fan#: 3952
more picture, including the 2005 ST with Audiophile package
___
Old 03-05-2005, 10:01 AM   #7
ealexander
Fan#: 15506
What I Drive: 2005 ses grey
FF Reputation: 1 ealexander Good Standing Member
Check this out for ipod hookup
http://www.jlaudio.com/press/CleanSweep05.html
ealexander is offline
Old 09-19-2005, 02:00 PM   #8
Toolman
Toolman's Avatar
Fan#: 27202
What I Drive: 2005 Ford Focus ZX3,Egg Yolk Yellow
FF Reputation: 1 Toolman Good Standing Member
2005 single-CD MP3 headunit
I've spent the last hour searching for info in the Forums - how can one tell which headunit they have? I've got a 2005 Ford Focus SE XZ3, with a single-CD, MP3 headunit. Audiophile package was NOT on my window sticker, so I'm assuming I don't have such (It also didn't come with a sub - that's what I'm trying to do). I keep seeing Sony and Blaupunkt mentioned - but can't find any mention of how to tell one from the other. Does anyone know how to tell which one I have, please?
Toolman is offline
Old 09-19-2005, 03:19 PM   #9
Zurkowski
Zurkowski's Avatar
Fan#: 27306
What I Drive: 2005 Ford Focus ST
FF Reputation: 1 Zurkowski Good Standing Member
Check out this THREAD. It seams to me that the Audiophile has the sub. Plus you may want to do a search and if you don't find out what you need try posting a new thread.
Zurkowski is offline
Old 12-14-2007, 08:40 AM   #10
BowlinBob
Fan#: 52181
What I Drive: 2007 Dark Red ZX3
FF Reputation: 1 BowlinBob Good Standing Member
but whats the username??
BowlinBob is offline
