200 whp? - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 03-10-2014, 03:08 PM   #71
bluehatch14
bluehatch14's Avatar
Fan#: 111245
What I Drive: 2012 blue se hatchback
Points 2,270, Level 28
Points: 2,270, Level: 28 Points: 2,270, Level: 28 Points: 2,270, Level: 28
Level Up 80% Completed
FF Reputation: 1 bluehatch14 Good Standing Member
Originally Posted by Eminaga View Post
Yhey are not similar weight I believe the GTI is around 3200. Yes you are right about the APR chip. I am saying with 190whp I will beat a stock GTI 10 out of 10 times.
And I hate to say it but besides driver error you aren't going to WALK a stock gti. You might beat it by a hair if your having a good day but he could do the same. There are other variables you must consider too. What tires you are running and also suspension setup, things of that nature.
bluehatch14 is offline
Old 03-10-2014, 03:16 PM   #72
sterlingfocus
Fan#: 115490
What I Drive: 2013 Focus se
FF Reputation: 1 sterlingfocus Good Standing Member
Originally Posted by bluehatch14 View Post
Just looked up the specs for a 2012 gti. It produces 207ftlbs of torque and 200hp at the crank. The curb weight is actually 3034lbs. Just some info to help compare spec to spec.
On my car regies my Focus= 2890 while the GTI is 3196. I dont know how accurate is that but the GTI dynos more then it advertises at the crank. What it advertises at the crank is what it gives to the wheels. I'm a bit lazy but how much hp does the highest rated N/A Focus dynoed on this board? Mod list also?
2013 F150 FX4 appearance supercrew
2013 Focus SE sedan Appearance DCT
2007 GTI 6 spd
sterlingfocus is offline
Old 03-10-2014, 03:19 PM   #73
bluehatch14
Fan#: 111245
Edmund's has a curb weight for the gti as 3034lbs. Just what I looked up not sure if its entirely accurate.
Old 03-10-2014, 03:22 PM   #74
sterlingfocus
Fan#: 115490
It would make sense 2dr,17s, manual, no sunroof, manual cloth seats
2007 GTI 6 spd
Old 03-10-2014, 03:58 PM   #75
Eminaga
Eminaga's Avatar
Fan#: 123953
What I Drive: 2014 Focus SE (Performance Blue)
Points 1,192, Level 18
Points: 1,192, Level: 18 Points: 1,192, Level: 18 Points: 1,192, Level: 18
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 24%
FF Reputation: 1 Eminaga Good Standing Member
Originally Posted by suss6052 View Post
You are way off about the curb weight of the GTI, which is closer to 3113 lbs than 3200 lbs. The Focus ST is closer to 3223 lbs.
There's not much chance of a modified N/A Focus at around 2960 lb or so walking away at 190 whp assuming you can get to that point from a stock GTI or ST unless the driver makes a mistake in the GTI, more so if they have the wet clutch DSG with it's instantaneous shifts v.s. your 5 speed or slightly slower dry clutch DCT.
http://www.vw.com/en/models/gti/trim...fbcf2f89050610
The fastest reported MK3 1/4 mile drag racing times are in the mid to low 15 second range, where as the ST and GTI are closer to the mid to high 14 second range stock unless the driver is not going flat out/ as hard as possible
there is a guy running 15.0 with few modifications in a sedan mk3.
*Snorkel/Shroud Delete, ITG Filter, Full ST Exhaust, E-RMM, Steeda RSB, Vogtland Springs, 180* T-Stat, Custom SCT Tune by Tom @ Focus-Power*
Eminaga is offline
Old 03-10-2014, 05:06 PM   #76
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,162, Level 96
Points: 26,162, Level: 96 Points: 26,162, Level: 96 Points: 26,162, Level: 96
Level Up 82% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
The highest HP Focus was Focusboy58 @183 HP/157 TQ. AEM intake, F2 race header, 3" custom dual exhaust.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
Old 03-10-2014, 05:08 PM   #77
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,249, Level 67
Points: 10,249, Level: 67 Points: 10,249, Level: 67 Points: 10,249, Level: 67
Level Up 50% Completed
Forum Activity 37%
Activity: 37% Activity: 37% Activity: 37%
FF Reputation: 26 suss6052 Great Standing Member
This may be the case that at best you might be able to shock a slower driver in the GTI or the ST, but even Motor Trend was getting a 14.6 @ 95.9 MPH from a Focus ST, 14.3 @100 mph for a 2013 MazdaSpeed3, and 14.7 sec @ 95.8 mph for a 2012 Golf GTI.
Unless you can consistently perform at or below 14.5 seconds you may occasionally beat a slower driver in a faster car, but 9 times out of 10 they will walk you if they are reasonably quick stock, and modified forget about it.
Well if you were in Europe you could spank the GTD all day long at 15.5 seconds if you had a 15.0 second car as that car was running 15.5 sec @ 89.2 mph.
http://www.motortrend.com/roadtests/...td_first_test/
suss6052 is offline
Old 03-10-2014, 05:11 PM   #78
Eminaga
Eminaga's Avatar
Fan#: 123953
Forum Activity 24%
didnt think the gti was that quick that must have been a freak because most videos is low 15's very high 14's from what i have seen. good thing i got my focus for the mpg and handling then :) I will be perfectly happy with i/h/e/tune :)
Eminaga is offline
Old 03-10-2014, 05:14 PM   #79
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
Forum Activity 60%
All he has is an intake and the Injected tune and yes, he has run 15.005 with just that and a lot of practice.
That is why you have to take the track into consideration. If he did all of the bolt-ons to his car and raced at that track in FL, he would probably always beat a stock GTI running in Denver. In no way am I discounting his time or the work he has done in achieving that 1/4 mile time, but I'll ask him if he can take note of what the local GTI's are running.
September '13 ROTM
2014 FiST-
Old 03-10-2014, 05:17 PM   #80
Eminaga
Eminaga's Avatar
Fan#: 123953
Forum Activity 24%
good point, so he is in fl? I would think 15.0 would be a drivers race with a GTI. Plus he can do a lot more mods to beat GTI. Ofcourse the GTI is stock but still not bad for a car economy car.
Eminaga is offline
