200 whp? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 03-07-2014, 01:29 AM   #31
goingtoscotland
goingtoscotland's Avatar
Fan#: 132001
What I Drive: '14 Tuxedo Black HB, 05 Kawi ZX-10R
Points 1,954, Level 26
Points: 1,954, Level: 26 Points: 1,954, Level: 26 Points: 1,954, Level: 26
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 6 goingtoscotland Good Standing Member
Originally Posted by suss6052 View Post
Of course for turbo assisted piston prop planes usually the turbocharger is just there to provide for power compensation at altitude as the air becomes thinner the turbocharger helps the plane to get close to the same air mass it would have on the ground at standard temperature and pressure.
A turboprop powered aircraft is not the same as one with a turbocharged piston engine. A turboprop is a turbojet or turbofan engine which has its compressor section driving a propeller instead of a fan disk.
You're right in that the wastegate is usually wide open at sea level, but that depends on the application and conditions/desired performance. There are many turbocharged aviation piston engines that boost at low altitudes.
goingtoscotland is offline
Old 03-07-2014, 08:46 AM   #32
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,038, Level 66
Points: 10,038, Level: 66 Points: 10,038, Level: 66 Points: 10,038, Level: 66
Level Up 97% Completed
Level up: 97% Level up: 97% Level up: 97%
Forum Activity 24%
Not a turboprop as in the turbine driven propeller air craft. I was talking about the turbo charged piston plane, that was a typo, but the remainder of the statement was factually correct in that most turbocharged piston planes were only turbocharged to normalize performance at altitude rather than increase performance on the ground like a car.
suss6052 is online now
Old 03-07-2014, 10:14 AM   #33
bluehatch14
bluehatch14's Avatar
Fan#: 111245
What I Drive: 2012 blue se hatchback
Points 2,208, Level 28
Points: 2,208, Level: 28 Points: 2,208, Level: 28 Points: 2,208, Level: 28
Level Up 39% Completed
FF Reputation: 1 bluehatch14 Good Standing Member
Better examples are turbocharged aviation piston engines. Reliability is paramount
Just trying to give examples of automotive engines.
bluehatch14 is online now
Old 03-07-2014, 11:19 AM   #34
goingtoscotland
Fan#: 132001
Yes, most are,however there are many designed to make use of forced induction at low altitudes. Whether cruising as 15,000ft or at sea level reliability is more important than it is in a car was my point. So saying FI is not safe just isn't correct
Old 03-07-2014, 11:29 AM   #35
darkangelism
Sonic Crew #04
darkangelism's Avatar
Fan#: 85425
What I Drive: 2012 Focus Titanium Hatch
Points 4,341, Level 41
Points: 4,341, Level: 41 Points: 4,341, Level: 41 Points: 4,341, Level: 41
Level Up 96% Completed
Forum Activity 6%
FF Reputation: 9 darkangelism Good Standing Member
Originally Posted by BecauseRacecar View Post
header
high flow cat
The obx/fswerks header is catless, probably some of the others as well.
2012 Ti Hatch
Sonic Crew #04
Steeda SRI/Newmission | Steeda RSB | SMC Replica ST Wing | SMC Aluminum Oil cap | Injected Tune | 2.5" custom exhaust
darkangelism is offline
Old 03-07-2014, 12:19 PM   #36
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 4,970, Level 45
Points: 4,970, Level: 45 Points: 4,970, Level: 45 Points: 4,970, Level: 45
Level Up 10% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 6 SlickWilly Good Standing Member
Originally Posted by Lost216 View Post
I'd say leave the nitrous for the mud boggers. It's not something I'd want on a DD.
Other than a stock turboed car I've never driven a reliable turboed car. I drive a reliable car on nitrous.
K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - N2O
SlickWilly is offline
Old 03-07-2014, 12:20 PM   #37
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 16%
On a wet kit that blends enough extra fuel perhaps. However on a dry kit going beyond what the fuel system can adjust for can run the engine dangerously lean in a heart beat. It's easier to tap into the fuel system of a port injected engine than it is on a direct injection motor.
Forced induction is forced induction no matter what you need to have your fuel tables correct.
Old 03-07-2014, 12:21 PM   #38
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 16%
Originally Posted by bluehatch14 View Post
Don't see how that's true. Turbochargers And superchargers are perfectly safe. I can give plenty of examples. Focus st, Shelby gt500, sti, evo, BMW m3, focus rs, all the ecoboost ford motors for that matter. There plenty of custom turbo kits on old svts and zetec motors. I fail to see how nitrous is any safer than those two other options.
Hoe reliable are these cars? Have you ever owned one?
Old 03-07-2014, 12:23 PM   #39
bluehatch14
Fan#: 111245
Then something was wrong with those turboed cars. I've known plenty of people with reliable turbo cars. Saying you haven't seen a reliable turbo car doesn't mean they don't exist or that nitrous Is safer for your car.
Old 03-07-2014, 12:33 PM   #40
bluehatch14
Fan#: 111245
No not personally. But I know people who own some of these vehicles and drive them a lot and they are reliable. They are factory vehicles designed to be driven daily. As long as they are properly maintained they will work. I'm not trying to say nitrous can't be reliable either though. But saying FI isn't reliable would be false.
