need info 2.3 head on 2.0 block - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-04-2014, 08:59 PM   #11
Outlaw5.0
Fan#: 84300
What I Drive: 2011 Ford Focus SES
Points 445, Level 8
Points: 445, Level: 8 Points: 445, Level: 8 Points: 445, Level: 8
Level Up 90% Completed
FF Reputation: 1 Outlaw5.0 Good Standing Member
2.0L stroke is 3.27
2.3L stroke is 3.70
2.5L stroke is 3.937
Outlaw5.0 is online now
Old 03-06-2014, 05:36 PM   #12
Driven5
Fan#: 95835
What I Drive: Building a Duratec powered Locost.
Points 52, Level 1
Points: 52, Level: 1 Points: 52, Level: 1 Points: 52, Level: 1
Level Up 4% Completed
FF Reputation: 1 Driven5 Good Standing Member
Originally Posted by 1turbofocus View Post
That would be a hugh incorrect assumption , Block/deck height , head , cams and more
Where can more info be found on the cam difference between the D20 and D23 cams? I'm probably not using the right search terms, or finding the right threads while sifting through the search results, but the only information I've been able to find on the stock cams is single sets of measurements, similar to this: http://www.focusfanatics.com/forum/showthread.php?t=120713
Also are there any known dynos comparing otherwise identical naturally aspirated setups on a D20 with only changing from the stock D20 head to the stock D23 head, to know realistically what gains are hiding there? Most of what I've been able to find on the D20 head actually being any appreciable restriction to mild/moderate naturally aspirated D20's appears to be primarily based on assumptions and hearsay, or who changed out more than just the head when measuring their gains.
-Justin
You can follow my Duratec powered 'Locost' build at:
GarageOdyssey.blogspot.com
GarageOdyssey.tumblr.com
Driven5 is offline
Old 03-06-2014, 06:00 PM   #13
Gladious
Fan#: 88166
What I Drive: 2006, gry,zx3
Points 157, Level 3
Points: 157, Level: 3 Points: 157, Level: 3 Points: 157, Level: 3
Level Up 14% Completed
FF Reputation: 1 Gladious Good Standing Member
not too sure.. BUT a question I've had was and is when u upgrade your cams tooo like a stage 1 .. I was told that its the stroke that's different. BUT if u change that wouldn't you need to change something else like piston length... oor something .. and IF I was to do that on a 99% stock engine like the 2.0 would it even make a difference ?
Gladious is offline
Old 03-07-2014, 06:56 AM   #14
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,715, Level 76
Points: 13,715, Level: 76 Points: 13,715, Level: 76 Points: 13,715, Level: 76
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
The 23 uses a taller deck height for the longer stroke crank vs the 20. Yea, installing stage 1 cranes do make a difference in both motors. No mix & matching the bottom end of either motor. If you want a 23 get one. You can throw a 23 head at the 20.
felixthecat is online now
Old 03-07-2014, 07:49 PM   #15
Gladious
Fan#: 88166
Points 157, Level 3
hmmm 23 and 20?.. I've read about that ..now im going to have to re look that up lol.
Gladious is offline
Old 03-08-2014, 10:11 AM   #16
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
Plus the 23 uses longer rods too.
Old 03-09-2014, 09:02 PM   #17
Gladious
Fan#: 88166
Points 157, Level 3
mmm... what about that Massive product the boarded cylinder wouldn't you need to change everything with that type of thing? because I seriously debating about up grading my car or finding a newer car and just garage keep that instead ...but im just trying to test the waters before I jump in..
Gladious is offline
Old 03-09-2014, 09:30 PM   #18
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,329, Level 75
Points: 13,329, Level: 75 Points: 13,329, Level: 75 Points: 13,329, Level: 75
Level Up 20% Completed
Forum Activity 99%
The "boarded plate" I think you are referring to is a torque plate to bolt on in place of the head when boring cylinders to a larger size ( to compensate for wear when rebuilding).
It's a machine shop tool, not a performance part.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 03-09-2014, 11:32 PM   #19
Gladious
Fan#: 88166
Points 157, Level 3
Massive.com has the actual cylinder head .. lets see ..
http://www.massivespeedsystem.com/_m.../i-412029.aspx
i hope that link is do-able
Gladious is offline
Old 03-10-2014, 06:36 AM   #20
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
That head looks awesome. To take advantage of it you'll need rods/pistons & turn the motor at high rpm or go boosted. It seems geared towards racing. The 23 head is the realistic way to go. If you had a sbc or ford v/8 I'd say go for it.
