Sub Installation - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-27-2014, 10:13 AM   #1
jwyrick03
jwyrick03's Avatar
Fan#: 119804
What I Drive: 2008 Red ZX4
FF Reputation: 1 jwyrick03 Good Standing Member
Sub Installation
I'm putting subs in my 07 Ford Focus SE and I'm not exactly sure how to run the power wire through the firewall back to the amp?
Please help!
jwyrick03 is offline
Old 02-27-2014, 10:46 AM   #2
Mgrwc14
Fan#: 141065
What I Drive: 2004 silver SE PZEV
FF Reputation: 1 Mgrwc14 Good Standing Member
You would have to drill a hole in the drivers side firewall just above the pedals. I didn't want to drill so ran it through the fender and through the door way. I know ghetto but I didn't have a drill bit lol. Make sure if you drill to seal it off after you have put in the wire.
Mgrwc14 is offline
Old 02-27-2014, 10:51 AM   #3
Tundrafoci
Fan#: 96605
What I Drive: 2003 light tundra ZTS
Points 717, Level 14
Points: 717, Level: 14 Points: 717, Level: 14 Points: 717, Level: 14
Level Up 17% Completed
FF Reputation: 5 Tundrafoci Good Standing Member
Buy-Sell-Trade Rating: (8)
I ran it through the fender as well. Been 2+ years nothing bad to report. I even check on the places where it would rub and I haven't noticed any damage to the wire at all. Also bonus no drilling your car. Its not a bad way to go just make sure you get some butyl rope to put in places where you are worried about it rubbing through.
Unless you have an automatic in which case there is already a hole in the firewall where the clutch pedal would go and you can just use that.
Tundrafoci is offline
Old 02-27-2014, 11:15 AM   #4
Gadabout
Gadabout's Avatar
Fan#: 114774
What I Drive: 2006 Vermillion Red ZX4 SE
Points 1,052, Level 17
Points: 1,052, Level: 17 Points: 1,052, Level: 17 Points: 1,052, Level: 17
Level Up 52% Completed
FF Reputation: 4 Gadabout Good Standing Member
This.
Drill through, grommet, done.
“Things work out best for those who make the best of the way things work out.” - J Wooden
Team Duratec #42
Gadabout is offline
Old 02-27-2014, 11:19 AM   #5
jwyrick03
jwyrick03's Avatar
Fan#: 119804
so there should already be a hole there? Mine's an automatic?
Old 02-27-2014, 11:19 AM   #6
jwyrick03
jwyrick03's Avatar
Fan#: 119804
I'm not too hype on drilling, I'll try to run it through the fender.
Old 02-27-2014, 11:28 AM   #7
Gadabout
Gadabout's Avatar
Fan#: 114774
No, theres a plastic plate where a clutch would be. This is what an installer would use to do it right.
Team Duratec #42
Gadabout is offline
Old 02-27-2014, 11:30 AM   #8
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,709, Level 76
Points: 13,709, Level: 76 Points: 13,709, Level: 76 Points: 13,709, Level: 76
Level Up 15% Completed
Forum Activity 11%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
Moved to: Car Audio
Ive had mine run thru the fender for about 8 years with no issues, but like the others have said there is a hole for the clutch pedal as well, better option imo as you wont be seeing the wire every time you open your door.
SkyPilot is online now
Old 02-27-2014, 11:42 AM   #9
FocusKnot
FocusKnot's Avatar
Fan#: 117505
What I Drive: 2004 Red SE Wagon 2.0 Zetec Auto
Points 1,605, Level 23
Points: 1,605, Level: 23 Points: 1,605, Level: 23 Points: 1,605, Level: 23
Level Up 5% Completed
Forum Activity 3%
FF Reputation: 3 FocusKnot Good Standing Member
Since you have an automatic trans, there is one bolt that holds the plastic filler plate for the clutch to the firewall. Unbolt it and then you can drill a hole thru the plate with it out of the car. One advantage to using the plate to pass the wires harness thru, is that the plate is plastic and less chance of any rubbing causing a short as might be the case if you ran it thru a hole in metal.
FocusKnot is offline
Old 02-27-2014, 12:13 PM   #10
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,573, Level 53
Points: 6,573, Level: 53 Points: 6,573, Level: 53 Points: 6,573, Level: 53
Level Up 12% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (23)
Drill the plastic plate, use a grommet, seal with silicone as the poster above said. It is much easier to push the wire into the engine compartment than it is to pull it to the rear.
Nothing beat the fact of a well done job.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
