SVTF 4 door - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 02-28-2014, 03:14 PM   #11
replica81
replica81's Avatar
Fan#: 88615
What I Drive: 05 ST
Points 1,607, Level 23
Points: 1,607, Level: 23 Points: 1,607, Level: 23 Points: 1,607, Level: 23
Level Up 7% Completed
Forum Activity 3%
FF Reputation: 3 replica81 Good Standing Member
Modded, walk away.
Originally Posted by co1458 View Post
The ford maintenance guide says the timing belt going bad will have no effect on the car as far as damage. recommends replacing at 125k I remember reading that a while back.
The SVT has an interference motor. It will damage things if the belt breaks.
SR #272
Beer and Metal.
replica81 is offline
Old 02-28-2014, 05:03 PM   #12
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 4,991, Level 45
Points: 4,991, Level: 45 Points: 4,991, Level: 45 Points: 4,991, Level: 45
Level Up 21% Completed
Forum Activity 13%
FF Reputation: 6 SlickWilly Good Standing Member
I mean, it could survive but not likely. I had a timing belt blow on a interference motor, it survived, scary as shit though not something you want to encounter so either way make sure it is good to go. Like he said modded cars are not the best to buy.
K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - N2O
SlickWilly is online now
Old 02-28-2014, 05:17 PM   #13
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
What I Drive: '02 Infra-Red SVT
Points 3,055, Level 34
Points: 3,055, Level: 34 Points: 3,055, Level: 34 Points: 3,055, Level: 34
Level Up 4% Completed
Forum Activity 99%
FF Reputation: 6 Gav-O-SVT Good Standing Member
9 times out of 10 modded= used and ABUSED.
Gav-O-SVT is online now
Old 03-05-2014, 02:48 PM   #14
JaFocus01
JaFocus01's Avatar
Fan#: 48654
What I Drive: 01 Turbo Zx3 & 04 Orange EaP
Points 1,382, Level 20
Points: 1,382, Level: 20 Points: 1,382, Level: 20 Points: 1,382, Level: 20
Level Up 82% Completed
FF Reputation: 1 JaFocus01 Good Standing Member
the motors on the focus are interference motors with or without vct, so if the timing chain goes the motor will likely bend the valves and mess up the pistons. check the compression on the motor check to see if theres any dirt/debri/oil in the intake and check all your vaccum lines and the pcv valve and make sure if it has any leaks or not. and as far as maintenance on the timing belt id change it after 100k miles
JaFocus01 is offline
Old 03-05-2014, 05:38 PM   #15
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 13%
The regular Zetec I believe is non-inference.
Old 03-05-2014, 07:12 PM   #16
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
Chain?
No they are not!
I can tell you that without a doubt the standard zetec is non-interference.
I have personally broken a belt, no damage.
I have personally removed the timing belt, moved a piston to TDC and freely rotated the cams. No contact or damage.
I do not know of anyone with a zetec who has had engine damage from a broken belt.
The SVT, it's hit or miss. It is interference. But as mentioned above, the conditions and actions after the break determine if and how much damage is done.
Both engines are driven by a timing belt.
The later engines, Duratec, is driven by a timing chain. Which does not break as belts do.
iminhell is offline
Old 03-13-2014, 07:21 PM   #17
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,189, Level 34
Points: 3,189, Level: 34 Points: 3,189, Level: 34 Points: 3,189, Level: 34
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 12%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
60k is a little excessive and OVER protective Id say every 90-100k do the timing assembly for the SVT Ive done 3 so far My car was at 97k and the other 2 were in the 115-120k range
qweesy is online now
Old 03-13-2014, 07:45 PM   #18
MineTwine45
Zetec is Best 'Tec
MineTwine45's Avatar
Fan#: 138537
What I Drive: 2003 Silver Frost ZX5
Points 21,466, Level 92
Points: 21,466, Level: 92 Points: 21,466, Level: 92 Points: 21,466, Level: 92
Level Up 12% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 2 MineTwine45 Good Standing Member
Okay, this sounds like the dumbest question ever, but what does the added F on the SVT stand for? I've seen it before but never understood what it meant.
2003 Focus ZX5 "Ruth" Silver Frost - 33,000 Miles - Hatch Nation #98 - TakeOver #004
Originally Posted by Deftmetal View Post
I saw a guy drop a wrench on a battery once. The hole in the ceiling was impressive.
MineTwine45 is offline
Old 03-13-2014, 07:50 PM   #19
co1458
Fan#: 106720
What I Drive: 2003,silver,SVT focus
Points 11, Level 1
Points: 11, Level: 1 Points: 11, Level: 1 Points: 11, Level: 1
FF Reputation: 1 co1458 Good Standing Member
Quick question . What's a typical price for replacing the svt timing belt ? I'm at 118k n planning to get it done soon
co1458 is online now
Old 03-13-2014, 07:55 PM   #20
ranger024x4
ranger024x4's Avatar
Fan#: 139745
What I Drive: 2004 silver svt
FF Reputation: 1 ranger024x4 Good Standing Member
svt focus
04 svt focus #1508
03 Ranger FX4 Level II 'twin stick'
88 mustang gt 5 speed
ranger024x4 is offline
