Extreme shaking at 55-65mph - Page 4 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 03-12-2014, 06:43 PM   #31
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
Originally Posted by herbz View Post
Learned a hard lesson about "Chasing vibrations above 55" on my old car a while back (a Ford, not a Focus),
Must be your tires! Replace those.. Nope
Must be the balance! Get a rebalance.. Nope
Must be a bent rim! Replace those. Nope
I see a little play in your tie rod! Nope
Your front axle half shaft is leaking oil! No
$3,000 later I said it.
This is why shotgunning parts is always a bad idea. take enough shots and you will eventually hit the target, but how much damage gets done to your wallet in the process?
find the problem, and fix it. spending thousands on what 'might' solve the problem is a complete waste of time and money.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 03-12-2014, 09:02 PM   #32
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 63 sailor Excellent Standing Member
Originally Posted by JustinT222 View Post
Well I went directly to the dealership to get everything fixed. Didn't want to be without a car for another week plus while the original shop messed around.
They went to balance the tires and they said it would have needed 6.5oz of weight on each tire...
The alignment was so bad on the car that it caused the tires to wear in a crazy pattern, basically you could run your hand over the tread and feel that one part of the tire was 1/8 - 1/4'' higher than the rest.
Didn't replace the tires yet, trying the alignment and crazy weights to balance for now and hoping the tires will wear down to normal after a few miles get on them.
The issue is a little better but far from fixed :(
Here's the OP's quote on tire wear/balance.
Decide whether those are likely to ever roll smooth for yourself.
Hard to tell if the tires are the only problem remaining, the wear & balance issues point to them as a definite problem IMHO.
P.S. - Agree that the "shotgun" approach can be costly. This car was apparently damaged badly, and not being aligned right after initial repair doesn't say much for the quality of that work.
"Rubber Side Down"
S.R. #275
sailor is offline
Old 03-12-2014, 11:31 PM   #33
JustinT222
Fan#: 107545
What I Drive: 2013 Black Focus Titanium
FF Reputation: 1 JustinT222 Good Standing Member
I agree that the quality of work has been sub standard.
I've called about them checking it out again and they give me a run around, I work 9 hour days 6 days a week and I can't take a day off to get the car to them anyway.
So after some more conversations with the dealership they are thinking new tires will fix the problem or at least that's what they are wanting to start with.
I just have a problem investing 650+ dollars on a whim because if its not the tires its the tie rods/axles
If its not the tie rids/axles it COULD be a small crack in a motor mount
If its the motor mount it COULD be something else
I got them to give me a quote to fix EVERYTHING and it was upwards of 5k if everything that COULD be a problem is replaced
Also as of late my car is roaring like I have 33'' mud tires on it and I'm told that its possibly a wheel bearing lol
I loved the car when its perfect, but lately its frustrating
JustinT222 is offline
Old 03-12-2014, 11:34 PM   #34
JustinT222
Fan#: 107545
Originally Posted by crazy_urn View Post
So, you are going to let the bank reposes the car because of a vibration? Did I read that correctly? That is an absolutely absurd idea that will negatively impact your credit for years to come.
It is probably too late now, but you should have contacted your insurance company before taking it to the dealership. Any reputable body shop should have had a warranty. Now the only thing you will ever get is a pissing match between the dealership and the body shop, both blaming the other for the problems.
Why ask for advice if you are just going to ignore it and do your own thing?
Was being a little over dramatic lol
I just want the car fixed without dropping 4 to 5 grand on it :(
Old 03-19-2014, 10:08 PM   #35
JustinT222
Fan#: 107545
Ok, new tires new alignment new wheel bearings and I'm back to 100% factory feeling/sounding
So I'm fixed for a little under a grand :)
Old 03-19-2014, 10:59 PM   #36
PratoN
PratoN's Avatar
Fan#: 88058
FF Reputation: 10 PratoN Great Standing Member
Yay! Which bearing(s) were bad?
2012 FF Ti HB Kona Blue, Built 5/24/2011, 401A + Ti Handling Package, Parking Technology Package, Winter Package, Moonroof, and MFT w/NAV at v3.6 91k miles and counting...
PratoN is online now
Old 03-19-2014, 11:27 PM   #37
JustinT222
Fan#: 107545
both on passenger side where the accident happened. I forgot how quiet and smooth the car was supposed to be :)
Old 03-20-2014, 03:58 AM   #38
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Wonderful to hear it's right finally.
"Rubber Side Down"
S.R. #275
sailor is offline
Old 06-14-2014, 12:38 PM   #39
TooOld
Fan#: 128586
What I Drive: 2014 Sterling Grey SE
FF Reputation: 3 TooOld Good Standing Member
Originally Posted by alfack View Post
Or the axle half-shaft? GF had that issue and it took them forever to figure out!
Yes, exactly what I had years ago in a Ford Escort. CV axle appeared fine (as in no boot breakage), but after trying many, many things, finally had someone say "CV axle." They were correct.
FocusFanatics - more entertainment per post than the FCC allows.
TooOld is offline
Old 06-14-2014, 08:51 PM   #40
FocusStrider
Deaf Focus Fanatic
FocusStrider's Avatar
Fan#: 36447
What I Drive: 2014 Tuxedo Black Ford Focus SE
FF Reputation: 3 FocusStrider Good Standing Member
Buy-Sell-Trade Rating: (7)
Last time I had this problem, it was the tires, so I changed them.. all smooth. I plan to have them check the alignment soon though.
Mr. Strider
Former FOCAL-POINT member
Former SEDAN REVOLUTION #11 member
Now a Freelance Street Tuner!
I'm Deaf and Proud to be!
FocusStrider is offline
