neg post problem - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-23-2014, 11:27 PM   #1
Bills86e
Bills86e's Avatar
Fan#: 119322
What I Drive: 2000 green SE, 2007 Kappa Speedster
Points 398, Level 7
Points: 398, Level: 7 Points: 398, Level: 7 Points: 398, Level: 7
Level Up 96% Completed
FF Reputation: 1 Bills86e Good Standing Member
neg post problem
Wife called said car is Dead. I got my voltmeter & hook strap and set out. Battery had 12.7v. I wriggled the battery connnections and she started.
Found the neg post connector just as you tighten the nut out, will turn
a little as if loose. Its nothing like a regular car battery connector. Ford.
Whats the fix?
Bills86e is offline
Old 02-24-2014, 02:18 AM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
\_l_/ -- That is about how the bolt looks. The edges of the battery clamp are straight for the most part.
So when the bolt is tightened the fingers of the clamp are forced together.
Being it is lead and soft, if it's overtightened or through repetitive use, the clamp will deform and the bolt can not clam tight enough.
The proper fix is going to be a new clamp or cable assembly.
A quick/temporary fix may be to simply 'shim' the bolt. Maybe a thin piece of metal on either side of the bolt will help.
iminhell is offline
Old 02-24-2014, 04:33 AM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,157, Level 74
Points: 13,157, Level: 74 Points: 13,157, Level: 74 Points: 13,157, Level: 74
Level Up 77% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat".
zetecDon is offline
Old 02-24-2014, 07:30 AM   #4
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
The bottom part of the bolt is 'anchor' shaped see the poster above iminhell \_I_/
For now get some pie plate material, 'drill' a hole then cut/shape it so it covers the 'anchor'.
The other possibility is that you have some sort of anti corrosive felt pad around the post-dump it
Anyway now tighten the connection, it should work
If it does then hunt down some thin brass sheet and replace that first piece
REASON:
To eliminate galvanic corrosion of dissimilar metals
Congrats of having a multimeter, SO MANY here think they can just look at stuff and solve electrical problems and start throwing parts at the situation
mikeeshaq is offline
Old 02-24-2014, 09:09 AM   #5
Bills86e
Bills86e's Avatar
Fan#: 119322
Points 398, Level 7
Thankyou Both !!!!
Bills86e is offline
Old 02-24-2014, 10:28 AM   #6
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
I ran an old Escort for years with a 1-inch sleeve of regular household conduit around the lead battery posts. I hack-sawed a slit down the side of each sleeve to allow it to expand/compress, allowing the cable clamps to clamp securely.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 02-24-2014, 11:19 AM   #7
syncro87
Fan#: 113430
What I Drive: 05 Wagon auto, 01 Wagon 5-spd
Points 293, Level 5
Points: 293, Level: 5 Points: 293, Level: 5 Points: 293, Level: 5
Level Up 86% Completed
FF Reputation: 4 syncro87 Good Standing Member
Good idea. I like it.
syncro87 is offline
Old 09-07-2014, 10:35 AM   #8
ellmarshptbo
Fan#: 185409
What I Drive: 2006 Focus ZX5 4 Dr Red,2000 Taurus
Points 31, Level 1
Points: 31, Level: 1 Points: 31, Level: 1 Points: 31, Level: 1
Level Up 62% Completed
FF Reputation: 1 ellmarshptbo Good Standing Member
yeah those terminal connectors are odd, I don't like them. I have them on my 06' and much prefer the older style on my dads 05'. Don't understand why they had to change them.
ellmarshptbo is offline
Old 09-07-2014, 10:16 PM   #9
amc49
Fan#: 96610
Points 3,376, Level 36
Points: 3,376, Level: 36 Points: 3,376, Level: 36 Points: 3,376, Level: 36
Level Up 18% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Because they make the company money after as little as one terminal cleaning removes enough material they do not clamp tight any longer. The design flat sucks there.
To mikeeshaq, oh no, I checked the fuses, relays, and wiring and there is NOTHING wrong with them..........................LOL, the biggest batch of incorrect deductions here onsite. I have met the enemy and he is ME.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is offline
