fuel pressure - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-23-2014, 11:03 PM   #1
sripvw
sripvw's Avatar
Fan#: 44061
What I Drive: 2007 aqua blue ses
Points 215, Level 4
Points: 215, Level: 4 Points: 215, Level: 4 Points: 215, Level: 4
Level Up 30% Completed
FF Reputation: 1 sripvw Good Standing Member
fuel pressure
hey all, ive been having a issue the last few days with the car bogging and almost stalling when at a stop. then today i could not accelerate without the car dying, i had to get back to my house at idle. when in the garage i heard the fuel pump whining really loudly and it finally threw a code...po191, fuel rail pressure. while the scanner was connected it was showing the fuel pressure at 13 psi. i replaced the fuel pump and the filter this afternoon and am still having the same issues.
my questions i have are,1) how do we hook up a fuel pressure gauge to the rail? there is no schrader? valve to screw the hose onto...2) is there a test for the fuel rail pressure switch to see if it is bad?
my car is a 2007 ses 2.0 that i have owned since new and have taken very good care of. i have 176000 mostly all highway miles on it.
i am stumped as to what it could be, i thought for sure the pump was bad. the filter bags on the pump were VERY dirty as was the inside of the housing where the pump sits. the tank itself was very clean looking...any ideas would be very much appreciated...thanks
sripvw is offline
Old 02-23-2014, 11:20 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
Fuel rail pressure (FRP) sensor might possibly be faulty or leaking internally.
P0191 - Fuel Rail Pressure Sensor Circuit Performance (FRP)
The comprehensive component monitor (CCM) monitors the FRP pressure for acceptable fuel pressure. The test fails when the fuel pressure falls below or exceeds a minimum/maximum calibrated value for a calibrated period of time.
Causes:
High fuel pressure.
Low fuel pressure.
Damaged FRP sensor.
Excessive resistance in circuit.
Low or no fuel.
A FRP PID value during KOER of 138 kpa (20 psi) and 413 kpa (60 psi) for gasoline or 586 kpa (85 psi) and 725 kpa (105 psi) for natural gas vehicles (NG) is acceptable.
BC_ZX3 is offline
Old 02-24-2014, 08:21 AM   #3
sripvw
sripvw's Avatar
Fan#: 44061
Points 215, Level 4
thanks for the response, im trying to trouble shoot the issue before dropping another 70 bucks on the sensor. i would like to verify fuel pressure to the rail first but cant seem to find out how to connect the pressure gauge. maybe a trip to the junk yard to grab a sensor and see what happens
sripvw is offline
Old 02-24-2014, 09:43 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Physical gauges that measure the fuel rail pressure usually cost as much as the FRP sensor itself.
http://www.massivespeedsystem.com/_m.../i-252294.aspx
BC_ZX3 is offline
Old 02-26-2014, 12:02 PM   #5
sripvw
sripvw's Avatar
Fan#: 44061
Points 215, Level 4
is there anything else it could be ? i have replaced the pump, swapped out the fuel control module and i cleaned the frp sensor. i keep seeing 12psi on my scanner, but when i un-plug and plug in the harness to the module it goes up to 50psi and then slowly reverts back to 12psi...im stumped
sripvw is offline
Old 08-17-2014, 09:58 PM   #6
pcordes1979
Fan#: 174201
What I Drive: 2006 Ford Focus ZXW Light Tundra
Points 131, Level 2
Points: 131, Level: 2 Points: 131, Level: 2 Points: 131, Level: 2
Level Up 62% Completed
Forum Activity 4%
FF Reputation: 6 pcordes1979 Good Standing Member
deleting message, didn't read previous messages in thread.
pcordes1979 is offline
Old 08-26-2014, 11:22 AM   #7
madjik68
Fan#: 166882
What I Drive: 2014 metalic grey SE
Points 44, Level 1
Points: 44, Level: 1 Points: 44, Level: 1 Points: 44, Level: 1
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 madjik68 Good Standing Member
Sry to hear your fuel pump went out. I'm dealing with the same issue with my 2014 Focus. The car has 3,000 mi on it and the fuel pump quit.
madjik68 is offline
