If you have ever found a small puddle under the front/ center of your SVT - - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-20-2005, 12:04 PM   #1
Darth Focus
I miss my Turbo SVTF
Darth Focus's Avatar
Fan#: 6849
What I Drive: 1988 Mazda 323 GTX
FF Reputation: 1 Darth Focus Good Standing Member
Buy-Sell-Trade Rating: (8)
Check here:
Look closely and you can see the drip at about 6 o'clock on the sensor. It goes towards the head and straight down.
What I found, was the coolant temp sensor is actually sitting in a stripped out bung. I have never touched it, and I dont know if Ford ever did. I do know that my car has had a tiny residual leak since my clutch TSB. I dont know if it was over tightened (well, yeah, it was, it wont snug at all).
So I either need to get my car in before my 36K is up (~400 to go) or buy a new "waterneck" (?) and do it myself....
Check your cars...
Russ Rudez
1988 Mazda 323 GTX; 1 of 1,243 Imported
AEM CAI, VJ11 Turbo @ 20psi, 2.5" IC Pipes,
Corksport IC, CFDF Clutch, 2.5" Turboback, Konis,
Suspension Tech Springs, 22mm Rear Sway, + More.
Darth Focus is offline
Old 02-20-2005, 12:32 PM   #2
Darth Focus
Fan#: 6849
NOTE: I cant tell if it threads in or not...I now found a C-Clip at the base of the bung...
I'm going to throw my OEM stuff on and take a trip to Ford...
Russ Rudez
Old 02-20-2005, 12:34 PM   #3
essveetee
essveetee's Avatar
Fan#: 1529
What I Drive: 2006 WRX 1984 VW Scirocco
FF Reputation: 1 essveetee Good Standing Member
Buy-Sell-Trade Rating: (21)
This is a pretty common problem, unfortunately. I think you right, it doesn't thread in. Been a while since I changed my thermo, but I believe it was just clipped in with an o-ring seal.
Sciroccos are cool.
essveetee is offline
Old 02-20-2005, 12:47 PM   #4
Darth Focus
Fan#: 6849
I bet I have no O-RIng...its just there and a clip holding it...it almost appears to be leaking around the clip, and not at the very top...
Does anyone have a schematic of the thermo housing assembly..like an exploded veiw of each part??
Russ Rudez
Old 02-20-2005, 07:02 PM   #5
essveetee
essveetee's Avatar
Fan#: 1529
I had one, but its gone. Call up Ford tomorrow and have them fax you the sheet. I honestly can't remember how it mounts, but I'm pretty sure it has at least one o-ring.
Sciroccos are cool.
Old 02-20-2005, 07:11 PM   #6
Hypnotic
Hypnotic's Avatar
Fan#: 17757
What I Drive: 02 Black SVTF with an 04 heart
FF Reputation: 1 Hypnotic Good Standing Member
Buy-Sell-Trade Rating: (27)
Let me get back from a test ride in the new baby, and I will post the schematic from the Ford DVD
W Foy
SVT Squad #109
Hypnotic is offline
Old 02-20-2005, 08:09 PM   #7
essveetee
essveetee's Avatar
Fan#: 1529
Wayne, you have PM.
Sciroccos are cool.
Old 02-21-2005, 12:35 AM   #8
Darth Focus
Fan#: 6849
Wayne, any news??
Russ Rudez
Old 02-21-2005, 07:52 AM   #9
Hypnotic
Hypnotic's Avatar
Fan#: 17757
I just checked the DVD, believe it or not, there is NO blown out schematic of whether or not there is an O-ring there. Sorry guys, I tried
W Foy
SVT Squad #109
Hypnotic is offline
Old 02-21-2005, 08:42 AM   #10
able2roll
able2roll's Avatar
Fan#: 11007
What I Drive: 2002 Silver SVT
FF Reputation: 1 able2roll Good Standing Member
are you pointing to your coolant pump?i had this problem a couple of weeks ago with radiator fluid leaking from a small silver protrusion (called the weeper valve) from the coolant pump.i read it is caused by bad seals inside of your pump.all i did was buy some of the Bar's Leak stuff and poured it in my coolant reservoir.I have pics too, if you want to see them.
...Faction R...
Check out my profile, as well as my team's, at OnlineShowoff...
http://factionrSVT.onlineshowoff.com
able2roll is offline
