oil pan d20 vs d23? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 02-23-2014, 06:19 AM   #1
koke'sfocus
koke'sfocus's Avatar
Fan#: 69779
What I Drive: 05 silver st
Points 4,267, Level 41
Points: 4,267, Level: 41 Points: 4,267, Level: 41 Points: 4,267, Level: 41
Level Up 59% Completed
FF Reputation: 1 koke'sfocus Good Standing Member
Buy-Sell-Trade Rating: (6)
oil pan d20 vs d23?
Are the 2 oil pans diferent? Im thinking because of the balance shaft
cossie im, cfm 67mm tb, 3" dp, 3" exhaust and custom turbo kit, holset hx35 turbo on 13psi, exedy stage 2 clutch and flywheel
Stock long block 353whp 280lbtq, 13psi
team duratec #94
D23 crew #9.
koke'sfocus is offline
Old 02-23-2014, 01:15 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,881, Level 74
Points: 12,881, Level: 74 Points: 12,881, Level: 74 Points: 12,881, Level: 74
Level Up 8% Completed
Forum Activity 99%
At a guess I'd say you're right.
Takes about an extra quart to fill it after the delete, that wouldn't be normal capacity for the 2.0.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 02-23-2014, 06:01 PM   #3
koke'sfocus
Fan#: 69779
I want to think I can put a 2.0 in a 2.3 engine if I do the bsd?
team duratec #94
D23 crew #9.
Old 02-23-2014, 06:29 PM   #4
Black05
Fan#: 123169
What I Drive: 2005 Black St
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
FF Reputation: 1 Black05 Good Standing Member
I wonder if there is a height difference on them? Basicly if a 2.0 on a 2.3 would give more ground clearence? Or made a pan baffle not needed?
Black05 is offline
Old 02-24-2014, 05:06 PM   #5
koke'sfocus
Fan#: 69779
Well the d23 passenger motor mount is taller so maybe that compensate the clearance of the oil pan and the ground
team duratec #94
D23 crew #9.
Old 02-25-2014, 02:57 AM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Trans hangs as low as the pan on the 2.3, so a shorter pan won't help with clearance.
If the pan baffle kit from massive was around when I did the BSD it would have gone in then, now it's another "some day" job.
"Rubber Side Down"
Old 02-25-2014, 07:41 AM   #7
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,059, Level 74
Points: 13,059, Level: 74 Points: 13,059, Level: 74 Points: 13,059, Level: 74
Level Up 53% Completed
Forum Activity 99%
The deck height is taller in the 23 for the additional stroke length.
felixthecat is offline
Old 02-25-2014, 07:44 AM   #8
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
I used a windage tray for a speed3. PTperformance. DFDD= Damm Fast Daily Driver.
