13 ST lowered seat bracket? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 02-22-2014, 04:06 PM   #1
dudeitswillis
dudeitswillis's Avatar
Fan#: 49214
What I Drive: 2013 Tangerine Scream ST
FF Reputation: 1 dudeitswillis Good Standing Member
Anyone know if someone out there offers or can make a bracket (or a way) to lower the recaro driver seat? I'm fairly comfortable now, but would like a bit more head room. I'm 6"2', so I come a tad close to the roof(I can't drive 'leaned back' very uncomfortable. ) lower the better. All help appreciated.
dudeitswillis is offline
Old 02-22-2014, 09:02 PM   #2
kakarote
kakarote's Avatar
Fan#: 124441
What I Drive: 2013 race red focus se hatchback
FF Reputation: 1 kakarote Good Standing Member
lowering seats
Im also 6'2", so i understand the height deal. I presume that you lowered the seat with the handle on the side of the seat.
With that said, I have in the past, lowered seats in previous cars. The way I did it was by removing the factory brackets.
I measured the factory brackets and figured out how much lower I needed.
I went to home depot and picked up a square boxed steel tube. Cut them about 2" long and drilled the appropriate diameter hole in them. I also picked some longer bolts for the brackets. ( also, flat washers can be used in the place of the box tubes and plastic shims)
MOST IMPORTANT, please remember to use lock washers or castle nuts on the brackets so the don't move!
Now, remember , the seat has forward and backward bracket under the seat with springs and cables.
Remember to allow room for them to operate, and you may need to shim the front to get the correct seat angle you need for comfort. I would use thin plastic putty or bon-do spreaders for this.
Hope this helps. I haven't looked at my seats, so I'm not sure this will work on the focus or not. But this is what I've done in the past.
Last edited by kakarote; 02-22-2014 at 09:06 PM. Reason: left out other options for lowering
kakarote is offline
